Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-05-2009, 08:08 PM   #1
69trk
69trk's Avatar
tubular motor mounts
I have these tubular motor mounts mounted before with some of the polyurathane mounts. The problem that i had before was my headers hit my lower a frame on the driverside. Plus my urathane mounts broke. So i went ahead and bought a set of solid mounts that are about 1/2 taller. Everything seams like they will work, but wondering if it will efect my drivetrain from lining up right. My engine seams to slant a little bit more to the rear. Any advise will be apreciated. here's a few pictures of what i have.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-05-2009, 08:11 PM   #2
69trk
69trk's Avatar
Re: tubular motor mounts
Here's a couple more
1.58- 60'
11.37- 1/4 @115.81
Old 04-05-2009, 10:12 PM   #3
72 SUPER10
looks good , vince
72 SUPER10 is offline   Reply With Quote
Old 04-05-2009, 10:50 PM   #4
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
is the trans,driveline, ect hooked up? they shouldnt have let it move but if all that isnt it could have....try to see if everything bolts up fine
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 04-06-2009, 06:06 AM   #5
69trk
69trk's Avatar
everything bolted up fine, i don't have anything tight yet, because im waiting to get some new headers, and i may need to lift engine to slide them in.
1.58- 60'
11.37- 1/4 @115.81
Old 04-06-2009, 10:01 AM   #6
drag_72
Ready to go fast!!
drag_72's Avatar
what kind of compression do you got? you sprayin at all to get that 11.37?
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 04-06-2009, 10:01 AM   #7
drag_72
Ready to go fast!!
drag_72's Avatar
i guess the nitrous question was stupid lol i dont see a plate shot or fogger system lol my bad
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 04-06-2009, 09:08 PM   #8
69trk
69trk's Avatar
11/1 comp. plan on running a 125 shot mabey this year.
1.58- 60'
11.37- 1/4 @115.81
Old 04-06-2009, 09:12 PM   #9
joeys66pickup
Dr. Frankenstein
should be fine then....so im guessing the 431" is whats left of a 427? nice truck by the way!!!
I Wanna Go Fast!!
Old 04-06-2009, 09:17 PM   #10
69trk
69trk's Avatar
thanks joey, yea it's a .030 over 427
1.58- 60'
11.37- 1/4 @115.81
Old 04-09-2009, 10:13 PM   #11
prostreet1967
prostreet1967's Avatar
u running pump gas?
prostreet1967 is offline   Reply With Quote
Old 04-09-2009, 10:42 PM   #12
69trk
69trk's Avatar
I run a mix 92 and 110. I have ran straight 92, but i don't get on it, just incase.
1.58- 60'
11.37- 1/4 @115.81
Old 04-09-2009, 11:21 PM   #13
Ont67shortbox
Looks good, but isn't a .030 over 427 a 433?
Ont67shortbox is offline   Reply With Quote
Old 04-10-2009, 03:10 AM   #14
joeys66pickup
Dr. Frankenstein
im not sure if .030 over always amounts to the cubes added for each engine....depends i guess on the EXACT bore sizing down to super tiny i cant even spell numbers
I Wanna Go Fast!!
Old 04-10-2009, 09:08 AM   #15
J_PEPIN87
J_PEPIN87's Avatar
Damn 11.3 for all motor is fast i was hoping to run this fast with nitrous when i'm done with my 427. Wat size stall are you running?
J_PEPIN87 is offline   Reply With Quote
Old 04-10-2009, 05:02 PM   #16
69trk
69trk's Avatar
3800 stall
1.58- 60'
11.37- 1/4 @115.81
Old 04-15-2009, 12:32 PM   #17
regan wilson
regan wilson's Avatar
When I changed over to my brodix 10.600 deck block I had to lower my motor in the frame half an inch . So I just lowered the tranny mount half an inch to keep it at the same angle . Since you cant adjust your pinion angle on a trailing arm you might check the angle with the tranny in both positions and see which one best suits you .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-15-2009, 02:16 PM   #18
Super73
Super73's Avatar
You may have to adjust the exhaust to meet up to the headers flange properly. When installing the motor plate in my truck I went up with it as much as possible with a slight slant to the rear and I need to cut the collector off the exhaust and reweld it since the angle changed slightly.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-15-2009, 03:58 PM   #19
joeys66pickup
Dr. Frankenstein
thats weird, i noticed you didnt have to put washers under your mounts....I Did though? i have a set under the actual mount and under the bolt head like you huh.
I Wanna Go Fast!!
Old 04-15-2009, 05:03 PM   #20
69trk
69trk's Avatar
I had a friend come over and look at it and he said the same thing about my engine leans back to much. So what i did was ordered new poly mounts from energy suspension which they said will not break!!!!! I also plan running a strap just incase. Plus a solid mount looks like it could eventually break the welds on my tubular mounts. I guess that if my new headers hit my lower a-frame again, i'll have to put some spacers underneath the tubular mounts. To bad they don't make a mount that's inbetween the 2 sizes that they have. I have also figured out that just a few washers can make a big difference!!!!
1.58- 60'
11.37- 1/4 @115.81
Old 04-27-2009, 02:44 PM   #21
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
how much do you want for the solid ones
and where did you get the lower mounts
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-06-2009, 12:26 AM   #22
GMC70c20
where did you get those mounts?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 05-06-2009, 02:02 AM   #23
meansting04
meansting04's Avatar
Run it and see. You will know if somthing is off. I think this is the only way to be sure. You don't want to get too crazy though. Let us know.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 05-06-2009, 05:57 AM   #24
69trk
69trk's Avatar
the tubular mounts came from performance online. The solid mounts came from moroso. I can't sell the solid mounts, they belong to a friend. He let me try them to see if they would work.
1.58- 60'
11.37- 1/4 @115.81
Old 05-06-2009, 08:50 PM   #25
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
thanks
do you have a website for both mounts
Gage
