#26 |
bbadfred
![]() Join Date: Mar 2008
Re: 6.0 LS questions
I bought my LQ9 on Ebay for 2600 dollars with 44k on it from Scottys auto parts in Virginia Illinois. They are about 1.5 hr from my house and I had had done buisness with them in the past. They are long time dismantlers Honest to a fault!!!. I got the trans still bolted to it for 500 extra its a 4L65. I got the motor all brackets, engine covers, airbox with filter , injector to box tube and maf sensor, power steering pump and lines, all belt drive and belt, ac compressor, wiring harness, pcm, tac sensor & pedal, exhaust pipes with 4 o2 sensors and convertors, radiator hoses, heater hoses and water resevoir cap and hoses, oil cooler, fuel tank with hoses ,cap and pump. The transmission came with cooler lines and shifter cable. Nothing was cut and I got all clamps,bolts and nuts!!!
#27 | |
On the path to financial ruin!
![]() Join Date: Jan 2009
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
#28 |
bbadfred
I know I even had the chance to go drive the truck around the yard before it was stripped. It had been Tboned on the passenger side but still ran and drove. Just pulled pretty hard to the right!! LOL
#29 |
What did the motor come out of?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
#30 |
the LQ9 only came out on the escalade, and silverado SS...
the LQ4 came out on all 2500HD trucks, yukon denali, they are both 6.0's the only difference is the piston, the LQ9 is a flat top piston = more CR. and the LQ4 is a dished piston with a little less CR... but they BOTH work good, I have a LQ4 in my ext. cab with cam only (no head work) and runs good for what it is... one very important thing about these motors... make sure you have a real good tuner to tune your truck... you wont believe the difference that it makes....
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! Last edited by ap2002; 12-07-2009 at 12:55 PM. |
#31 |
bbadfred
silverado
#32 |
bbadfred
In 2004 it was available in extended cab and 4 door Silverado in either two wheel drive or 4 wheel drive mine was in an extended cab 2wd. it was called vortec high output VHO
#33 |
bbadfred
heres the article http://en.wikipedia.org/wiki/Chevrolet_Silverado
#34 |
GM ONLY BABY!!!
Subscribing, LQ4 on the way for my 72 GMC.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#35 |
Truck and auto performance nut
Lots of LS builds these days. Doing a carb'd genIV 6.0L (has L92/LS3 style heads).
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#36 |
I decided to ditch my big block and bought an 6.2L/4l80 set up. Ill start a thread once Im "done" with the big block
#37 |
If your looking for the possible best ls manifold it would be the newer lsx rt truck manifold im pretty sure it out flows all the others but thats because its of huge design although it loses a little torque down low but gains it up high some consider it not worth it for a grand but if you don't have much room its useless because its quite massive, as said the gto had 2 motors the ls1 in 04 and 05-06 the ls2 both all aluminum the ls2 having the worst flowing of the ls manifolds according to ls2gto people and the 5.7 can be bored to a maximum of i think... 3.9 something but can't make the 4.00 bore of the 6.0 but a 5.3 can become a 5.7
and some random lq4/lq9 info.... In 2003, the LQ4 was modified for installation in the new Express and Savana vans. The LQ4 for vans is essentially the same as the variant installed in Chevrolet Silverado and GMC Sierra pickups, with two packaging adjustments: The oil pan on the LQ4 was modified with a slight scallop in its sump to allow clearance over the van’s front suspension. In developing the new pan, engineers learned that the design further stiffened engine structure and reduced the oil pan’s natural tendency to magnify mechanical noise generated by the engine. With that information, and the desire to make common as many parts as possible, GM extended use of the Express/Savana oil pan to all Gen III Vortec V8 applications. The 6.0L LQ9 is a more powerful evolution of the LQ4, developed for Cadillac's luxury sport utility vehicles. It features increased power output achieved primarily through the use of LQ9-specific: flat-top pistons, rods, crank, and beefier pushrods that increase the compression ratio from 9.4:1 (for the LQ4) to 10.0:1. The block and heads are common with the LQ4. Originally referred to as the “Vortec H.O. 6000”, in 2006 the LQ9 was renamed the “Vortec MAX” to underscore its being the most powerful light duty V8 in GM’s truck line at that time. The 2006+ engine “vanity” cover displays new “Vortec MAX” badging.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB Last edited by Mr. 250r; 02-04-2012 at 06:00 AM. |
#38 |
I got an 06 savanna 6.0 for my shortbed, and was pleased to learn the 05 and newer engines have better/stronger rods than the previous years. Good info to know when building a turbo motor
