67 Chevy Stepside
making a short bed crew cab
ok guys. i have seen it done a few ways. i got a 4x4 1 ton dually crew cab. my goal is to have a short bed crew cab 4x4 whice is the best way to go. cut the frame i got or put a surban and pick up frame together and put it under it. would like for ya to tell me ya input
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
Jonny
Re: makeing a short bed crew cab
Personally I would, and hopefully some day will, use the shortening your current frame method. This way you will have the thicker, stronger frame. In doing so I suggest using the "tab and slot method rather than any other. To me it makes sense that this will be the strongest, but I have yet to see anyone's frame break.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
67 Chevy Stepside
tab and slot ?
Mine is done, will get some pics tomorrow!!!!!
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
I'm planning on shortening my one ton frame.....like sailed stated, it is a much stronger frame than the 1/2 ton frames.
here is an attachment to show what I think he was referring to. The dotted line is the cut/weld joint. The idea is the more weld you can put down on the cut when you weld it back together, the stronger the joint will be. First is just a straight vertical cut. Then you have a tongue and groove method, and last the diagonal. The vertical cut is not recommended, but many people have done it without problems. It is also recommeded to box the framerail or use a fishplate on the inside of the framerail along the joint.
Sorry for the small pics a huge white area, it was quick and done with paint
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() Last edited by dooce; 11-16-2009 at 07:17 AM. |
here is how I have seen it done, and the way I am planning to do it....
![]() ![]() Last edited by joe231; 11-16-2009 at 09:30 AM. |
Happy to be here
![]() Join Date: Mar 2000
There is a great article in the FAQ about this. Not a 1 ton frame but the theory still applies- LINK
Got mine back today, best I could get with a cell phone...
Can't really tell in the crappy pics, but the frame was notched then welded back together. Kinda wish he put the plate on the inside, but once it gets ground down and a coat of paint, won't look to bad hopefully. If it does then I'll change it.
looks isn't really what you should be going for when doing this. you want it to be structural. THAT is not. that will tear over time. even with it fish plated on the outside you don't have enough of the support spaced out. you will need to plate the inside and box the inside to make it as strong as possible.
i'm not saying cut it off and redo it just please plate the inside and box the frame. i would suggest the tab and slot method.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
It is notched, like the 3rd one joe231 had in his pic. I'm gonna make another plate to go on the inside of the frame....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS Last edited by b454rat; 11-16-2009 at 06:03 PM. |
#13 |
Luv the Crewcabs
I used the ojoe method & am quite pleased with the results..........
Here is a link to ojoe's Method.............. (http://67-72chevytrucks.com/vboard/s...d.php?t=218953 Couple Pics of Mine.............. Rick ![]() ![]()
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
#14 |
67 Chevy Stepside
thanks to all of ya
#15 |
Ridin' Dirty
would it be easier to just lop off extra frame length off the rear of the chassis, and then fab the spring hanger and box mounts? Or does the curve in the frame screw that up??
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#16 |
That is another way of doing it. The box sits on that high hump, but would still work, just be further ahead. The rear spring hanger might have to moved down, I'd think where they would need to be would be right in the hump in the frame.
#17 |
Still plays with trucks
Doing it this way you can shorten the wheel base and use a standard short bed box when you are done. What you propose would require cutting & shortening a bed to fit. It can be done either way but using a stock bed is the easiest.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#18 |
Ridin' Dirty
Why couldn't you use a stock short bed after chopping off the back of the frame? I wasn't really thinking about bodywork, but assuming that one would use a stock short bed. I was just wondering why guys shorten the frame instead of just buying a shorter box and moving the suspension forward on the frame and just cutting off any excess frame hanging off the back. thus keeping the integrity of the frame with no structural welding required.
#19 | |
I guess a C-notch could take the place of the slight hump the stock frame has over the rear axle. You would probably have to reinforce the rear spring hangers so they could be mounted at the right elevation to maintain pinion angle since they would now be 14" into the axle clearance hump. I think for the work involved it is easier to Z-notch the frame and leave the rear suspension alone.
#20 | |
Ridin' Dirty
#21 |
gets board easy.......
Re: making a short bed crew cab
B454rat, thats scarry,
That will BREAK |
#22 |
How is it gonna break?? It's cut and welded like the one that was in the above post.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS Last edited by b454rat; 12-21-2009 at 11:04 PM. |
#23 |
Nother shot.
#24 |
do you have any better shots? that pic is small
kinda looks like the reinforcement piece on the outside of the frame isn't over the weld, hard to tell in the pics. EDIT: never-mind...I see now. as long as the welds got good penetration, I don't think it will be a problem. I would probably plate the inside, But i have a tendency to go overboard ![]()
![]() ![]() Last edited by joe231; 12-22-2009 at 12:51 AM. |
#25 |
so b454rat that pickup has a nv4500 in it? and what does 427td mean
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
