Old 09-16-2009, 10:25 AM   #1
vtblazer
vtblazer's Avatar
Blazer Body Mount Bolt Measurements
Not exactly hi-tech imagery but I had em out and it's always asked, so here ya go.
vtblazer is offline   Reply With Quote
Old 09-16-2009, 10:26 AM   #2
vtblazer
vtblazer's Avatar
Re: Blazer Body Mount Bolt Measurements
...and position 5
Old 09-16-2009, 11:00 AM   #3
drunkbus
New Member
drunkbus's Avatar
Just a heads up for anyone replacing their mounts with poly instead of rubber. I just did this and only a few of the stock length bolts worked. The poly mounts will require longer than stock bolts in almost every position. I think I was able to only use 2 or 4 stock length bolts, I can't remember for sure.
drunkbus is offline   Reply With Quote
Old 09-16-2009, 11:15 AM   #4
vtblazer
vtblazer's Avatar
That's interesting...every poly set I've ever seen had 'thinner' bushings.
Thanks for posting up what you've run into.
Old 09-16-2009, 11:23 AM   #5
vtblazer
vtblazer's Avatar
Remaining parts to each position aside from the rubber body mounts.
Old 09-16-2009, 11:24 AM   #6
vtblazer
vtblazer's Avatar
...and position 5.
Old 09-16-2009, 11:52 AM   #7
lks dcvn
lks dcvn's Avatar
where did you get the kit from?
EDIT - After Googling the PN#s looks like the LMC numbers...
lks dcvn is offline   Reply With Quote
Old 09-16-2009, 11:56 AM   #8
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Thanks! good info that always seems to be overlooked..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-16-2009, 12:15 PM   #9
vtblazer
vtblazer's Avatar
Nope, I never shop @ LMC.
Bought my two sets from the board vendor Tim Christian of 'Christians Classics'.
http://www.christiansclassics.com/default.htm
Old 09-16-2009, 04:24 PM   #10
71jimmy
71jimmy's Avatar
Great stuff VT.
Moderators please post to FAQ section.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-16-2009, 05:20 PM   #11
vtblazer
vtblazer's Avatar
The set I got from Tim is what I would consider to be "complete".
There are other vendors out there selling...lets just say "not so complete" sets.
Talked with another blazer guy who just received one of those 'other' sets and it was missing these items:
* the square washers for the core support
* the 7/16 core support bolts
* ALL 4 concentric washers
* and both position #2 bolts were M.I.A.
At a premium price too.
Old 09-16-2009, 05:37 PM   #12
lks dcvn
lks dcvn's Avatar
What does the kit from Tim cost - I checked his site - but couldn't locate it in the product listings.
Thx for posting this (BTW) -
Old 09-16-2009, 05:41 PM   #13
Burt4x4
Burt4x4's Avatar
You're making it too easy for rookies
We had to bleed,sweat & cry to get that far ahead in replacing them. I probly made 5 different trips to the bolt store to do mine hahaha
Just messin ~ Good for the community
When are you gonna ship me your tube doors? Not being a "harcore" wheeler anymore you don't need um
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-16-2009, 06:01 PM   #14
vtblazer
vtblazer's Avatar
I can't remember what I paid Tim, it was over 6 months ago and I'm sure prices have gone up.
The incomplete kit in the pic was over $200.00 though.
Yeah, newbs have it to easy now for sure and still they don't bother to look anything up.
Sorry bud, tube doors went with the blue blazer.
Want me to build a pair for ya?
Old 11-24-2009, 07:48 AM   #15
vtblazer
vtblazer's Avatar
Bump incase some missed this and are wondering.
Old 11-24-2009, 09:00 AM   #16
Critter
Future TOTM Winner
Critter's Avatar
I'm wondering why it isn't in the FAQ section? Glad you brought this back ttt.
I replaced mine a couple years ago with a poly kit but I didn't get the concentric washers. Did I screw up? Why does it need the concentric washers? I have everything pretty torn apart at the moment, should I add them?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-24-2009, 09:13 AM   #17
vtblazer
vtblazer's Avatar
They say a picture is worth a thousand words.
Old 11-24-2009, 09:47 AM   #18
zammer
Addicted user
zammer's Avatar
Thanks for the great info!
Now... is the body mount kit the same for the 2wd and the 4x4 blazers??
I am having trouble finding a kit that says it is compatible with the 2wd blazer..
thanks
zammer is offline   Reply With Quote
Old 11-24-2009, 09:50 AM   #19
vtblazer
vtblazer's Avatar
thanks
Yes, I'm sure they are.
Old 11-24-2009, 10:34 AM   #20
Critter
Future TOTM Winner
Critter's Avatar
So the answer is "Yes, I should get them" looks like it keeps the body from shifting from side to side. Thanks Kurt, as usual you have made me realize that I need something that I didn't even know existed.
Old 11-24-2009, 10:38 AM   #21
vtblazer
vtblazer's Avatar
...well I'll take that as a 'good' thing.
The factory didn't use the washers but it seems like a good idea, can't hurt.
Old 11-24-2009, 11:17 AM   #22
lks dcvn
lks dcvn's Avatar
It (offset washer) basically acts to lock the carriage bolt to the floor so you can tighten them down without welding the head to the bed.
Old 02-06-2010, 12:12 PM   #23
k5keith
VT what grade are those 3/8 bolts ?
k5keith is offline   Reply With Quote
Old 02-06-2010, 12:29 PM   #24
vtblazer
vtblazer's Avatar
Silver grade...
Old 02-06-2010, 03:19 PM   #25
Rochlow
Great reference!!! Funny, that I found this not even 10 minutes after I order my set from LMC???
Rochlow is offline   Reply With Quote
