Old 02-07-2010, 02:36 PM   #26
highrpm
Re: Blazer Body Mount Bolt Measurements
Anyone know what the factory torque specs are on these??
highrpm is offline   Reply With Quote
Old 02-08-2010, 12:03 AM   #27
k5keith
Originally Posted by vtblazer View Post
Silver grade...
awesome silver grade has a good shear strength and hi torque value
seriously just bought a body bushing kit $139 no bolts but has washers . 9/16 and 1/2 bolts in grade 8 easy to find but not 3/8. all I can seem to find is grade 2 . seems a little weak. would like to get at least find grade 5 . I hate it when I get in a wreck and the body goes one way and the frame another
k5keith is offline   Reply With Quote
Old 02-08-2010, 07:15 AM   #28
vtblazer
vtblazer's Avatar
In truth, I really don't know what grade they are in the kits nor what grade they were from the factory.
vtblazer is offline   Reply With Quote
Old 10-09-2010, 08:54 AM   #29
vtblazer
vtblazer's Avatar
Old post, good info - - bump ttt
Old 10-10-2010, 04:12 PM   #30
hgs_notes
GEARHEAD
hgs_notes's Avatar
I had bookmarked this thread knowing the day was coming to replace the mounts. I used this today to buy all the bolts I needed. I go to a farm supply place because they have a good price for all the bulk nuts and bolts and they have all the carriage bolts to pick from. I got enough to do 2 blazers for about $16.00.
hgs_notes is offline   Reply With Quote
Old 10-29-2010, 11:05 AM   #31
mcmlxix
Collector of Projects
mcmlxix's Avatar
OK. I'll bump this and add a question...
My bolts are welded to the floor. Whats the best method to cut these loose without destroying the floor?
I was thinking dremel... but that means I have to borrow or buy one....
Rich
1972 K5 Blazer CST Click HERE
Old 10-30-2010, 12:04 AM   #32
hgs_notes
GEARHEAD
hgs_notes's Avatar
I just used an angle grinder with a thin cutting wheel on it. Cut through the side of the carriage bolt head where the weld is. Popped the bolt loose, then cleaned up the floor with a die grinder. If the floor gets bent up a little when tapping the bolt out, just pound it back down with a hammer. If you don't have a die grinder, they are one of the cheapest air tools to get and come in handy. Same with the angle grinder.
Old 10-30-2010, 10:02 AM   #33
mcmlxix
mcmlxix's Avatar
Ok... I have a die grinder but I didn't have any cut off wheels... I picked up some 3" wheels and a shaft/aug ... The problem I'm having is even the small 3" wheel doesn't fit into the recess for the two bolts in the driver and passenger footwells.... I ended up drilling out the others and using a punch. I will probably go the same route with the last two... but they are a larger diameter...
Rich
Old 10-30-2010, 03:09 PM   #34
71jimmy
71jimmy's Avatar
I have used my dremel tool with a cutoff wheel or grinder bit with excellent results. It's slower but being able to get into the hard to reach areas without causing damage to surrounding areas is priceless.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-30-2010, 03:15 PM   #35
71jimmy
71jimmy's Avatar
A related question: Is it necessary to weld the new/replacement bolts back in?????????
Old 10-30-2010, 05:41 PM   #36
hgs_notes
GEARHEAD
hgs_notes's Avatar
No
The front floor mount bolts were not welded in mine. Just the bed floor bolts. I think the dremel would be the best bet, or a die grinder with a pointed bit. Or just put the impact wrench on and break 'em loose.
FYI, On my kit for poly mounts, they assumed the front mount bolts were 1/2" but they are actually 9/16" and I had to use different washers than were included in the kit.
Old 11-01-2010, 06:46 AM   #37
vtblazer
vtblazer's Avatar
I've had really good results using 2" RoLoc pads on the 90 degree air tool.
Takes a little longer but you don't end up with the slices in the tub that you do with a cutting wheel/grinder approach.
Old 10-26-2012, 03:39 PM   #38
Vendetta
Vendetta's Avatar
Old post still giving. Love this site. Thanks.
Vendetta is offline   Reply With Quote
Old 10-29-2012, 05:36 AM   #39
chuckmc8
It's alsways something.....
chuckmc8's Avatar
great info here- thanks for posting
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 12-14-2013, 07:14 PM   #40
Rem701
I am in the middle of changing all of the body mounts on my Jimmy, thanks to the is thread, I was able to do all of the ones on the drivers side with the exception of the first position one (under the gas pedal). I got it removed relatively easy but the problem is when I put the new one in and try and put the bolt in there is an alignment issue. Does anybody have any suggestions?
Rem701 is offline   Reply With Quote
Old 12-27-2013, 08:15 PM   #41
7D2N
7D2N's Avatar
When I changed mine a few years back, I did one side at a time and lifted body just enough to get the body bushing in and went quite well. I did not tighten any of the mounts on that side untill all bolts were in. Do you have a metal drift or log awl to push up through and help aline the bushing? maybe start from the front and work to the back.
7D2N
7D2N is offline   Reply With Quote
Old 01-12-2016, 11:25 AM   #42
jakesblazer
Hey guys. Im restoring my 72 blazer 2WD. The body mounts available all say they are for a 4WD! are people buying these for there 2WD trucks? If so, how do they work out for ya??
jakesblazer is offline   Reply With Quote
Old 01-13-2016, 12:19 AM   #43
smbrouss70
smbrouss70's Avatar
I bought mine from Early Classic years ago, but they had the same part numbers as the LMC catalog, and worked just fine for me. They looked just like the stock ones that came out, but they weren't compressed and deteriorated.
Looking at the LMC catalog, they only list one set for each body mount position regardless of whether it is 4x4 or 2wd. It looks like the only difference is in the radiator support lower cushions and only for 71-72, probably has something to do with the fact that the front leaf spring mounts right under the cushion, but I'm not sure why 71-72 is different from 69-70. But they do offer the complete kit for a 2wd there.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=19
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-14-2016, 02:30 PM   #44
HARDCORECASH
Anyone have a pic of the rear 2 mounts installed?? My floor cross support hits the frame before the mounts do.....Thanks for the help.
HARDCORECASH is offline   Reply With Quote
Old 01-14-2016, 02:41 PM   #45
smbrouss70
smbrouss70's Avatar
Sounds like you have a 72 frame with a 69-71 body. The 72 bodies have a notch for the frame horns to clear.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-14-2016, 02:56 PM   #46
HARDCORECASH
That would explain it. The frame is a 1972 2wd and I have no idea what year the tub is. Would anyone have a picture of this notch. Otherwise I will probably just trim it out until the mounts touch properly. Thanks!!
Old 01-14-2016, 11:53 PM   #47
ls1nova71
ls1nova71's Avatar
You can see them in this pic.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-15-2016, 12:47 AM   #48
HARDCORECASH
Perfect!!! Thanks for the help!!!
Old 01-15-2016, 12:13 PM   #49
jakesblazer
Good call on lmc. Thank you I see now!
Old 01-19-2018, 02:42 PM   #50
mister.freeze
mister.freeze's Avatar
Assuming all went well, how long shouldnit take to do all the mounts on a 72 K5? I got a smokin’ deal (Energy Suspension kit for $26 on Amazon) but no bolts. Also, are poly’s really a different thickness than rubber? If so, what bolts do a poly kit need? Thanks all!
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
