#26 |
Fabricate till you "puke"
I would think a drop spring would mess with angles more than a block,as the arms set down the pinion will tend to roll nose down,& need a shim. You should see the shaft on my 69.....the back of the rear shaft angle upward to the rear diff! the sum of the 2 angle equal a straightline (trans & diff are phased properly). I have had the u joints in for 3 or 4 yrs, without problem& the shaft spins smooth to 6500 rpms.....thats about topped on 4.10 coggs....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#27 |
Slowly getting CRSS...
mine are 2.5'' made em out of 2'' ID square tubing, the reese hitch stuff. and went down to the spring shop and had em make longer bolts for $14.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
#28 |
So now we've got the rear dropped, what about the front?
I'm thinking of dropping my 2wd Jimmy using blocks in the back and for the front I was going to cut one complete coil off the springs rather than use drop spindles. The reason is to avoid my buddy's experience. He has a lowered 68 swb with drop spindles, which of course, drop the lower control arms. He's currently replacing the control arms cuz the spring pockets got bashed crossing an uneven railroad track. Any comments about the cut coil plan?
Thanks, ![]() ![]() |
#29 |
SLICER AND DICIER
That's not why your buddy JACKED up is control arm.
Yes spindles move up the center of the rim up but the reason he destroyed his lower control arm is because he didn't pay attention to his SCRUB LINE. This kinda thing happens all the time when you don't fully understand the concept of lowering. CUT COILS ![]() I feel if ya wanna do it DO IT RIGHT the first time. You can get a pair of drop springs from a number of vendors. ![]()
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
#30 |
Thanks for the reply NSANE 68!!!
Tell me more. What do you mean about paying attention to the scrub line? What is it in respect to and how do you have control over it? And secondly, whats the difference between shortening the springs compared with buying shorter ones? It's not that the coils would we cut or rewelded or cut on the oblique. They would be cut virtically one coil lower than they current are. |
#31 |
SLICER AND DICIER
SCRUB LINE, imagine you got 4 flats at once, then look under your truck and see what all would drag. In some states you can get multiple violations for scrub line laws.
I would guess your buddy put on 2.5" drop spindles and was runnin 15" rims with a small side wall tire. That would make for a very low scrub line. If he had 17" rims the scrub line would be 2" higher. Does that make sense? If I am wrong then I would say STAY AWAY from thos tracks in the future. Cause they GOTTA be sticking up higher than nomal. SPRINGS, first off if you cut a full coil off that will give you a full 3" of drop. NOW if you do a 3" drop in springs alone, YOU WILL NEVER BE ABLE TO ALIGN IT AGAIN. Cause your ride geometry will be all jacked up, basically leaving you with a negative camber. If you must cut, then atleast submerge the spring in water to keep heat down. When you shorten a spring it makes it stiffer, thus giving a bumpy ride. The new drop springs are wound shorter, with same load rating, giving a much nicer ride. PLUS they are CHEAP, like I said many board vendors have them for sale, including me. ![]() Sorry if I'm rambiling. ![]()
#32 |
PROJECT LO-LYF
Get yourself some Bags and be done with it!!!
But if you insist on dropped coils I have a set of 3 inch drop coils for the front, still in the box, never on a truck! $$75.00 plus a little shipping and there yours!! Send me a P.M. if you them.
FOUNDING MEMBER OF THE "O-SH*T, THAT TRUCK IS LOW" CLUB PROJECT: LO-LYF Bagged 68 Shorty home.att.net/~justin.lewis |
#33 |
Thanks again for the excellent reply 67/72 Junkie!!!
Now I savvy and you are right with my bud's truck config! I've bookmarked your Website. Cheers, |
#34 |
SLICER AND DICIER
Cool Brotha, that's what the board is for to learn.
#35 |
So Many Ideas, So Little Money
Crazy, when you lower with stprings the trailing arms pivot to the frame to lower the truck, going though natural motions yes raisiing th rear in relation to other u-joint spots BUT the rear is twisting wih it all. with blocks te frame in relationship to the trailing arms is te same, butterear is higher witout the rotation.. that make any sence?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
#36 |
Thanks for all the info guys, now i can get to work...
'68 Chev C-10 '91 Western Star (workin wheels) Just an ole time truckin idiot! Jim G. |
#37 |
I have to agree that 3"on a spring is pushing the geometry pretty hard. i have done a cut coil(1 full ring), & what was to be a temporary deal ......has run 10-12,000 mi! I dont have any complaints on the ride, other than the front feels a little 'soft". the truck handles good, & hasnt chewd the tires off the front. I have looked at other options, but will add a sway bar to the front to help give the springs a little boost....& just run it. i agree with the rest of the crowd that 2" on a front spring is about all you want to go to really keep front geometry as it should be......crazyL
