Old 08-27-2010, 12:44 AM   #26
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: Is anyone running hydro boost?
Where did you get the lines I like the look of that
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 08-27-2010, 01:46 AM   #27
Captainfab
60-66 Nut
You can also mount the hydroboost unit upside down from the original position. This positions the hoses on the bottom for a little cleaner look. I have the hydroboost mounting plates, and '67-'72 specific brackets for those interested. The link is in my sig......
Old 08-27-2010, 08:03 AM   #28
6600DURAMAX
6600DURAMAX's Avatar
I ordered my lines on line, cant remember where though.
I would have mounted the hydroboost unit upside down if I would have known at the time. It definatley would have made a cleaner install!!
Very nice bracket !!!! Wish I would have known about those
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 08-27-2010, 12:00 PM   #29
SWB4x4
SWB4x4's Avatar
you read my friggin mind!
so the Booster bracket is what you are talking about? can you pm me a link for what I need to install hydroboost into my 72 mounting plates and specific brackets. TIA
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 08-28-2010, 01:46 AM   #30
Captainfab
60-66 Nut
PM sent
Old 08-30-2010, 03:20 PM   #31
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Like mentioned, they can be mounted upside down. That's what I had to do to get it to fit on the car.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-04-2010, 11:08 AM   #32
Wildstreak
Wildstreak's Avatar
What did you guys do about the power steering pump/pulleys. I took the hydro all out of the donor and took everything, but the pumps pulleys look bigger. Did you all just find another belt or?
57 chevy 4x4
68 burb 2wd:
Old 11-04-2010, 12:23 PM   #33
6600DURAMAX
I am running the stock size pulley from a non hydro boost set up. Mine is actually a MARCH setup.
Old 11-04-2010, 02:40 PM   #34
Wildstreak
Wildstreak's Avatar
Yea if I had more money and more time I would get the march brackets, they looks so nice. I need to get this on the go, old man winter is steadily approaching. Im just going to see if the old pulley will fit in the new reservoir/pump. What type of proportioning valve did you use 6600DURAMAX is it the stock model for our years?.
@yukonjack what type of adjustable proportioning valve did you get?
57 chevy 4x4
68 burb 2wd:
Old 11-04-2010, 02:44 PM   #35
Wildstreak
Wildstreak's Avatar
Does anyone know if the stock proportion valve will work with the hydro boost setup? or for that matter can our stock power steering pump/res be used with the hydro setup? The donor truck was a bbc and the brackets dont match either...
57 chevy 4x4
68 burb 2wd:
Old 11-05-2010, 11:59 PM   #36
6600DURAMAX
I used a disc/disc proportioning valve from Pirate Jack (part# PV4CK-2) with a line lock plumed into the front brakes. The master cylinder was also a disc/disc setup (part# MC2912ACHFT)
hope that helps out a little
Old 11-06-2010, 01:06 AM   #37
Wildstreak
Wildstreak's Avatar
Ive decided to save the hydro for another project so it gives me more time to acquire parts I need for it. Just too much of the unknown right now. The donor truck had a big block as well and the brackets look like theyd fit my 454 so I might try and use it with a bbc in my swb.
57 chevy 4x4
68 burb 2wd:
