Old 01-25-2010, 02:48 AM   #26
JEM
Ironmonger
Re: i have thought about converting
If you want good light, and not just something that looks pretty, IMO you need to look at what GM did for vehicles exported to parts of the world where US-market headlights of that era are considered so bad sometimes they're illegal.
I ended up with these (bought a spare, too, because they'll be unobtanium eventually) for low beams:
http://www.rallylights.com/detail.aspx?ID=3929
with a set of Osram Silverstar +50 H4 bulbs (you can go bigger on wattage if you want, they've got steel reflectors and glass lenses and should take the heat, but I'm happy enough with a decent modern 60/55W +50) for the low-beams, and a set of the 4701 high-beam replacements from here:
http://www.eurolamps.com/eurolamps/c...headlights.htm
with a set of +30 H7 bulbs (never mind their crap about 'xenon' and 'ion' and etc. bulbs, their lamps take a standard H7 halogen bulb, I threw out the blue things they sent and put in good Osram ones.)
The Bosch/Guide lights are European OE-quality, and the best optics you'll find in the little 150mm package. I bought only the lamp assemblies (two low-beams plus a spare) and not the full harness, because I wanted to do my own wiring. The Eurolamps stuff is of indeterminate (India? China?) origin but adequate (they're not plastic) for high-beam use.
Then you need to wire some serious amperage to them because the tiny stock wires can't carry enough current to light up a decent flashlight.
I pulled out the front-body harness and did some serious reworking, used the existing hi/lo headlight wiring to switch a pair of relays (the sealed metripack kind used for the fuel pump on TBI trucks) that feed the headlight circuits directly from the +12 distribution block on the firewall. One walk through the pick-n-pull will yield all the relays and fuse holders needed, then you just need some new metripack terminals to rewire them.
Bought a pile of TXL wire from Waytek (lots more than I needed for this, but I've got a couple other cars to rewire), Metripack terminals from pcsconnectors.com (love them) and mouser.
Very pleased with the results. It'd be fruitless to post pics of the lights because they look stock, I'll try to snap a pic of what my harness ended up looking like.
JEM is offline   Reply With Quote
Old 03-06-2010, 02:40 PM   #27
Fer79
Fer79's Avatar
Fer79 is offline   Reply With Quote
Old 03-08-2010, 12:48 AM   #28
86454k30
86454k30's Avatar
I am going to do this on the 87 I just bought. Is the wiring pretty straight forward? I know it isn't plug and play.
86454k30 is offline   Reply With Quote
Old 03-08-2010, 09:38 AM   #29
Jonboy
Slots go on anything!
The colors match up the same (at least they did on the 85 I converted). I had to pull the tan wire out of the original harness that goes to the plug down by the proportioning/combo valve on the frame- the 90 harness did not have it.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-08-2010, 11:36 AM   #30
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Same thing for my 86.
I am a wiring idiot, but with a couple phone calls (and realizing the colors all matched up) I had an easy go at it. And like I said earlier, make sure you spread out your connections so you can fit it back in the split loom easier.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-09-2010, 12:01 AM   #31
86454k30
86454k30's Avatar
Thanks for the input. Since mine is a dual headlight truck I am pretty sure I will have to get a harness for a four headlight before I splice the 89-91 harness. Or will the dual headlight harness work?
Old 03-09-2010, 12:17 AM   #32
Driveway Dreams
I have car A.D.D.
Sorry, just though it was easier to show you what mine came from in case your wording and mine were not the same. My truck originally looked like this...
Now, all I did was cut my truck harness (minus the 1 wire that goes to the brake proportioning valve) about half way forward on the fender. I cut the suburban harness off near the same spot. Then I spliced the matching colors together. There are 2 instances in which one harness has 1 wire of a color while the other has 2 wires of that same color. Tie all 3 of those together. (sorry I cant remember what colors right now.)
I hope this is actually helping. I feel like I am having a hard time making sense.
-Gerald
Old 03-09-2010, 12:26 AM   #33
86454k30
86454k30's Avatar
Nope that makes sense I appreciate the explanation. And mine has the same headlights yours had.
Old 03-09-2010, 12:30 AM   #34
Driveway Dreams
I have car A.D.D.
Glad I could help. I got all my info when I did it from people on here. So, I am just glad to offer it back up. That is why we are here after all.
-Gerald
Old 03-09-2010, 12:39 AM   #35
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Dang ! I thought I had invent'd the "spread out the wire splice's" idea, you are right , nothen look's worse than a big bunch of butt connector's all hang'n out of the wire loom.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-09-2010, 04:19 PM   #36
motornut
78K & 79C Jimmys
motornut's Avatar
just a thought but i moved the low beam lights down and the highs up,this kinda adds a lower look to it.....not why i did it ,just seemed to make sense,low low high high
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-09-2010, 05:03 PM   #37
BGRAFX
Jittery Guy- what's the drop on your dually? I like it!
BGRAFX is offline   Reply With Quote
Old 03-14-2010, 07:22 PM   #38
87 chevy silverado
i have already did that
87 chevy silverado is offline   Reply With Quote
Old 03-14-2010, 07:23 PM   #39
87 chevy silverado
x2
