Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-10-2009, 02:13 PM   #26
SCOTI
SCOTI's Avatar
Re: tubular motor mounts
Originally Posted by 69trk View Post
....I guess that if my new headers hit my lower a-frame again, i'll have to put some spacers underneath the tubular mounts. To bad they don't make a mount that's inbetween the 2 sizes that they have. I have also figured out that just a few washers can make a big difference!!!!
I made 'shims' for the POL mounts. I traced the bottom mounting surface on some cardboard (the part that sits on the c.member). I then transferred the template to the appropriate steel in the thickness of choice. Worked well for my application so keep it in mind (looks more solid than washers too....).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-10-2009, 02:15 PM   #27
SCOTI
SCOTI's Avatar
Originally Posted by regan wilson View Post
When I changed over to my brodix 10.600 deck block I had to lower my motor in the frame half an inch . So I just lowered the tranny mount half an inch to keep it at the same angle . Since you cant adjust your pinion angle on a trailing arm you might check the angle with the tranny in both positions and see which one best suits you .
Pinion adjusting shims are available for truck arm suspensions too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
