04-09-2013, 09:39 PM | #26 |
Re: Rubber or urethane trailing arm bushings?
Awesome! Thanks for the detailed instructions (now I see the links up top... like I said I'm dumb). I can tell you that chiseling w/ an air chisel does not work
It always comes down to that one stupid bolt... |
04-10-2013, 12:40 AM | #27 |
Yeah, the burn em out method stinks! Literally! I'm going to have to try the drill and pry method.
Thanks for the information on the pros and cons of rubber and poly, I'm going with poly, though.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
04-10-2013, 02:16 AM | #28 | |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-10-2013, 07:42 AM | #29 |
I drilled out my old bushings on the weekend... 5 minutes tops! I am going to be ordering urethane bushings.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
04-10-2013, 09:34 AM | #30 | |
I'm sure you're right, in which case any sqeaking would come from the ends of the urethane bushing rubbing on the insides of the bracket. It's just that I've seen some where the sleeve is longer than the width of the bar end so that it gets pinched stationary in the bracket when the bolt is torqued. In those the bushing rotates around the sleeve. By "track arm" I meant the parts you're working on not panhard rod or bar, often called a track bar. Thanks also for taking the time to post that blog. |
04-10-2013, 10:27 AM | #31 |
I just ordered the Poly bushings... thanks for the tip to take the old ones out. Will update on the wear and noise...
Wagz
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
04-10-2013, 12:05 PM | #32 | |
Here's a great thread on making your own tubular arms with adjustable heim joints. http://67-72chevytrucks.com/vboard/s...d.php?t=321100
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-17-2013, 06:43 PM | #33 |
Thanks again Lugnutz! Just did mine... took about 10 mins and I didn't even break a sweat! Awesome! BTW, I did my panhard bar too. Worked just as good there
04-17-2013, 09:14 PM | #34 |
Glad to know it worked as well for you as it did me. I have gotten great help from the forums, so it's good to know I can occasionally give back.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
10-06-2015, 11:21 PM | #35 |
Used this thread lugnutz65, all worked out perfectly. Used poly and wow what a difference
04-18-2018, 08:54 PM | #36 |
But Found Her 25yrs Later!
More opinions?
Rubber or Poly? Brand and/or part numbers?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-18-2018, 09:03 PM | #37 |
Oh if money was no prob... the rebuildable links. I like the spherical links. When in doubt look at a trophy truck doin 120 in desert. Then poly... poly break under severe punishment
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-08-2019, 11:06 PM | #38 |
I know this is a bit old...but wanted to add to it for future poly inserts. I see some had a bit of a problem with the small poly piece going in properly. If you heat up the small piece and use a c clamp as picture shows it does go on with out any modifications. If it is not pressed on you get a total of 3 inches across and the arm it fits in is 2 3/4 inches. After it is pressed on I got the 2 3/4 to slide right in.
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
01-10-2019, 04:43 PM | #39 |
Is this the same for body mounts as far as squeaking? I have the poly mounts for the cab and was fixing to install them until I read this...any suggestions would be greatly appreciated...didn't mean to thread jack
01-10-2019, 04:52 PM | #40 |
The body mount bushings are not articulating like the a arms and trailing arms. So you should be fine from squeaks. The only thing i have heard about the poly body mount bushings are that they don't compress like the rubber so sometimes there are things that don't quite line up after?
01-10-2019, 04:57 PM | #41 | |
