#26 | |
406 Powered
Re: Most Annoying Oil Leak EVER
70 GMC 68 c10 2002 silverado 72 4x4 |
#27 |
Cluster King
![]() Join Date: Nov 2012
OK, way to much going on here for a simple problem.
Order a new dip stick tube and insert it in the block. It is a press fit and will require some work to get in the hole in the block. I have used a 7/16 boxed end wrench to slide over the tube to give me something to pound against. If the tube does not fit very snug, it will most likely leak. I could not even imagine the hole in the block is wore enough to cause this. |
#28 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#29 |
Cluster King
Wow, I did not even look at the original post date.
#30 | ||
For some reason... he keeps dredging up old threads from eons ago. Not sure why.
![]() Gary
#31 |
GASoline71, are you referring to me? If so I didn't realize there is an expiration date to an issue people have had or might still have. Besides threads were supposed to be "closed" otherwise they are open for comment. If you were talking about me I understand the replacement tube solution, my question is how do remove an insert that is stuck in the tube bore in the block from a cheap dipstick tube?
