Old 11-10-2009, 08:48 PM   #26
tkeduk8r
tkeduk8r's Avatar
Re: dogs a$$ plus a bright sunny day = super score!!!
throttle knob holds the throttle open at a certain/desired RPM most often used to power PTO driven accessories (winch, hydraulic pump, etc.). Some guys use them as poor mans cruise control. Some guys (like me) with GOCD (gauge obsessive compulsive disorder) put them in there trucks because there is a hole stamped in to their dash and need to fill it with what was supposed to go there ....
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 11-10-2009, 09:11 PM   #27
SkullCandy
Nice finds.
Here's one that i found, doesn't have the tach though.
Originally Posted by 71swb4x4 View Post
Yes.
Mike, that is an amazing day at the yard. Great find!!
Edit: Don't forget that those 427's are tall decks, and not worth what car 427's are worth.
Originally Posted by Dieselwrencher View Post
But all tall decks, 366's & 427's, have 4 bolt mains, the main caps can be installed in short deck big blocks, and have steel cranks, which can be used in 396's and 427 standard deck blocks. Plus these blocks can be bored .120+ without having the over heating issues like the short deck blocks do.
Any links to info on these tall deck 427's.
1990 Dodge Ram D250 Cummins
SkullCandy is offline   Reply With Quote
Old 11-10-2009, 09:50 PM   #28
72 Super
72 Super's Avatar
Some guys have all the luck I mean scoring 3 tach dashes, not getting H1N1 virus lol
Hope you feel better soon.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 11-10-2009, 10:13 PM   #29
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sorry I don't have any links. I can tell you the easiest way to identify one is by the intake. The tall decks have 2 thermostats instead of one. Most of them have points dist. and you can use a HEI from a SBC or BBC. Just check to make sure it has the proper oiling groove on the dist. body. Also the early tall decks had semi closed chamber heads that can help raise the compression ratio on a standard closed chamber engine by almost a full point. I believe they had the heavy duty rods with 7/16 bolts as well. The biggest difference besides the block beeing taller is that the piston is longer and has 4 rings. The rods are the same as 396-454. Another thing, a lot of times the harmonic balancer has a cast 4 pulley center that isn't removable. Hope this helps.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
