Old 12-27-2009, 01:30 AM   #1
markeb01
Senior Enthusiast
markeb01's Avatar
Rubber or urethane trailing arm bushings?
Please advise which you prefer for a street driven truck. It appears the urethane bushings are easier to install at home, but may be hard on components and have a tendency to squeak if not greased with the correct lubricant. The original style rubber bushings are noiseless and last for decades, but careless installation can damage the trailing arms. If you use urethane, what lubricant do you use, and do they need to be lubricated periodically? Thanks in advance.
Old 12-27-2009, 01:38 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Rubber or urethane trailing arm bushings?
I would guess the lube is the same stuff that comes with sway bars. It's clear, thick, and sticky. I believe it is a type of silicon lube. My sway bars dont squeak.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-27-2009, 11:05 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
Mark a lot of the street rod crowd use them, a lot less deflection, better handling but your right they do tend to squeak on occasion, most all of them install zirk fittings in them to alleviate the problem and use moly lube no more complaints..
http://www.timskelton.com/lightning/...e_bushings.htm
My prooblem is which one is better suited, poly graphite or urethane bushings...? any advice is welcome as I`m thinking of doing the same.
http://www.p-s-t.com/pc-3037-597-che...d-1963-72.aspx
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-27-2009, 05:43 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Good point, I didn't realize there were other options.
Old 12-29-2009, 12:19 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Any other opinions on rubber, urethane or poly graphite trailing arm bushings??
Old 12-29-2009, 03:04 PM   #6
astrochimp
The arms actuality twist to make our rear suspension work.
IMHO the polly would limit articulation and put more stress on other parts.
David
astrochimp is offline   Reply With Quote
Old 12-30-2009, 12:36 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
I typically use white lithium grease for the assembly of all the bushings. I tend to go with rubber bushings in all of my suspension components, but I have built cars and trucks using urethane bushings with no issues or squeaks, etc. The one area that I do use a urethane bushing is for the track locater/panhard bar.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-30-2009, 08:32 AM   #8
lakeroadster
I was on the urethane band wagon about 20 years ago and used them on the rear suspension on a '72 Chevy Nova I restored back about 20 years ago. Also used them on my Model A four link and Model T Hairpins.
Having used both rubber and urethane I prefer OEM style rubber mounts. That is what I used when I rebuilt the trailing arms and panhard bar on my C10 last year and when I replaced the rear springs on my '69 Camaro about 3 years ago.
In my experience the urethane transmits a lot more road noise through the suspension pieces and into the frame and thus makes for a harsher / noisier ride.
I would rather trade the slight disadvantage in handling for a less harsh more peaceful ride.
My 2 cents.....
lakeroadster is offline   Reply With Quote
Old 12-30-2009, 11:56 AM   #9
jbgroby
jbgroby's Avatar
I need to change mine how to you get them in? Do I need to bring them to a press? I hate banging on things. I have a 1960 GMC with a simple single stock sway bar.
jbgroby is offline   Reply With Quote
Old 12-30-2009, 01:05 PM   #10
lakeroadster
I removed the bar and then drilled out the rubber with a small drill bit between the O.D. steel tube and the I.D. sleeves. Drove the new ones in with a hammer.
I have heard some people take a torch and burn them out. I gotta think that would be nasty.
Old 12-31-2009, 02:10 AM   #11
Rich 5150 69
John you said it right according to this link (nasty)
[PHP]David said The arms actuality twist to make our rear suspension work.
IMHO the polly would limit articulation and put more stress on other parts./PHP]
I think this would be negligable from a street truck standpoint, the trailing arms are positoned at an angle as not to twist as much plus they sell strengthening plates as well, I will add larger front sway bar 1 13/16 , and a sway bar for the rear 3/4 to 1 inch. I`m not building a road racer just a better handling truck..
Old 01-25-2010, 02:03 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
so rubber or polyurathane??? not building a race car but wanna have good handling if i can get it
John
1999 Toyota Tacoma 4x4
Old 01-25-2010, 05:05 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
After reviewing all the responses above, plus some pm's I received, I decided to go with the factory rubber bushings. It appears from those having experience with both kinds, the non-rubber bushings will eventually squeek. I'm too old and busted to want to chase chassis squeeks a few years in the future. I'm going to be installing mine in the next week or two per the procedure outlined above by Lakeroadster.
It would still be nice to have more opinions on the record for anyone searching for information on this topic later on.
Old 01-25-2010, 05:28 PM   #14
oldblue1968chevy
too late!
i went poly....we will see lol
John
Old 04-01-2013, 08:28 PM   #15
CRGRS 66
CRGRS 66's Avatar
Originally Posted by oldblue1968chevy View Post
too late!
Well you two... Mark, you installed the OEM style, oldblue. you installed the urethane, pro's cons two years later? Are you happy with the poly bushings old blue?
I need to place an order for a variety of bits and pieces for frame/suspension re-assembly, currently torn on this one.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-01-2013, 10:18 PM   #16
Lugnutz65
Lugnutz65's Avatar
See my Tips and Tricks Section on my BLOG to see photos of how easy it is to remove the old rubber bushings. Five minutes and they're out! Really! No fire!
I have not driven my truck yet, so I don't know if the poly bushings squeak or not. LOL!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-02-2013, 07:17 AM   #17
brokenspoke
brokenspoke's Avatar
Poly do not last as long
brokenspoke is offline   Reply With Quote
Old 04-02-2013, 07:33 AM   #18
thunder71
thunder71's Avatar
I've seen some of the old poly crack...good rubber lasts along time...
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 04-09-2013, 02:17 PM   #19
Mackie
Mackie's Avatar
Hey Lugz,
Great technique for old track arm bushing removal in your tips and tricks! I have a poly bushing set in stock waiting to do the job and I'm wondering about a zerk install to avoid the eventual poly squeak.
Can you say where the rotation actually takes place? If it's between the bolt and sleeve, poly grease is not necessary I figure; just regular grease for metal on metal. If the rotation is between the sleeve's OD and the poly bushing's ID then a zerk with some cut channels might be a good mod.
Mackie is offline   Reply With Quote
Old 04-09-2013, 03:01 PM   #20
oldblue1968chevy
I never heard any noises (this time last year truck stopped being a DD )
I was happy with em
John
Old 04-09-2013, 03:50 PM   #21
Reyals Bemus
Just replaced mine with a set of GM NOS rubber bushings. Love em.
Reyals Bemus is offline   Reply With Quote
Old 04-09-2013, 08:40 PM   #22
blackcloud45
blackcloud45's Avatar
I'm dumb... where's the blog?
It always comes down to that one stupid bolt...
blackcloud45 is offline   Reply With Quote
Old 04-09-2013, 08:48 PM   #23
Lugnutz65
Lugnutz65's Avatar
Originally Posted by Mackie View Post
Hey Lugz,
I'd bet a dollar the inner sleeve rotates on the bolt. When I think about how tightly the original rubber bushings were holding onto the original inner and outer sleeve, I have to believe that they only provided the limits of the control arm movement. As far as the tracking arm, well I'm not sure about that issue, but I think it's probably the same situation.
Old 04-09-2013, 09:11 PM   #24
blackcloud45
Is this it?
It only lets me go back so far, then tells me '404 not found'?
Old 04-09-2013, 09:28 PM   #25
Lugnutz65
Lugnutz65's Avatar
Originally Posted by blackcloud45 View Post
Is this it?
Yes, that's my build thread. At the top of the BLOG you can see different sections that are not on the main page.
Just for fun, I'll post the bushing tip below.
