Old 09-25-2009, 04:15 PM   #26
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: exhaust on a slammed c-10
kool
but this half of the site thinks
DUMPS ARE KOOL
lol
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-25-2009, 06:45 PM   #27
jamis
F.A.S.T. president
jamis's Avatar
Originally Posted by lo72 View Post
Jamis, what type of headers are you running?
Originally Posted by VA72C10 View Post
What headers? Have you run it to see how loud it is?
I think they're hedman, I bought them a couple of years ago and now I cant remember the brand LOL
That was before I put the mufflers on. It wanst load but it would rattle like a fart can import when you decelerate.
In this pic you can see where the mufflers are now
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 09-25-2009, 07:40 PM   #28
Hottrucks
Hottrucks's Avatar
nice sneakers could you pm me some info on what they are??
Old 09-25-2009, 11:55 PM   #29
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I run mine from stock manifolds below the clutch linkage, above the tranny x member straight back to the trailing arm x member. There are two holes with pipe lining them in for support. From there it goes into two glasspacks angled up and then a u turn above the frame rail and under the bed to dump right in front of the rear tire. It doesn't drone like under cab dumps and is very livable. There's about 2 inches of clearance between the pipe and the bed floor.
It was really fun to make... 8 hours on my back welding the mandrel pipe around everything. but it works and sounds great, far enough back to be better than dumps and is entirely above the frame.
(note: not at full lay-out)
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
Last edited by lowrollin70gmc; 09-25-2009 at 11:57 PM. Reason: spelling for marines
lowrollin70gmc is offline   Reply With Quote
Old 09-26-2009, 12:44 AM   #30
VA72C10
VA72C10
VA72C10's Avatar
Looks good man...nice truck.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-02-2009, 10:09 PM   #31
weekendracer728
weekendracer728's Avatar
ttt
weekendracer728 is offline   Reply With Quote
Old 02-17-2011, 03:20 AM   #32
weekendracer728
ttt
Old 02-17-2011, 11:17 PM   #33
shortbed70
shortbed70's Avatar
Well mines not laying frame. I run camaro LT'sand my exhaust isnt done but heres my plan..
Flex joint off headers into x-pipe,then through the trailing arm x-member then turn through frame then turn back into mufflers then out the back following the frame. I also have nothing hanging below the frame so that way I dont have to worry about scrapping the ground.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-18-2011, 02:56 PM   #34
jasonroman
jasonroman's Avatar
ok. so i have an 85 longbed. when i picked truck up i needed exhaust done.
took it to a guy who messed truck up pretty good. long story. anyhow eventually he got it finished. put on new piping from manifolds back. cat, muffler, and 2 exit pipes.
now last week i took truck to a guy to do the spindles for me. and when he started flip kit and shackles, he decided it necessary to cut off piping on passenger side. right at muffler.
so now i have a muffler with two exit holes, 1 length of pipe running on the driver side that exits behind rear wheel. and an open hole at muffler.
thought about asking another muffler man to maybe cut the existing pipe and put 2 turndowns at end of muffler. ?? bad thought? that the dumping your talking about?? will it be stupid loud???
am i eating gas by having open hole now?
dont have cash to redo exhaust right now.
thanks for any opinions
jasonroman is offline   Reply With Quote
Old 02-18-2011, 04:09 PM   #35
weekendracer728
If he had to cut the exit pipe to do a flip kit than he should put it back on.
Old 02-18-2011, 06:15 PM   #36
jasonroman
jasonroman's Avatar
yea, well. guess his reason was the way it was routed, the axle would be in the way.
and then seeing the way he hacked up the bed supports for shackles.
and the fact that he didnt install rear shocks because he said they didnt fit...which turned out into me taking the rear shocks he put in the front...
and putting them where they go, then putting in the front shocks. and then re doing flip kit...etc.
so no, truck wont be going back there.
Old 02-18-2011, 08:32 PM   #37
SBTork
Garage wrench
SBTork's Avatar
anyone with a low suburban running exhaust out the rear? I ask because I have a dump on mine before the rear axle now and the interior drone is a little bit too much for me at highway speeds. It should not be a problem to have it re-done to exit the body but there is not a lot of room between the axle and the body, and it also has the big 40 gallon fuel tank to not much room around that either. I am just curious to see what's been done.....
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-03-2011, 11:44 PM   #38
bigblock68
bigblock68's Avatar
i had a little room so my exhaust guy tucked the tips out in front of the rear tires,a little different than everyone else,it kinda grew on me.i had no room to go further back because of c-notch.rear end and body is close to rear aired out....anyway i think this looks pretty cool.
bigblock68 is offline   Reply With Quote
Old 04-03-2011, 11:47 PM   #39
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Before I did the rebuild that how I had it on my 78 as well.^
Looks good.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-04-2011, 08:28 PM   #40
72gmcshorty
72gmcshorty's Avatar
hey bigblock68, do you have a pic from underneath showing the exhaust?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
