01-22-2010, 09:38 PM | #26 |
Re: Another LSx/4L60e Swap
I am not sure but in the pic, it looks like if those mounts would had allow to use the original compressor... they almost look like the plate had the "fred" cut on them,, what you guys think?
01-22-2010, 10:50 PM | #27 |
Next project: 1970 K10
It would allow the 5.3L compressor to fit, but at the expense of not being able to re-use the stock driveshaft (i would have to be shortened), and the need to move the shift linkage frame bracket.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
01-23-2010, 08:22 PM | #28 | |
how can you guys tell the transmission you have,,, I saw somewhere that the some have the "4l60e" staped on the.. but my have nothing but a # 58 also has the GMPP staped on it.. came from a state trooper tahoe? any one..? Last edited by fpjr0; 01-23-2010 at 08:28 PM. |
01-23-2010, 08:29 PM | #29 | |
Here is a site that gives tranmission measurements. The 4L80 is about 4 inches longer to the bolt flange (measurement B). Should be able to figure it out with these measurements
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 01-23-2010 at 08:30 PM. |
01-23-2010, 08:33 PM | #30 |
if i'm not mistaken, the 60's and 65's have a round cap with a clip on the passenger side where the shift servos are. someone please correct me if im wrong.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
01-23-2010, 08:55 PM | #31 |
I would correct you.....
but you are right!
01-23-2010, 10:13 PM | #32 |
got 1 right!!
01-23-2010, 11:23 PM | #33 |
thanks... It does have the round clip.. so I guess a 60 it is.... thank you.....
01-24-2010, 05:46 AM | #34 |
box junkie !!
awesome build !! lots of good info . subscribing
- 500mg of crazy a day ...... will keep the straight jacket away !!! :burno |
01-25-2010, 02:04 PM | #35 |
The truck had the usual rust areas, so I welded in pillars, kick panels, cab corners, outer floors and rocker panels on each side.
01-25-2010, 02:08 PM | #36 |
The original harness was shot, so I replaced it with a Painless direct-fit. Many of the circuits aren't going to be used, so I have them tied uo for now. Also mounted the engine harness fuse block in the same area.
01-25-2010, 02:15 PM | #37 |
I found a '91 Blazer cluster with electronic speedometer and got it tied into the chasis harness. All of the guages and lights work (not sure about the speedometer because I haven't tested it). I tapped the t-fitting near the oil filter and mounted a sender. Works great!
01-25-2010, 08:23 PM | #38 | |
6.0L power.........
What ever the mind of man can conceive......... he can achieve! My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E 1995 Mustang GT 347 |
01-25-2010, 09:40 PM | #39 |
Street and Performance sells that bypass block, their are fairly reasonable on the price too (surprise surprise!!). I bet you could get a part number from a dealer too, then check at gmpartsdirect.com to see if they are cheaper.
01-25-2010, 09:41 PM | #40 |
This is what i did, it was for my 97 tahoe so it's a different sender but you should be able to fit the older sender in there.
01-25-2010, 09:52 PM | #41 |
Formerly- 1972SuperCheyenne
My engine is from a van and just has a block off plate there. I guess I need to go look and see where my oil sender is on the 6.0 NOOK and TRANNY on ebay sells a oil sender and a one wire connector (from a 2002 F-Body) so you can hook the wire directly to your factory wiring for your pressure gauge.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-25-2010, 10:30 PM | #42 |
Josh i just seen your sig!!
btw, i need one of those oil sender t's also.
01-26-2010, 11:16 AM | #43 |
I just though I would post an FYI that the "electronic" speedos actually still need a cable drive from the transmission and the speedo it self has a signal generator for the computer (engine only during these years).
I hope that this saves you some time. Just look at the back of the speedo yand you will see the cable fitting. |
01-26-2010, 11:22 AM | #44 | ||
The electric speedo we use for these swaps come from a 90-91 Blazer, Suburban or dually. They are true electric speedometers, and only require the one signal output from the PCM ran to the cluster. You must re-pin the cluster connector, but there is NO speedo cable. Quote:
Edit - Corrected the date.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-26-2010 at 11:31 AM. Reason: Corrected the date |
01-26-2010, 11:25 AM | #45 |
This is another oil pressure sender option I posted in the other thread.
Some people remove the oil pressure sending unit from the back of the engine and use a 16mm X 1.5 to 1/8NPT adapter and use that for their oil pressure line/sender. The PCM doesn't need the oil pressure sender (from what everyone tells me). I am having a T made for that location so I can have both (I believe a scanner, Tuner and things like an aeroforce gauge can read the stock sender) This is the adapter fitting Aeroforce gauge
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-26-2010, 11:29 AM | #46 | |
I have a 1989 sub that i'm parting and it has a speedo cable with an optical sensor for the computer.....I will look and see what the exact date is on the sub, maybe it was a mid year change?
CHEVY ONLY |
01-26-2010, 11:29 AM | #47 |
I left the 5.3's sending unit in it's original location, and drilled and tapped the bypass block and put the sender there. Why? Hell, I don't know. Cause it was funner to drill and tap something I guess?
01-26-2010, 11:30 AM | #48 | |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-26-2010 at 11:32 AM. |
01-26-2010, 11:36 AM | #49 |
soule64 - Is that a tach in the bottom left hole in your cluster? If so, what kind is it? Things are looking good!
01-26-2010, 11:45 AM | #50 |
May be a dumb question, but couldnt you have used the F-body (2002) sender and your factory wiring or was the location of the 5.3s sender an issue?
