Old 01-05-2010, 11:38 AM   #26
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: 3.07 gears????
It's been a while, but I had the 3.0x gear in my 12 bolt and do not recall needing a carrier to swap to 3.73.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-05-2010, 12:34 PM   #27
Pyrotechnic
Pyrotechnic's Avatar
Re: 3.07 gears????
As far as I know, there is only a 3 and a 4 series carrier for a truck 12 bolt. 3 series is 3.42 and under, and 4 series is 3.73 and up. There aren't really that many gear choices for the truck 12, so it's pretty simple.
If you have a 3 series carrier, you can buy aftermarket thick gears that will let you run 4 series gear ratios on your 3 series carrier.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-05-2010, 01:49 PM   #28
68 TT
Still plays with trucks
68 TT's Avatar
Re: 3.07 gears????
Originally Posted by 78-5.3 View Post
understand !!12 bolts are alot of hassle compared to a 9" i think i might start looking for a nine inch thats been narrowed down too around an s10 width for my future 4 bar set up i just wanna run lower gears till then!! these diesel gears are terrible
It sounds like the truck 12-bolt did not have a 2-series carrier like the car 12-bolt so you just need to find out where the gear ratio break point is for the carrier you have. A gear listing catalog would tell you.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-05-2010, 09:04 PM   #29
LONGHAIR
Re: 3.07 gears????
Wow, how many hi-jacks can we have in one day?....LOL
78 5.3
does anyone know what i need to change my gears to either 3.73 or 4.10 they are 3.07 at the moment do i just need the ring and pinion set or a carrier too? its open and im leavng it that way !!! i know there other need parts to buy ?
Yes you do need a carrier too.....and a professional to install it all for you. It's just not worth the time/effort and new tools required to do this "one time" job.
68TT
If they break it down like the car 12-bolt carriers you will need a 3-series for 3.73's and a 4-series for 4.10's unless you run special thick gears on a 3-series carrier then you can get 4.10's on the 3-series. Can't get 3.73's on a 4-series carrier.
They don't....The break in the carriers is at 3.73. The 3.73 gears fit on a 4 series carrier and 3.42 is the lowest for the 3 series.
Pyrotechnic
Yup, but I'm not a big fan. IF they still make them, there are ring spacers too, not a fan there either.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-05-2010, 09:20 PM   #30
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
ok so i will need a 4-series carrier for my 3.07 !!! out of a truck !!! to make it a 3.73
78-5.3 is offline   Reply With Quote
