12-31-2009, 04:21 AM | #1 |
cutting rear coils?
i know alot of people cut the fornt coils , its cost efective . but my question is has anyone ever cut the rear coils and remade the pig tales? i want to be about tree inches off the ground.
12-31-2009, 04:27 AM | #2 |
Re: cutting rear coils?
lowering blocks.
12-31-2009, 04:36 AM | #3 |
i need it 3 inch up off the ground. i already have blocks
12-31-2009, 04:43 AM | #4 |
65 Chevy
I cut my coils in the rear. You dont have to re-do the pigtail just cut the top part off the coil as much as u want (if i remember rite 1 coil = 2 inches)dont qoute me on that, then just rebolt the bottom pigtail . when you lower the truck back down, the frame will sit on the cut end of the coils. This is what i did for now and it worked awesome. Make sure you completely cut of the rear bump stops w/the medal mount that the bump sits on or your truck will bounce like crazy.Hope this helps, good luck
12-31-2009, 04:46 AM | #5 |
AAAAACKCKKCKK!!!! seriously!!!!
12-31-2009, 04:50 AM | #6 |
that really worked? i dont know if i really trust that very much . i know there is peopel that will cut and recoil to whatever you want . i knew an old man that used to do it for a friend of mine but he has passed .
12-31-2009, 04:53 AM | #7 |
if i cant find anyone then i will think about it . thanks for the info. kiknrocks
12-31-2009, 05:59 AM | #8 |
anyone else?
12-31-2009, 08:25 AM | #9 |
I did the same, cut off the top of the spring and when you let it down, it rests against the bottom of the frame. The bottom of the spring is still bolted to the trailing arm and ive never had any problems since I did it 6 months ago.
12-31-2009, 09:01 AM | #10 |
and a few others
I can't imagine any way you could "make" pigtails without heating the coil. And, you don't want heat on them. Why not go to a junk yard and get used Jeep springs? They're cheap and work well. And, a whole lot safer than no pigtail.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
12-31-2009, 10:55 AM | #11 |
Rods
For the unknowing.. What jeep coils work.. (maybe we can save him the trouble of damiging his springs.)
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
12-31-2009, 11:17 AM | #12 |
Hollister, CA.
I also cut one end off. Once bolted in the trailing arm correctly, it will not go anywhere.
Just make sure you position the cut end centered in the frame. You can, using heat, re-shape the coil end into a pigtail....I have done that many times as well in the 'old days'. Obviously, lowered springs, or Jeepers are the way to go (I have to throw this in to make everyone happy) Suspensions...it's what I do
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
12-31-2009, 11:53 AM | #13 |
use jeep springs
im prety sure any 97-06 cj rear springs will work
61 step/long bed SBW(SOLD) NEED A NEW PROJECT |
12-31-2009, 03:48 PM | #14 |
does anyone have pics with jeep sprins on them. i wanna see how low it sits . cause i want it to sit like whammydwonders truck. there used to be an old man that used to cut them and remake the ends to whatever height you wanted.
12-31-2009, 04:14 PM | #15 |
You can cut them and reshape the pig tails but you change the spring rate making for a harsher ride
The other issue of just spirng height lowering is the trailing arm geometry A combination of the tested jeep springs and lowering blocks should get you where you want to be The other Point everybody misses is the panhard bar It should be remounted to be horizonal at ride height and should be as long as possible and if you are smart adjustable
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
12-31-2009, 04:28 PM | #16 |
MY truck has the jeep springs that are CUT in the pic. above. They werent low enough stock (stock jeep springs)only got it 4 inches or so lower. and I wanted hammered! by the way, the truck rides soooo amazing with the jeep springs, even cut people that ride in it cant even believe it. Never have had any problems with the cut springs moving around or making funny noises or anything either. oh and I did cut the the springs and heat up an end to make it a pig tail on both ends but it colapsed where I pig tailed it so just cut now, and no problems. jeep springs were outa 01' grand cherokee rear with a v8.
12-31-2009, 04:44 PM | #17 |
Well i put a 96 caprice rearend so i Have to redo the pan hard bar , as long as posible . But i want the hight first then set pinion angle , last adjustable pan hard bar.
12-31-2009, 04:47 PM | #18 |
12-31-2009, 06:17 PM | #19 | |
and a few others
Or, 70's Chevelle springs work too. That's what I used in my 63
12-31-2009, 06:55 PM | #20 |
well i guess im gonna cut mine , they are off a g body car . but at the end that sits on the forame ill weld in a piece of pipe to slide it into so it wont fall out . just to secure a little bit
12-31-2009, 07:14 PM | #21 |
If it's bolted to the truck arm like it's supposed to be, it's not going anywhere.
12-31-2009, 07:51 PM | #22 |
65 Chevy
well im sure glad you guys put in your 2cents cuz i know i wasnt the only one that lowered my truck that way. Thanks
12-31-2009, 10:24 PM | #23 |
ya srry (tj) is what i was trying to say just miss typed
01-01-2010, 12:49 AM | #24 |
rear springs out of a mid to late '80's 325is BMW will give you about 3-4 inches and a great ride. They are coiled tight at each end so a small cut of the pigtail with a sawzall is needed. This allows the stock cup to be used in holding them in place. I got mine for free when my buddy lowered his BMW
01-27-2010, 02:26 AM | #25 |
this is how it sits now with the rear coils cut . thanks alot guys it rides beautiful. i used a set of g body springs.
