Old 08-24-2009, 09:39 PM   #1
SCOTI
SCOTI's Avatar
OE Shock Relocators
Lot's of times when guys drop their 67-72 coil spring trucks they opt for relocating the mounting points of the shocks to gain precious travel back. Since you must remove the original shock brackets, with just a little effort, drill, angle grinder w/a cutting/grinding disc, & a press or vise, you can modify your originals.
Uppers first: You want to relocate the hole higher & slightly over vs. OE....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
