Old 07-12-2009, 10:45 AM   #26
DHPmike
DHPmike's Avatar
Re: Watts link
By the way, the one in the pics at the top, the crossbars are way short and if you have alot of lift you may max them out.
You can make the bars longer and go across the center with them. many stock vehicles that use a watts have the bars crossing the center.
DHPmike is offline   Reply With Quote
Old 07-12-2009, 11:01 AM   #27
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Watts link
Welcome over DHP.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-12-2009, 11:19 AM   #28
DHPmike
DHPmike's Avatar
Re: Watts link
thanks man. Ive already posted in some other threads as well. Man Ive done so many things to these GM trucks over the years.. hopefully I can help.
Old 10-10-2009, 08:05 PM   #29
fletch4x4
fletch4x4's Avatar
Re: Watts link
Just thought I should make a comment about the bars being too shot. Your right if I had too much lift they would max out. The bags are right over the axle, and with all the lift I can get outta them they don't get close to maxing out.
I designed it to have the bars level at ride height(ish) and still have all the travel they need.
Im not trying to be an expert or anything, but I would have defiantly been an idiot to weld everything up without at least cycling it through the suspension and making sure it actually works
edit... and it was done that way all for looks if you were wondering, just happens to work as well
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 10-11-2009, 12:54 PM   #30
DHPmike
DHPmike's Avatar
Re: Watts link
great, and ill add that a watts will let the axle go side to side if the bars go past the useable point. cycle any watts past the useable limit and you will see the axle go to one side.
also as I said, you can add travel by making the bars go across the centerline. like this...
im not dissing your project but rather adding tips to make ANY watts a better install. Ive made many many watts in kits and also many different variations in custom design form and there are little things that make them better.
Im also used to seeing bag setups with lots of lift and usually base bag opinions on that.
Old 10-13-2009, 06:21 PM   #31
fletch4x4
fletch4x4's Avatar
Re: Watts link
I hear ya- hell I was just copying pictures of what I had seen and reading some suspension articles. It was just luck that this all ended up working! lol. that and a lack of travel helps.
Old 10-14-2009, 06:10 AM   #32
DHPmike
DHPmike's Avatar
Re: Watts link
Ive seen some pretty short bars work on drag cars and such. trucks with bags need quite a bit of travel. post some more pics of your setup plz..
Old 10-16-2009, 02:31 PM   #33
fletch4x4
fletch4x4's Avatar
Re: Watts link
I wish I could right now, I think ive posted up all I have. I just moved to TN and the truck is still sitting in CT at my parents house.
I think I only have about 8 in of travel in rear from laying on the ground, to completely aired up.
when I get home (November) for a weekend ill get some pics and you can let me know what ya thing.
thanks for the help!
Old 10-16-2009, 06:03 PM   #34
DHPmike
DHPmike's Avatar
Re: Watts link
deffinitely post some pics as soon as you have some. anyone else with a watts please post some pics and tell us a little more about yours.
Old 03-12-2011, 12:22 AM   #35
jmlcolorado
Re: Watts link
I'm not dissing your project but rather adding tips to make ANY watts a better install. Ive made many many watts in kits and also many different variations in custom design form and there are little things that make them better.
I'm also used to seeing bag setups with lots of lift and usually base bag opinions on that.
Bringing up an old thread but is this picture showing the links past center line (vertical line at least) at ride height?
it looks as though when the axle travels through its articulation, the center line of the three points on the watts link will travel closer to vertical? Is this right?
jmlcolorado is offline   Reply With Quote
Old 03-12-2011, 07:04 AM   #36
DHPmike
DHPmike's Avatar
Re: Watts link
The watts stays in the middle like any other watts with the exception that it stays in the middle farther up and down the travel.
Yes the crank turns toward the vertical.
The difference here is that the bars have more length and that creates more up and down travel before the axle goes to one side.
Old 03-15-2011, 01:11 PM   #37
67cheby
67cheby
67cheby's Avatar
Re: Watts link
mine is a KP one just thought i would throw some pics of it on for reference
67cheby is offline   Reply With Quote
Old 03-15-2011, 01:21 PM   #38
jmlcolorado
Re: Watts link
That's a good lookin setup. I like the idea of mounting the watts using a separate ring on the diff rather then hard welding the pivot point.
Who makes that?
Old 03-15-2011, 01:23 PM   #39
jmlcolorado
Re: Watts link
That sounds like a good advantage to me. Why doesn't everyone do that? Is there a disadvantage to it?
Old 03-15-2011, 01:24 PM   #40
jmlcolorado
Re: Watts link
So I've heard that using a watts link is highly beneficial cause you can adjust instant center. I assume this is more for drag racing but what exactly IS instant center?
Old 03-15-2011, 01:25 PM   #41
67cheby
67cheby
67cheby's Avatar
Re: Watts link
it is made by KP COMPONENTS
Old 03-15-2011, 04:39 PM   #42
layingC10nK5
Re: Watts link
Nice gas tank, will that work without raising the floor? Who makes it? Thanks
layingC10nK5 is offline   Reply With Quote
Old 03-15-2011, 04:41 PM   #43
67cheby
67cheby
67cheby's Avatar
Re: Watts link
it would if you let it hang below the frame some , i have it so it doesnt hang below the frame at all, it is an RCI tank from Summit
Old 03-15-2011, 05:43 PM   #44
hotrodhomi
hotrodhomi's Avatar
Re: Watts link
I love the looks of the Watts. I have the KP watts on my blazer.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-15-2011, 08:19 PM   #45
DHPmike
DHPmike's Avatar
Re: Watts link
The benefit is that the axle stays in the middle for more travel plus the bars look cool going across the center especially with the cool looking center crank. the crank also rotates more which also looks cool with the right shape crank.
the only down side is the bars make odd angles as they go up and down. looks funny way up or way down..
The rear cover mount is a good way to go on a 10 bolt or 12 bolt. The axle mounts look pretty cool too tho...
Old 03-15-2011, 10:19 PM   #46
ruffrida2005
Re: Watts link
Mike that setup looks good. S10 i'm guessing? Can you show me some more pics of the rear set up.
Paul
Old 03-16-2011, 06:06 AM   #47
DHPmike
DHPmike's Avatar
Re: Watts link
That's on a Nissan Frontier. I will find more pics of this one plus this same one is going on a Nissan 720 this weekend.
Kinds depends on the style you want. You can mount to the axle and several people make nice setups. rear cover mount, I think only two companies make that style and then there's the frame mounted pivot where only the parallel bars themselves are mounted to the axle and everything else mounts to the frame.
Old 03-16-2011, 04:15 PM   #48
Mechanic77
Re: Watts link
Kind of like what I did on my truck
I need to post up some more current pics, I've cleaned things up a bit and upgraded the rod ends and links to 5/8"....if anyone's interested, I'll try to post some tonight
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 03-16-2011, 07:42 PM   #49
DHPmike
DHPmike's Avatar
Re: Watts link
yep, chassis mounted pivot, I made one of those also.
