Old 11-29-2014, 01:03 AM   #26
SnowNeck
SnowNeck's Avatar
Re: Rear mount gas tank?
Originally Posted by Captainfab View Post
In looking at your pic a little closer, it looks like that tank is a poly tank?
It's a daily driver so it's actually truck bed linered, it's aluminum.
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 08-28-2017, 10:29 PM   #27
1BAD65
Originally Posted by pdxhall View Post
I am using the falcon gas tank in my build. I haven't finished it up completely but here's what I did.
looks great !!
I see its a tanks.inc 64-68 Mustang Tank kit.
1BAD65 is offline   Reply With Quote
Old 08-29-2017, 10:21 AM   #28
vince1
http://67-72chevytrucks.com/vboard/s...d.php?t=742282
The Jeep tank is easy but only 15 gal. and sending unit does not match our gauge.
vince1 is offline   Reply With Quote
Old 08-29-2017, 01:45 PM   #29
1BAD65
In Case anyone is looking for a cheap 16 gallon gas tank that F**d Mustang tank is only $53.79 on Rock Auto shipping costs vary by your location.
DORMAN 576036
You will need a sending kit as well
SPECTRA PREMIUM/COOLING DEPOT FG86A (3/8 line) $37.00
Old 09-25-2017, 11:01 AM   #30
shoveldug
DORMAN 576036
Thank you sir!
shoveldug is offline   Reply With Quote
Old 09-25-2017, 04:24 PM   #31
vince1
It seems obvious but don't overlook the need for venting. I saw an unfinished truck at a car show that looked like the tank was collapsing. The sending unit vent was capped off and the fuel filler cap looked like maybe it was of a non venting type.
Old 09-26-2017, 12:10 PM   #32
Chevystep
My problem with most tanks is the filler location in the bed, which I don’t want. So I decided to go with a 69 Camaro tank with the license plate fill location. I’m currently mocking this up and will try to post some pictures when I get time. I’m at the end of a resto and haven’t put the bed boards in my 66 longstep, so the tank stuff is a LITTLE easier. It DOES put the entire tank below the frame rails, but it’s still way above the diff., and I’ve coated the tank with bed liner while it’s new and clean. Look in the FAQ section on gas tanks for K1rodeoboater’s write up, but his is an older truck and I think the bed rails were wider?
Chevystep is offline   Reply With Quote
Old 09-26-2017, 12:20 PM   #33
Chevystep
Oops, never mind the FAQ reference, none of the photos are there due to photobucket issues, I guess.....
Old 09-26-2017, 07:47 PM   #34
rvrfoot
Yep, no more pictures.
rvrfoot is offline   Reply With Quote
Old 11-22-2017, 09:31 PM   #35
raidmagic
raidmagic's Avatar
Have you posted pics of this anywhere? I like the idea of coming out behind the plate. It's not an expensive tank either.
raidmagic is offline   Reply With Quote
Old 11-23-2017, 12:50 AM   #36
Sik5chevy
I used tanks INC mustang style tank and mounted it in between the frame rails on 1x1 tubing so I can take it out later if I need too. I did have to trim a 1/4” Off either side of the bottom frame rail
Sik5chevy is offline   Reply With Quote
Old 11-25-2017, 11:02 PM   #37
raidmagic
raidmagic's Avatar
What year Mustang tank? Where is your filler neck? Got pics?
Old 11-26-2017, 11:36 PM   #38
Sik5chevy
I think the part number is mu-t and takes aftermarket fuel senders. It’s modeled after a 65-68 mustang tank. I have not put the floor in yet. Good thing is it came with two different necks that bolts to the top. I’ll see if I can find a pic if not I’ll take one next time I go to my shop.the measurements or on tanks INC site
Old 11-27-2017, 04:51 PM   #39
rvrfoot
Yep people love the FORD tank. I am just saying.
Old 11-28-2017, 09:43 AM   #40
Rich 5150 69
Rich 5150 69's Avatar
Not all tanks created equal....49 to 52 chevy pass, this has a smaller inlet 1 3/8 side fill with vent. I just went thru the side of the frame.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
tfrg
