Old 12-29-2010, 07:33 PM   #26
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: OE Shock Relocators
See what I did?
I was planning on making them, then a quick swap onto my truck, Now I guess i'll have to butcher the 1 off my truck also
John
1999 Toyota Tacoma 4x4
Old 12-29-2010, 07:38 PM   #27
oldblue1968chevy
If I line em up back to back the shock eye holes dont line up
John
Old 12-30-2010, 11:40 PM   #28
oldblue1968chevy
Ok, got another bracket and got the tops done! The rivits took me nearly the afternoon!!! HUGE PITA FOR 4 RIVITS! I hate em
I havent started the bottoms yet. Is it ok if the metal tears (gonna put em in a 22ton press) But it looks like the metal will tear @ the curves. Did yours? I couldnt tell from the pix.
John
Old 12-31-2010, 09:51 AM   #29
SCOTI
SCOTI's Avatar
No, they should not tear. Just work them a little @ a time until flat. The hard part is done.... nice job so far.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-16-2011, 09:57 AM   #30
mcbassin
Still Learning
mcbassin's Avatar
Scoti,
I am going to do this cheap modification. What shocks do you need to run shorter versions of the original? I have 5" drop in the rear. I assume I have to get a way shorter shock?
Another question. On the upper mounts are the left and right the same or semmetrical until the tabs are trimmed off? thanks.
mcbassin is offline   Reply With Quote
Old 02-16-2011, 12:58 PM   #31
SCOTI
SCOTI's Avatar
Originally Posted by mcbassin View Post
Scoti,
There is a F/R to each bracket.
When I do this mod, I used standard, off the shelf shocks as my drops use lowering blocks (lowering blocks on truck arm set-ups have no negative impact on shock travel).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-16-2011, 08:44 PM   #32
oldblue1968chevy
There is a thread somewhere for the KYB ECE shocks but you can get the # to order them at your parts store..
John
Old 03-04-2011, 10:56 PM   #33
mcbassin
Still Learning
mcbassin's Avatar
I got the rest of my mounts done finally today. I had to use a rosebud torch and big hammer to flatten mine. Then I made some gusset/ribs to mount on the bottom of it to take the place of the originals that were flattened. I thought it might make it stiffer.
Thanks again Scoti for the great idea! I'm now trying to figure out my track bar and relocation mount. Here are some pics:
Old 03-05-2011, 03:17 AM   #34
SCOTI
SCOTI's Avatar
Nice. How much drop do you have? That helps determine what you need for the Panhard bar mounts.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2011, 02:36 PM   #35
mcbassin
Still Learning
mcbassin's Avatar
I'm using 5 inch lower springs. I like the idea of building my own adjustable super track bar kit like some of the after market companies make.
Old 03-06-2011, 06:40 PM   #36
SCOTI
SCOTI's Avatar
Some of the stuff being built by 'aftermarket companies' resembles stuff built by our members too .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2011, 08:05 PM   #37
oldblue1968chevy
There is a thread right now about homade adj panhards.
John
Old 03-06-2011, 08:10 PM   #38
crakarjax
crakarjax's Avatar
Link?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-06-2011, 08:17 PM   #39
SCOTI
SCOTI's Avatar
Originally Posted by crakarjax View Post
Link?
The FAQ section of the forum is in the info section. Click the 'truck tech' selection.....
http://67-72chevytrucks.com/vboard/s...d.php?t=450565
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-26-2012, 03:53 PM   #40
VA72C10
VA72C10
VA72C10's Avatar
bringing this great thread back up ttt...going to do this for my shop truck!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-04-2012, 02:03 AM   #41
HotRod C/10
HotRod C/10's Avatar
Great work!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
