Old 12-12-2009, 08:40 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Most Annoying Oil Leak EVER
I am leaking oil from the oil dipstick tube, where it plugs into the block.
I've tried some of the rtv ultra black to seal it up, but it's not working. I can just reach down and pull it right out of the block like it's barely in there.
In fact, when I pull on the dipstick to check the oil, it pulls the tube out of the block.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 12-12-2009, 08:53 PM   #2
Mt Man Chad
Mt Man Chad's Avatar
Re: Most Annoying Oil Leak EVER
Pull it out, clean block and tube with brake clean and use JB weld.
Always works!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 12-12-2009, 08:55 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Take the dipstick and dent it a little with some vice grips. Clean it and the hole in the block with some laquer thinner. Try a Q-tip for the hole in the block. Put some RTV on it and stick it back in. Edit: We posted at the same time.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-12-2009, 10:57 PM   #4
big_al_71
big_al_71's Avatar
Buy your self a quality dipstick like the one from lokart and your problems will end.
I have gone thru stock dipsticks and the chrome from mr gasket then I switched to the lokar and it never happened again..
http://www.lokar.com/
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-27-2013, 04:57 PM   #5
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
This ^^^^^
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 05-27-2013, 05:05 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
OK, way to much going on here for a simple problem.
Order a new dip stick tube and insert it in the block. It is a press fit and will require some work to get in the hole in the block. I have used a 7/16 boxed end wrench to slide over the tube to give me something to pound against. If the tube does not fit very snug, it will most likely leak.
I could not even imagine the hole in the block is wore enough to cause this.
TBONE1964 is offline   Reply With Quote
Old 12-13-2009, 05:24 AM   #7
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Funny how such a little thing can be such a pain.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-13-2009, 06:44 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
there's something to be said about a new tube from the dealer combined with a good cleaning.
68C15 is offline   Reply With Quote
Old 12-13-2009, 10:24 AM   #9
toddtheodd
toddtheodd's Avatar
It is a dealer tube. My original tube had broken off many years ago, and when I bought the cheap chrome one it wouldn't fit in the block... at all.
So I went to the dealership and bought this one.
Then, I rebuilt / overhauled the motor, and when I put it back together, the tube wasn't as hard to put in this time...
IIOY???
Old 12-13-2009, 09:26 PM   #10
hayhauler71
hayhauler71's Avatar
I have taken the dipstick tube out and grabbed a craftsman 1/4 drive socket that is usually tapered and put in the tube and a few raps on the socket with a hammer you can make it larger to give it a snug fit.
hayhauler71 is offline   Reply With Quote
Old 02-01-2011, 03:08 AM   #11
CEE1NG_RED
uPDATE?
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 02-01-2011, 06:30 AM   #12
Luvlegs
Luvlegs's Avatar
had to read that 3 times - kept wondering why you make the hole bigger! Stretch the TUBE.... got it.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-01-2011, 09:31 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
shouldn't a dealer (stock replacement) tube have a tab to bolt it to the engine?
Old 02-01-2011, 10:23 AM   #14
'70_402
'70_402's Avatar
yes mine (i'm assuming it's stock) has a tab that matches up with a header bolt and it holds it in place..
'70_402 is offline   Reply With Quote
Old 02-01-2011, 11:26 AM   #15
tooter
tooter's Avatar
Big blocks do, small blocks don't in pre 85 motors (driver side)
tooter is offline   Reply With Quote
Old 02-01-2011, 11:37 AM   #16
'70_402
'70_402's Avatar
Well they should.. it's a great idea... lol.
Old 02-01-2011, 09:53 AM   #17
63chevyll
gets board easy.......
63chevyll's Avatar
They don't bolt in, press fit only
63chevyll is offline   Reply With Quote
Old 02-01-2011, 11:38 AM   #18
allengator
allengator's Avatar
when you had your block rebuilt they probably went .010 over on the dipsick... you need a .010 over tube!!!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 02-01-2011, 06:39 PM   #19
63chevyll
63chevyll's Avatar
haha, thats good
Old 02-09-2011, 11:44 AM   #20
CEE1NG_RED
...any updates?
Old 02-09-2011, 12:10 PM   #21
Dave
DND Trucks
Smile Re: Most Annoying Oil Leak EVER
Just curious, what year is the engine? Stock or later model (85 and up)
Dave is offline   Reply With Quote
Old 02-01-2011, 11:49 AM   #22
406 Q-ship
406 Q-ship's Avatar
Before 1981 the dipstick tube is on the left side of the engine and only presses in. Get a brand new tube and do NOT sand on it at all, clean the hole in the block, and press it in. Use a 1/4 wrench or crowsfoot to tap it down into the block. Should not need any sealant (GM never used any on them) but if it makes you feel better a very small amount on where it fits in the block. Forget using those chrome POS, only the plain steel GM ones.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 02-01-2011, 01:49 PM   #23
BearFlagRepublic
I agree with that, I fought with trying to get mine to seal for the longest time until I realized that it would never seal properly as it was a chrome POS that the PO tried to put in there. It would leak oil like a sieve.
BearFlagRepublic is offline   Reply With Quote
Old 02-01-2011, 01:21 PM   #24
Longhorn Man
cool. It's been a long time since I had a small block and it was a newer one at that.
Old 02-09-2011, 12:16 PM   #25
cam.man67
cam.man67's Avatar
Here's a question, then. Mine has two dipstick holes, one on each side of the engine. The one on the left is longer and has the dipstick in it, but the right one goes into the engine as well. It is blocked off, but I'm not sure why the engine even has it?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
