Old 01-27-2010, 02:39 AM   #26
WHAMMY'DWONDER
Re: cutting rear coils?
looking good!
WHAMMY'DWONDER is offline   Reply With Quote
Old 01-27-2010, 02:55 AM   #27
chopper john
chopper john's Avatar
thanks for the advice. its smooth.
chopper john is offline   Reply With Quote
Old 04-07-2012, 12:42 AM   #28
txinliner
txinliner's Avatar
Originally Posted by chopper john View Post
this is how it sits now with the rear coils cut . thanks alot guys it rides beautiful. i used a set of g body springs.
didnt see when this was posted but the stance is *****icn gonna try it
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 04-07-2012, 11:12 AM   #29
bama63
bama63's Avatar
just an FYI
Just wanted to add a note to this thread about the rear Jeep TJ/LJ springs.
There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate.
The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows:
103AA (or 3AA) 130lb.
104AA (or 4AA) 140lb.
105AA (or 5AA) 150lb.
106AA (or 6AA) 160lb.
hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 04-08-2012, 12:06 AM   #30
Captainfab
60-66 Nut
Thanks for sharing the info you discovered.
