Old 11-20-2009, 03:22 PM   #1
eric67m
eric67m's Avatar
Is anyone running hydro boost?
I was just learning a little bit about the hydroboost system. I was wondering if anybody is using it on their trucks, either factory installed or retrofitted. How do you like them. I understand they can be a little touchy, grabby. If you were to run it on a truck with 4 wheel disk brakes would you only need a proportioning valve on the rear wheels to stop them from locking up first (just like any brake system). I was thinking about doing this swap while everything is apart and I will be needing to change boosters as I am going from 1/2 ton all drums to 3/4 ton with all disks.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-20-2009, 06:26 PM   #2
rcbildr
rcbildr's Avatar
Re: Is anyone running hydro boost?
I have hydro boost on my diesel rigs..83 chevy shortbed and 85 chevy suburban. I like it a lot. I didn't notice any difference in stopping when I went to larger tires on my Suburban. The Burbs brakes are a little grabby until they warm up a bit and its really noticeable when its wet out. My only complaint is it's hard to keep the belt tension set right...it seems to get loose over time.
I like it so much my girlfriend and I are thinking about trying to retrofit it on my girlfriend's 54 chevy 1-ton dually project.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 11-20-2009, 08:14 PM   #3
eric67m
eric67m's Avatar
I see that there is a guy on craigslist that has a set up, master cylinder, booster, lines, rebuilt pump for $100. I dont know what they generally go for or what I could pick all of that up at a wrecking yard for. I just have basically no money in my parts fund until the end of the month. Im just thinking and just might go this way.
Hey, I see you are just up the road a way. I live above the old prision farm.
Old 11-20-2009, 11:35 PM   #4
ghettoluxury
ghettoluxury's Avatar
I have hydro-boost with 4 wheel discs on my 82 3/4 ton and didn't change the prop valve. Have not had a problem with the rear locking up. Let me tell you that this is an awsome setup and I would pay the 200 for a used hydro-boost agian.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-21-2009, 03:37 AM   #5
Dooley
Dooley's Avatar
I have had 1 or more trucks with hydroboost continually since 1977. Both gas and diesel powered. I think it is a great system. Never any problems with them.
Dooley is offline   Reply With Quote
Old 11-21-2009, 09:15 AM   #6
jgdually83
jgdually83's Avatar
hydroboost is awesome works great. i would take it over vacuum anyday
83 K30 3+3 Dually
83 K20
jgdually83 is offline   Reply With Quote
Old 11-21-2009, 11:05 AM   #7
2badgn
I have an 84 GMC 3500 2wd with Hydroboost and its great. In 25 years, I only had to change the MC once. Great stopping power but u have to ocassionally tighten the Power Steering belt.
Alot of older muscle cars and cars w/turbos convert to Hydroboost bc vacuum brakes cannot hold as much boost.
2badgn is offline   Reply With Quote
Old 11-21-2009, 05:19 PM   #8
thirdstreettito
Resident of Here
thirdstreettito's Avatar
My 84 K10 Diesel has hydro.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-24-2009, 07:32 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
My '86 Was a Diesel converted to gas and its got the hydro boost set up. I like it seems like it works pretty good no major issues yet. Might lift the truck a little and go like 33"s so I will see how it does then.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-25-2009, 09:46 PM   #10
Devil'S Ride
For a hundred bucks, get it and don't ever look back. I have the full system on my 83 and if I stand on the skids it WILL plant your forehead into the windshield, with 44's. Like mentioned above, I have to occassionally tighten the P/S belt, but for tires this big, I couldn't ask for more stopping power. very rarely I also tow my 20' camp trailer (1981, the old heavy kind) and I don't have electric brake controller, and I can run down the hills here with no problem, around town stopping is great.
I would highly recommend that you upgrade to the hydroboost if you are able!!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 11-27-2009, 12:02 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
I bought a 1989 1 ton and swapped in it's engine and hydroboost setup - I went from manual drums to hydroboosted drums and it is wonderful! Getting ready to swap in a Dana 60 so the disks up front are going to be a great improvement of course.
