#26 |
Re: making a short bed crew cab
never mind i got it tall deck
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
#27 |
The frame was shortened and welded by a pro welder, I can weld, but would rather have someone else do it. I don't even own a welder. I wish he did plate it on the inside, but that is easy to do later on. The welds have good penetration. This wasn't the first frame he shortened.
I dunno why those pics turned out so small. It will have the 4500, right now still has no motor/tranny. I have a 400 that I'm gonna use till I get the bugs worked out, still need to get the 3 year only flywheel for the 427, and clutch and throwout bearing yet too. Biggest thing that is holding me up now besides time is the engine crossmember. Need to figure something out...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 12-22-2009 at 09:19 AM. |
#28 |
Still plays with trucks
I believe it is a tall deck truck 427
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#29 |
gets board easy.......
well, i dont mean it will break right away, but anytime a frame is shotrened it needs to be strengthened on bothe sides,
I guess its not bad, but if you start wheeling with it and twisting the frame it may start cracking |
#30 | |
Add a 1/4"x2"+ strip of flat bar to the top & bottom flanges in the repair area and extend it about 6" each way past the repair and the repaired area will be stronger than the unmodified areas of the frame. Cover the welded area with a welders blanket and let it cool slowly and the repair will not be as brittle as if it cooled quickly in the air. Never hose off a frame repair weld with water. The metal will be excessively hard and lose much of its elasticity.
#31 |
I agree that those cuts/welds would make me nervous over time. But that is just me, I tend to overbuild everything to the point of overkill, hence the name of my SAS build..lol.
Should be sweet either way. |
