Old 01-17-2010, 03:48 PM   #1
soule64
soule64's Avatar
Another LSx/4L60e Swap
The truck is a '76 SWB that I bought for my son several years ago. We got it running with a crate 350/TH350, but I was concerned about reliability since he had it with him while in college. Last April, I found a complete '06 4.8l/4l6e with all accessories, pcm, harness, manifolds and mounts with 20k miles on the clock for under $1k. I started the build in June and it is now installed and running. I wasn't looking for high performance - I wanted a rock solid daily driver in an older classic truck. I'll play catch-up as I get the photos uploaded.
soule64 is offline   Reply With Quote
Old 01-17-2010, 04:00 PM   #2
soule64
soule64's Avatar
Re: Another LSx/4L60e Swap
I wanted the drivetrain to look as stock as possible, so I installed the original intake system from the throttle body to the air cleaner. I trimmed down a p/s battery tray to mount the box. Ran the steam line from the throttle body to a JTR adapter in the top radiator hose. The top hose is stock for an '05 Silverado and fits like a glove. I had to trim and patch the intake plenum similar to project 'Fred'. The filter box looks like it's tilted fwd a little, but will sit flat on the tray once I bolt it in. Same thing with the battery on the other side - I will be pulling much of it back off for body work (new fenders) and paint later on so I left it as-is.
Old 01-17-2010, 04:04 PM   #3
soule64
soule64's Avatar
I mounted the battery on the d/s with a tray/mount from LMC. The original battery cables fit perfect.
Old 01-17-2010, 04:34 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Nice job!!!! I love these swaps, they are by far my favorite now! What a great price too.
I see you used the high-mount kit for the A/C, is that from Kwik Performance? Does it work with the OEM air intake stuff? It looks close. If it does, that will save me from running the air cleaner over to the D/S.
Great job, that 4.8 should be excellent for reliability and mileage in that truck. My 85 weight just a smidge over 4000#, so that 4.8 should produce some great MPG with the right gearing.
Can't wait to see some more pics!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-17-2010, 04:36 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks awesome. Nice work.
--Josh
Old 01-17-2010, 04:38 PM   #6
glock35ipsc
Forgot to ask, what is the quality of that adapter from JTR? I was going to get one, but a very talented board member machined an adapter for me that goes in the radiator where the OEM heater hose went. Works perfect, but the JTR piece gets it up a little higher.
Bob
Old 01-17-2010, 09:54 PM   #7
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Very nice! This is the way I want mine to look. Like it came from the factory with that engine in it. Great Job!
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 01-17-2010, 11:59 PM   #8
soule64
soule64's Avatar
Thanks for the comments - The JTR adapter fit very well, but I had to center it on the pressure hose on the top of the radiator shroud which takes away from the factory look. The plenum has about an inch of clearance over the top of the serpentine belt, but there is a factory mounting tab that I can mount a bracket to the radiator shroud to keep it from dropping into the belt. The Kwik bracket and Sanden compressor fits great.
Old 01-18-2010, 08:15 AM   #9
menace121978
menace121978's Avatar
looks great!! looking forward to more pics and details.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-18-2010, 09:02 AM   #10
STOCKISH
STOCKISH's Avatar
It looks great.
--Josh
Old 01-18-2010, 10:29 AM   #11
soule64
soule64's Avatar
For the fuel system, I used a new '87 tank from Rock Auto, new mounting straps, an '87 sending unit and an ep-381 pump. I used high pressue line to connect the pump to the sending unit. I think I screwed up with the clamps, though. I read on another post that I shouldn't use the worm style, so I'll have to go back later and fix it. I used -6 braided steel lines with compression and snap fit fittings to the filter/regulator and more -6 line to the fuel rail. By the way, the outside port on the regulator is the pressure side and the inside is the return. Ask me how I know...
Old 01-18-2010, 10:39 AM   #12
glock35ipsc
That is great news!! That means I can install the compressor without spending the money to fab up a drivers side air intake setup. And I know the tab you are talking about to mount it to the shroud, I think I will do the same.