Here is a link to my website where I detail the install on my 69 K20.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-29-2009, 04:39 PM   #12
Matt Man
Matt Man's Avatar
i have hydro on my 86 dually and for a vehicle this size this thing stops very quickly never had a problem with it so far.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-30-2009, 01:17 AM   #13
Wildstreak
"something witty here"
Wildstreak's Avatar
I was just wondering this myself, whats a good aftermarket hydro boost to use. I thought about just getting one like a stock gm replacement, but what other companies offer good hydro boost setups?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 12-08-2009, 01:06 PM   #14
LANDC
LANDC's Avatar
I used one out of an astro van from pick and pull. Its a Vanco one, the same one used in the packaged deals you can buy. Let me tell you, I can put my 'Cruiser that is on 44's on its nose.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 12-08-2009, 05:12 PM   #15
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I also like the hydraboost over the vacuum systems. Especially when you are towing, or for a gas engine, get crazy and put a big cam in your ride.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-08-2009, 09:27 PM   #16
edge
edge's Avatar
i need to look into the Hydraboost for a K10, see what it takes to. the big tires and good stopping comments here are what i need around where i live! thanks.
edge is offline   Reply With Quote
Old 12-12-2009, 04:47 PM   #17
Firebirdjones
I run the hydroboost on 2 vehicles, one factory and the other was a retrofit.
My 79 1 ton cam with it originally and it has worked flawless since new.
My chevelle has too much cam to support a vacuum system so I converted that to hydroboost.
I can't remember if I bought that from Master Power Brakes, or Muscle Car Brakes. But those are 2 places you could look around for a retrofit system.
Never had any power steering belt issues as mentioned in some posts above.
Firebirdjones is offline   Reply With Quote
Old 12-19-2009, 07:51 PM   #18
msgross
msgross's Avatar
Musclerodz put one in the 68 K-20 that he just built... use the search feature and you can find the thread on it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-03-2010, 10:38 PM   #19
Wildstreak
Wildstreak's Avatar
I tried searching but couldn't find that thread.
I have a hydroboost setup on an old 80's truck sitting that I wanna steal. I was just trying to figure out the installation process.
57 chevy 4x4
68 burb 2wd:
Old 01-03-2010, 11:41 PM   #20
Wildstreak
Wildstreak's Avatar
found it
57 chevy 4x4
68 burb 2wd:
Old 08-19-2010, 01:24 AM   #21
240 Jordy
240 Jordy's Avatar
Originally Posted by Wildstreak View Post
found it
Share it?
please! . . . LOL!
240 Jordy is offline   Reply With Quote
Old 08-19-2010, 10:58 PM   #22
Wildstreak
Wildstreak's Avatar
If you go up a few posts Yukon Jack has a link to a great write up with pictures(which is great for me because Im a very visual person)
Yukon you said in that previous post that you you ran the hydro boost on drums. I have a 67-68 4x4 with the drum front and rear, I was wondering how that worked, dont you need a different m/c or is it different for hydro?
57 chevy 4x4
68 burb 2wd:
Old 08-20-2010, 11:32 PM   #23
Yukon Jack
Post Whore
Yukon Jack's Avatar
I didn't use a proportioning valve and it worked just fine with drums all around. I recently swapped in a Dana 60 up front which got me disks. I added an adjustable proportioning valve and really dig the stopping power I have now.
Old 08-26-2010, 05:55 PM   #24
6600DURAMAX
6600DURAMAX's Avatar
Here are a couple pics of my setup. I pieced mine together online using piratejack.com for the m/c and prop. valve and it is a ebay hydroboost unit. I needed it because of my cam size and I could never get the vacumn canister to work correctly
Would have been pretty cheap if for not the hoses
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 08-26-2010, 07:08 PM   #25
Dieselwrencher
Nice set up! I even installed GM truck hydraboost on my corvette.
Ryan
