Old 04-28-2009, 11:38 AM   #26
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6 Lug Rally Wheel Center Caps
Here it comes....Gotcha You got me on the 7" I admit,but I`m seein`16 on the 5-luggers.
(Just worked out that way,not into tit for tat)
I meant 8" 6-lug ralleys.
Keith
Convert to disc brakes.
Old 04-28-2009, 11:41 AM   #27
lolife99
lolife99's Avatar
Originally Posted by chevlwb68 View Post
okay so I just realized also that the 6 lug wheels have 10 holes (openings?...don't know what to call them) in them, while the 5 lug have 16. interesting, but cool......so it does seem to be a little rare.
I've actually never counted them before now,....
Keith
Old 04-28-2009, 06:19 PM   #28
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
Originally Posted by 68Stepbed View Post
Here's a shot of the 6lug versions.
how did you get the caps to stay on. i drill three holes and bolted them on
Rudy67chevy is offline   Reply With Quote
Old 12-09-2009, 05:40 PM   #29
Matty Wagz
Matty Wagz's Avatar
lolife99, what size tires you running on the back of your 69 w/ the 15" rallys? they look good in there. Thanks, Wagz
Matty Wagz is offline   Reply With Quote
Old 12-09-2009, 07:36 PM   #30
lolife99
lolife99's Avatar
275/60-15's.
Keith
Old 02-21-2010, 09:54 AM   #31
67mater
67mater's Avatar
are these low profile caps still available? can't find em! I also wondered where the conversion lug nuts are available. LAstly, I bought what I was told was 5 15x8 6 lugs for $80; turns out two fo them are the 7"!!! I noticed when I got there but kept my mouth shut!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 02-21-2010, 10:16 AM   #32
67mater
67mater's Avatar
just found these 7/16 lug nuts with the gm outside thread!
http://www.prestigewheel.com/cgi-bin...ction&key=5802
1967 K10
1967 Camaro
Old 02-22-2010, 09:03 AM   #33
Matty Wagz
Matty Wagz's Avatar
same thing happened to me 67Mater, bought a set of 6 lug rally wheels and turns out 2 of them were 15 X 7s. fine by me,
trying to find a different kind of center cap to go into these wheels, any ideas?? leaning towards push through cap with straight bar spinner from Summit. not really first choice, but seems to be best looking right now and i think the wheels need something.
Old 02-22-2010, 09:37 AM   #34
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
matty if your running the 10 hole 6 luggers than you better check clearance my wheels are very tight on the center hole I dont think I could get a cap on and still seat the wheel tight to the drums
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-22-2010, 09:58 AM   #35
Hottrucks
Hottrucks's Avatar
I just did some measureing and the lug nuts are 6 1/2 apart but you could snap a couple clips and snap a 7 1/2" cap on and be in a set of baby moons..for about $25 this is what I'm talking about
http://www.bigrigchromeshop.com/Merc.../UEHC/UP10201P
these are the horn covers I was thinking of notice the dimentions
http://www.bigrigchromeshop.com/Merc.../UEHCS/UP10301
for those not famliar with these there is an inner lip that snaps over the lug nut corners (sometimes you need to turn the lugs a bit to get them tight) but they stay very well I have run a dump truck though gravel pits and every where else without loosing them...
I think its going to look killer and make others scratch there head to see baby moons on a rally??Oh and in my case a 14" wide stock Rally but thats another post... but we will keep it our secret....!!!...LMAO
Old 02-07-2011, 12:15 PM   #36
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Hottrucks,Did you ever get these installed?Wondering how it worked out.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 02-07-2011, 03:17 PM   #37
Hottrucks
Hottrucks's Avatar
the pieces work but my wallet has been taking a beating so its kinda on hold till spring...we mocked the hole thing up with 2" drop spindles I think I may also try going to a hine joint to save on the ball joint convertion then I can also swap it so there is better steering angle
Old 02-10-2011, 02:25 PM   #38
ChevyLvr4Life
ChevyLvr4Life's Avatar
I'm running the later model center caps also like lolife99 and the rest mentioned. I'm using the 7/16" conversion lug nuts, and I also replaced the black lug nut covers with chrome ones, got them off ebay. I had the big 4x4 caps to start with didn't like them as much...
1970 Chevy C10 LWB 307 3OTT 3.73 gear
ChevyLvr4Life is offline   Reply With Quote
Old 02-10-2011, 02:59 PM   #39
lolife99
lolife99's Avatar
Those look good!
Keith
Old 02-10-2011, 03:58 PM   #40
Classic Bowties
Always on the hunt...
That's a good looking setup there ChevyLvr, I like the chrome lug conversion. To comment on the other part of this 6 lug rally thread, years ago I found and purchased a set of what I originally thought were 8's but they wound up being 7's and they came off of a mid 70's GMC 1500 4wd van. Mel
Classic Bowties is offline   Reply With Quote
Old 02-10-2011, 04:07 PM   #41
ChevyLvr4Life
Those look good!
Thanks guys, appreciate the compliments!
Old 02-10-2011, 07:04 PM   #42
cerjio
where would one get those 7/16th chrome lug nuts at forr the converstion ?
cerjio is offline   Reply With Quote
Old 02-10-2011, 07:19 PM   #43
ChevyLvr4Life
I found mine on ebay, I can't remember the seller's name, but he sells the 7/16" conversion lug nuts and the chrome lug nut covers as a set. I just found his name it's aaiautomotiveaccessories. He sell 2 different length lug nut covers for the trucks, make sure you get the longer ones. I bought the short ones and had to return them for the long ones.
Old 02-10-2011, 08:31 PM   #44
mtm_seven
Loading.....
mtm_seven's Avatar
Here's what my roommate did - these are off a 2002 or 03 chevy truck - you can get them in chrome also. Trick is you have to find lugnuts with a 7/16 shank and the threaded outer for the caps to screw on to.... those lugs may have come on newer Chevy cars like the maliboo and cavalier.
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 K20 LWB GMC
'72 K5 1-ton gear 468BB
‘79 K20 LWB GMC
‘86 K30 GMC High Sierra C&C Single Cab
‘94 LWB GMC 2500 4x4
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'01 K2500 Yukon Safari 6.0
‘06 1500 LWB 4x4 5.3
‘06 2500HD Single Cab C&C Duramax 4x4
'08 2500HD x-cab duramax 4x4
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
Old 02-10-2011, 09:40 PM   #45
ChevyLvr4Life
I almost went with the chrome version of those instead of what I got. They look good too.
Old 01-17-2013, 11:58 PM   #46
SD68C10
SD68C10's Avatar
Hi Keith, I scored a pair of 15x7, 6 lug, for my 68 stepside. Had to pay $300 - but it's worth it. Your '69 offset 7 & 8's look awesome! Do you have the low profile center cap? Like in the photo I attached. Thanks for your time, Bill. San Diego, CA
Here's my 7's and 8's on the my '69.
SD68C10 is offline   Reply With Quote
Old 01-18-2013, 12:38 AM   #47
SD68C10
SD68C10's Avatar
Great choice Keith!
Old 01-18-2013, 08:39 AM   #48
lolife99
lolife99's Avatar
Yes,... those are what I have.
I found mine on ebay.
Also found the 7/16" conversion lug nuts with the outer threads for the plastic screw on covers.
The covers are what holds the center caps to the wheels.
Keith
Old 02-14-2013, 01:54 PM   #49
Tomahawk30
Tomahawk30's Avatar
Looks like everyone here is buying the 7/16" conversion lug nuts, correct? I'm looking at picking some up at the site below, but their application guide shows 1/2" lugs on the 2wd trucks. I tend to believe what I read here more than some random application guide, but thought I'd double check to make sure that I'd use 7/16" nuts on my 70 C10... If these don't look like the correct lug nuts, someone slap me upside the head before I order them! Thanks!!!
http://www.ezaccessory.com/GM_7_16_E..._p/98-0022.htm
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline   Reply With Quote
Old 02-14-2013, 02:59 PM   #50
lolife99
lolife99's Avatar
5-lug trucks are 1/2".
6-lug trucks are 7/16".
Those are the correct 7/16" lug nuts.
Keith
