#26 |
someday it will be done!
Re: what did you get done 4/19/09
Put a stereo in my 80 using the sub and amp that's been following me around for years.I finally decided to build a box and get some use out of it before I get too old....it's borderline too loud
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#27 | |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#28 |
i bought this 86
#29 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I was presently surprised when I picked it up that the whole harness was removed with only 1 cut in it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#30 |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#31 | |
#32 |
I pulled the airhorn of the q-jet and fixed several issues.
Both high-speed air-bleed tubes had fallen out of the air horn and were sitting in their wells. Hammered them bank in. Float level was 3/16" and was supposed to be 3/8". Needle was hooked to float with 2 of the little hanger clips, one through each hole in the float bar. Put in a new needle & seat and float. Hung the needle how it was meant to be. Adjusted the air-door spring to 7/8 turn. It was at about 1/2. Gasket was folded over on the drivers side secondary. Front mounting bolts - 1 cross-threaded and one wasn't even finger tight. Several of the air horn screws were just finger tight also. I know they're not supposed to be torqued down real hard, but they shouldn't move from the weight of the screwdriver. New air horn gasket and tightened everything down correctly. After I was done, I adjusted the idle mixture and speed since it was running much faster now. Throttle response is much better and I think the gas mileage will improve, but I haven't been able to test it yet. I know lots of people don't like them, but it's really hard to beat a well tuned Quadrajet for a daily driver carb. (It's just hard to get them tuned that way sometimes.) Matt |
#33 |
truck addict
honestly i should have... but being i have a new cab that im gonna swap on it anyway i didnt put any supports in there... after a few days of driving it around and everything settling the doors are getting harder and harder to close.. im gonna be swaping this cab onto my longbed 87 but im gonna weld the doors closed and probley put a roll cage in it before i do... the cab itself is borderline rotted so thats why it setling the way it is... i may be buying a 77 longbed and do the same... only brace it better this time.. this was just kind of a test to see what it would look like cause the cab was toast anyway
trucks |
