Old 10-28-2009, 10:45 PM   #26
terd ferguson
terd ferguson's Avatar
Re: My '63 is now officially up for sale...
Originally Posted by 1964C10 View Post
Thanks for the info! Where you able to use any of the existing holes for alignment?
Hope you sell it this weekend!
I went from a '63 grill on a '63 grill to a GMC grill to the '60 chevy grill. I "think" the GMC grill needed four new holes drilled and then after that, the '60 grill only needed two. Not sure how it'd be for a '64 to '60. But it's just four 1/2" holes at the most. It's about as easy as it gets.
If you have to drill all new holes, here's how I did it. I held the grill up in place with the aid of a helper. I centered it side to side and top to bottom still holding it in place. Then I used a shaprie and marked the top and bottom of the mounting brackets on top and bottom of each side. Then I measured how far the hole was from the edge of the mounting bracket and measured that distance below the lines I made and drilled holes. It sounds a lot more complicated than it really is.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 10-29-2009, 12:45 AM   #27
1964C10
1964C10's Avatar
Thanks! that does make perfect sense, I just wasnt sure and didn't want to go drill new holes when I didn't need to!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
