Old 09-23-2009, 10:08 PM   #1
weekendracer728
weekendracer728's Avatar
exhaust on a slammed c-10
what are you guys doing for a exhaust on a truck that lays frame?? Do just run it out before the axle?? search button does not work for me???
weekendracer728 is offline   Reply With Quote
Old 09-23-2009, 10:33 PM   #2
SCOTI
SCOTI's Avatar
Re: exhaust on a slammed c-10
Make sure you're using the 'grey default' screen that you can choose on your user control panel for the best functionality w/searches.
Many guys opt for 3/4 length car headers (Camaro/Chevelle) or manifolds to keep the exhaust above the lower frame rail lip. How far back it's ran is very subjective. Some guys (esp younger ones) love the loud/dumped exhaust so it's much easier for them. Others that want a less harsh, full length system can either snake the pipes all the way back or route them outside the frame rails. The amount of patience you have (or the size of your checkbook) are a big factor in determining which is best.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-23-2009, 10:50 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I agree witht he short headers or even stock rams heads maifolds then run along side the tranny and over the trans X memeber what to do next is still puzzlng to me but it seems some guys have cut a hole in the frame welded in a piece of pipe then got it outside the frame rail before the trailing arms....I have long tubes and mine goes under the X memeber so I drag my exhaust when I dump with cupped LCA and a 2 " c nocth
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-24-2009, 09:12 AM   #4
weekendracer728
Thanks for the help. That is all done the road. I am doing rust repair now on the cab and want it back together before the snow flys so I can drive it a little...
Old 09-24-2009, 11:04 AM   #5
nastyc10
nastyc10's Avatar
I'm running sanderson shorty headers with my pipes up between the frame rails and dumped before the rear axle.
nastyc10 is offline   Reply With Quote
Old 09-24-2009, 12:10 PM   #6
dznucks
dznucks's Avatar
I am curious as to what has been done also. any body got any pics?
dznucks is offline   Reply With Quote
Old 09-24-2009, 04:31 PM   #7
The Big Green
I ran mine from manifolds and they are turned down just shy of the back of the cab. It's loud, but the 8 valves are by the back of the cab, so I couldn't get it back any farther.
The Big Green is offline   Reply With Quote
Old 09-24-2009, 05:02 PM   #8
jamis
F.A.S.T. president
jamis's Avatar
I ran shorties inside the rails thru the crossmember and dump in front of the diff. Nothing hangs below the frame rails.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 09-24-2009, 06:12 PM   #9
Hottrucks
Hottrucks's Avatar
ummm JAMIS..ummmm wheres the mufflers???
Old 09-24-2009, 06:42 PM   #10
SCOTI
SCOTI's Avatar
My 3" mandrel exhaust was run like Jamis's. I still had to determine the final configuration on ride height & suspension parts so that's where it stopped. I will be routing it all the way back to the rear bumper.... no dumps for me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-24-2009, 06:55 PM   #11
Hottrucks
Hottrucks's Avatar
I don't like dumps either but I can't see how to get over the axle betwem the pumpkin and a watts link I dont see the room below the bed...maybe I need to put stacks on it?? truth be told I have been thinking a set of retro side pipes but they need to be long enough to look right???
Old 09-24-2009, 08:17 PM   #12
lo72
Truck Junkie
lo72's Avatar
Jamis, what type of headers are you running?
lo72 is offline   Reply With Quote
Old 09-24-2009, 08:55 PM   #13
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Here's mine... all stainless, and all the way to the back.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-24-2009, 10:43 PM   #14
andrewmp6
Looks great why not a x or h pipe in there?I have seen oval exhaust piping now which would work good on something lowered and need a big pipe.
andrewmp6 is offline   Reply With Quote
Old 09-24-2009, 11:42 PM   #15
Tagg33
Tagg33's Avatar
smashingchuck, I really like your square exhaust tips exiting there. Mine go close to that spot, just to either side of the plate box. Mine are tucked up out of sight and turn down at the roll pan, stealth.
