12-30-2009, 09:31 AM | #26 |
Re: Show your motor..73-87
My 350 gm crate
12-30-2009, 09:48 AM | #27 |
355 stroker, 11.3:1 compression. got the pulleys and waterpump and ingnition on it now, need some more pictures of it. Last edited by dbmx66; 12-30-2009 at 09:49 AM. |
12-30-2009, 10:01 AM | #28 |
Still plays with trucks
As purchased and after the clutch job & engine freshen up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-30-2009, 11:59 AM | #29 |
just back from the machine shop
in with my air intake on (not agreat picture, I know)
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-30-2009, 03:45 PM | #30 |
350 with Crane cam 222°duration,Edelbrock Performer intake and 625 cfm Carter carb,Dynomax Jet hot coated headers and dual exhaust!
The cam is replacement for the 350 hp 327 cui motor! Dyno results: 178.8 kw / 243.4 hp and top speed 218 kph! Not to chebby for a worn out carb and over the thumb ignition settings!
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ´81 GMC C 10, Spanish Red |
12-30-2009, 05:05 PM | #31 |
stock 350 tbi
12-30-2009, 06:55 PM | #32 |
The One And Only !!!
Naaa, It's a Mallory distributor assembly. I had the Mallory coil take a dump, All I could find local (had a show to attend) was a Accel super coil. I painted it red to match the cap.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-30-2009, 07:11 PM | #33 |
Laid back freak
1985 350
Cam specs i am not sure it was rebuilt before we got the truck in 1994. I added a edelbrock endurashine intake, a summit 600 electric choke carb. Set of headmen headers,edelbrock endurashine waterpump,edelbrock fule pump, set of march performance serpantine pulleys.Ball milled valve covers, finned oil pan.700r4. thanks pat
1980 chevy c10 step side restomod, 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). Last edited by 80stepsideguy; 12-30-2009 at 07:13 PM. |
12-30-2009, 08:27 PM | #34 |
Here is a pic of me mocking up my 8.2l Cadillac a while back. I still have to get this motor together. Stock rebuild with upgraded cam, intake, and valvetrain. Similar setups net around 390hp/500+ torque. Real easy swap.
12-30-2009, 09:04 PM | #35 | |
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
12-30-2009, 09:17 PM | #36 |
yeller
468
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-30-2009, 10:48 PM | #37 |
another rat
'79' shortbed |
12-30-2009, 10:58 PM | #38 |
Low & Fast!
Here is a old pic of mine when I had to put a new cam in and push rods and then found out I had a main out. So I ended up taking it all the way out..
And you guys have some nice stuff..
12-31-2009, 12:23 AM | #39 |
350 crate engine with about 25K mi on it, Centerbolt Heads, Edelbrock carb 1806 and Edelbrock Intake 7516 and a Edelbrock Cam 7102 with springs, serpentine belt setup, electric fans from a 90's winstar and new wiring.
1977 Chevy Cheyenne 2wd SWB |
12-31-2009, 09:16 AM | #40 |
Tons of great motor shots guys. Keep them coming!
12-31-2009, 09:49 AM | #41 | |
12-31-2009, 10:35 AM | #42 |
On a budget like Fred Sanford
Here's the lil 383 that pushes my heap around. Has 30k miles on her now.
Here's how she sounds:
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
12-31-2009, 01:03 PM | #43 | |
That sounds a lot like my C-10 did with the 408 when it had the Performer RPM cam in it.
12-31-2009, 01:59 PM | #44 |
3/4 Ton Rodder
Ok, I'll post mine, even though she ain't the purdiest one on here.
As far as I know it's an unmodified GM Crate 350 with a Rochester 4 bbl. I have a rebuilt carb and a set of headers going on it as well as a pair ov valve covers that I'm buying from a fellow board member. I'll add a video of how she sounds later.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. Last edited by Scootin 81 C20; 12-31-2009 at 02:02 PM. |
12-31-2009, 02:11 PM | #45 |
Master Hater
The ol $300 86 tbi 350 I got used, ebay 86 and up edelbrock intake for 60 bucks, and a old serpentine setup I got off my old 89 caprice after I did the LT1 swap.
being a Canada made engine it didn't have the fuel pump machined so i had t go electrick pump and regulator. But a LT1 will take its place this summer. Last edited by oldiron; 09-15-2010 at 06:25 AM. Reason: Removing dead picture links |
12-31-2009, 03:09 PM | #46 |
It's a Comp roller cam, 232/238 .544"/.555" 110lsa installed at 106icl. Pulls about 13-14"HG at 850rpm. Runs power brakes & HVAC just fine.
12-31-2009, 03:16 PM | #47 |
This is the orignal 350 w/ a Holley 650 that I need to pull...spun bearings... oil leak.
I have a '79 350 out of a chevy car to put in it's place. Far from pretty but the truck has never been a beauty queen, it's been workhorse...although I do find the old school alarm pretty cool. Long term future plan is to rebuild the original 350 with a little more umph...it also needs a fair amount of body work before that is the priority.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
12-31-2009, 03:22 PM | #48 |
6.0 powered square
update pics on mine
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
12-31-2009, 03:28 PM | #49 | |
12-31-2009, 09:41 PM | #50 |
I did these valve covers, medallions, & air cleaner last year! We also did a billet oilpan, & transmission pan!
