Old 06-07-2009, 01:27 PM   #26
big mike71
big mike71's Avatar
Re: radio install ??
I always hook the red and yellow together and hook them to my brake light fuse, you just have to remember to turn the radio off.
big mike71 is offline   Reply With Quote
Old 06-07-2009, 02:18 PM   #27
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That's kind of what I'm trying to keep from doing. Initially the PO had both power wires hooked to the cigarette lighter which is why their battery was constantly dead, it was constantly drawing power.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-07-2009, 02:43 PM   #28
clos69
Its Topless Season!!!!
clos69's Avatar
Nate you can plug the red wire (12v+ acc) to the ingnition unfused outlet and the yellow (12v+ constant) to you cig lighter....this is how I hooked mine up with 0 problems...hope this helps
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 06-07-2009, 02:48 PM   #29
72BlckButy
Tot Roddin'
72BlckButy's Avatar
clos69, thanks for the info. Actually that is how I have it set right now. I was only worried about this type of setup if I was sitting in the truck and didn't have the truck running but turned to the "start" setting on the ignition. Would I end up burning up my points?
Apparently I also have some issues with my ignition as my truck tried to turn itself over in the accessory position yesterday afternoon.
Just trying to make sure everything will work after listening to the radio.
-Nate
Old 06-07-2009, 10:15 PM   #30
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Check the fuse. That labeled picture is a little wrong-the fuse labeled heat is actually the radio fuse. If you are using the stock radio it should be 3 amps. Also, if your using the stock radio, make sure your speaker is good. Playing the radio for very long without a speaker load on the output will burn it up.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-07-2009, 10:23 PM   #31
72BlckButy
Tot Roddin'
72BlckButy's Avatar
oldgold70c10, actually the PO hacked the dash so I installed a new unit (aftermarket). I was a little thrown off by the fuses and their labels. I will have to check the fuse labeled "heat." IIRC the color on the fuse was red, and the others on the block had a blue color on them (coloring within the fuse less than a 1/4").
Thanks for the info!
-Nate
Old 03-16-2012, 07:37 AM   #32
LSUMurse
LSUMurse's Avatar
I read the whole thread and followed the instructions and my new radio in my '68 C10 works perfectly.
Red wire from fuse box for main power when key is on.
Yellow wire jumped from cigarette lighter as memory power.
Thanks for all the help from those who knew.
LSUMurse is offline   Reply With Quote
Old 03-16-2012, 02:40 PM   #33
SOON2BLAZE
SOON2BLAZE's Avatar
Originally Posted by 72BlckButy View Post
Okay guys.... I need to bring this back to the top.
This morning I installed a new radio in my truck, but for some reason my radio terminal is dead. Does anyone have any ideas as to why this might be? This will be a dumb question, but is there a fuse to this terminal? Still learning guys..
What other terminals can I tap into to be able to use the accessory switch on the ignition?
Attachment 467763
Same issue here! Dead terminal. didnt used to be which makes me wonder if theres a relay somewhere that needs replaced?
SOON2BLAZE is offline   Reply With Quote