Great progress, can't wait to hear that it runs!
Bob
Old 01-18-2010, 10:53 AM   #13
soule64
soule64's Avatar
It does run. I fired it up about a month ago. Once I got all of the connections made, I primed the fuel rails. It cranked over maybe 2 revolutions and started right up - idled high for about 10 seconds and then slowed down to around 600 rpm. Suprised the hell out of me...
Old 01-18-2010, 10:55 AM   #14
glock35ipsc
LOL, I guess I should have re-read the very first post, eh?
Since this is an '06 engine, do you have the electronic gas pedal installed yet?
Bob
Old 01-18-2010, 11:20 AM   #15
soule64
soule64's Avatar
Funny you ask - The pedal that came with the truck ended up being bad (same as yours), so John from Speartech sent me a new one with the harness. I mounted it in nearly the same place as the original one. I have a picture somewhere, just have to find it...
Old 01-19-2010, 07:17 PM   #16
smokedat
smokedat's Avatar
looking good, subscribed
smokedat is offline   Reply With Quote
Old 01-20-2010, 09:55 AM   #17
soule64
soule64's Avatar
I found some earlier pictures of the build on another computer. Between work and home, I've got three crappy cameras and three equally crappy computers, so it's kind of tough getting everything in the right order. We started at the back and got the truck down to the frame, then hit it with a pressure washer, solvent and whatever it took after that to find bare metal. POR metal-prep and gloss black after that, plus a set of new cab/bed bushings.
Old 01-20-2010, 10:47 AM   #18
soule64
soule64's Avatar
Also felt it was a goos time to rebuild the front end, so we installed a new steering box, tie rods, pitman and idler arms and just about anythig that was rubber. Did the POR thing and put it back together.
Old 01-20-2010, 11:53 AM   #19
soule64
soule64's Avatar
Forgot about the pics on the cell phoe, so add one more to the camera list.
Anyway, here is the the transmission and original cross member. New case mount and grade 8 bolts included. Everything fit perfectly without any drilling (by me). There were a few holes on the frame rails that didnt look original, but they were enough to get it to fit.The original shift linkage fits ok, but I to move the frame bracket fwd an inch or two. I had to get the driveshaft lengthened 2 inches and it fits very well.
Old 01-20-2010, 11:59 AM   #20
glock35ipsc
The 2" setback plates would have let you use the original drive shaft and keep the linkage in the original spot. You must have used the rectangular shaped motor mount plates if you had to lengthen the drive shaft and move the shift linkage?
Bob
Old 01-20-2010, 05:34 PM   #21
soule64
soule64's Avatar
The mounts that I used were from ECE. They bolt on in place of the plates/shell on the engine. The guy I bought the motor from threw in a set of plates and mounts, but I decided to go with these so I could use the oem mounts. I should have done more research before buying these...
Old 01-20-2010, 06:13 PM   #22
78-5.3
78-5.3's Avatar
i had to lengthen my driveshaft about 1 3/4in
but my shfter linkage is correct and works right!!!
how much did you lengthen your????
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 01-22-2010, 03:10 PM   #23
soule64
soule64's Avatar
I had to lengthen it 2 1/8" if I remember correctly. The shifter worked in the original position, but the arm to the transmission coupling was at an rearward angle that looked a little strange. Moving the frame bracket fwd helped straighten it out.
Old 01-22-2010, 03:37 PM   #24
glock35ipsc
That sounds about right. The 2wd truck 4L60E is 2-1/8" longer than the 9" tail shaft TH350, and the plates move the engine forward 2", leaving only a 1/8" difference that the slip yoke can handle.
Do you have any pics of the truck itself?
Bob
Old 01-22-2010, 05:02 PM   #25
soule64
soule64's Avatar
Sorry, I can't find any pics of the truck itself. There's not really much to see because it's pretty much blown apart to get to the frame. Can't wait to show off the power "Dallas Cowboy" edition power doors.