A Watt's Link would be hard to get around. My notch and exhaust pic is probably not going to help but here it is. My challege will be routing the exhaust around the corvette IRS, when I get to it.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 09-25-2009, 12:54 AM   #16
VA72C10
VA72C10
VA72C10's Avatar
What headers? Have you run it to see how loud it is?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-25-2009, 10:21 AM   #17
smashingchuck
Honesty I don't see the need for a h pipe. I was happy enough just to get everything to jive as it is, plus it would be pretty tricky with the amount of driveshaft travel. I've got 2.5" pipe, but if you wanted it I don't see why 3" wouldn't clear just fine.
You could sneak one side under the tail shaft of the trans so they both go over the axle on the same side (obviously the side that has the link bar low on the axle). With the IRS, I've seen people go directly under the pig with a 1-piece rectangular pipe.
I plan to weld in a piece on the bottom side of the rear bumper so the tips are "framed", then send it out to get re chromed.
78 Build Thread
4Runner Build
Old 09-25-2009, 11:35 AM   #18
Hottrucks
Hottrucks's Avatar
Hey nasty do you think with the shorties you could get outside the frame rail before it flattens out under the cab ( behind the front suspention)??? my thoughts started out thinking side pipes and trying to get it out as close the bottom of the front fender as I could to get rid of all the snaking around then I was thinking why not tuck it under the cab between the frame and rocker and dumping out the side of the bed?? I have a few Ideas for that too...just looking for a newer Idea thats all
ok just looking at my truck maybe a set of sprint car headers or roadster since I have no inner wheel wells it would be easy...hmmmmmmmm what ever happen to the old wheel well headers that you see on some gassers???hmmmmm
Old 09-25-2009, 11:43 AM   #19
Ackattack
Ackattack's Avatar
I'll have an genIII engine in mine and the long tube headers I'm using are pretty much within the frame rails. I have an X-pipe in mine, so I couldn't get it through the trailing arm crossmember, so it runs underneath.
If I didn't have the X-pipe it would go through the trailing arm crossmember pretty easily. I'm not that low, so I wasn't too concerned about it. The exhaust dumps before the rear axle.
Ackattack is offline   Reply With Quote
Old 09-25-2009, 12:20 PM   #20
Hottrucks
Hottrucks's Avatar
heres a link to what I was thinking??
http://www.bigblockdart.com/techpages/Hustler.shtml
I think the collectors would need to be raised?? I would leave the flange and cut a hole in th side of the header to add a full exhaust ....but who wouldn't want a set of Dumps!!!!
Old 09-25-2009, 12:26 PM   #21
smashingchuck
Fenderwell headers? Seriously?
I think they would cause more problems than they would solve.
78 Build Thread
4Runner Build
Old 09-25-2009, 12:32 PM   #22
nastyc10
nastyc10's Avatar
there is no way you could get them outside the frame rail with out cutting a huge hole through the frame. My collectors are at the top of the frame rail and that is with my motor being raised a little because of my dropmember.
Old 09-25-2009, 02:42 PM   #23
SCOTI
SCOTI's Avatar
1/2 the guys on this site.
The 'side pipe' idea can work 'cause we've done a similar stealth system (we did my buddies old 65 that way). The exhaust was a set of 2.5" Ram Horns w/2.5" pipe that immediately 90 degreed to outside the framerails. He put his mufflers on the outside of the frame under the cab & routed the tips of the pipe out in front of the rear tires. Painted the pipe w/black VHT high temp engine paint to keep it less obvious.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-25-2009, 02:50 PM   #24
smashingchuck
I might as well be the first one to tell you to post some pics.
78 Build Thread
4Runner Build
Old 09-25-2009, 03:23 PM   #25
SCOTI
SCOTI's Avatar
If that's toward me, unfortunately I can't. This was back in the mid 90's & the truck met an early demise after an a-arm had an abrupt meeting w/a manhole cover that was exposed about 1.5" from the road surface. No.1 reason why I don't like dropped a-arms (he wouldn't listen to me & swap to discs & dropped spindles).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
