#26 |
Insane In The Membrane
Re: Which rear end is everybody using?
Dana 80 Dually
#27 |
Cool thanks, I need a new rear end. My truck just waste too much gas.
#28 |
I have a 10 bolt from a 1978 camaro lt, with drum brakes non pose don't no what gear it has or how to find out I just thought it worked good in the camaro? I am thinking of changing it to don't know yet??????
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck |
#29 |
Certified Car Nut
If you want to know your gear ratio on a 10 bolt 8.5 which you have. Take the cover off and turn the ring gear until you see a set of numbers stamped on the edge of the gear this is the tooth counts for the ring and pinion. You divide those numbers and it will give you your gear ratio. For example if the numbers are 48:14 you divived 48 by 14 and it will give you 3.428 which is 3.43 gears.
#30 |
wow kabwe pretty smart trick. i wouldn't have figured that out...
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#31 |
Certified Car Nut
I know its pretty sick that I know this stuff, what can I say I was born into a family of lowriders. You should see me in the junk yard.lol People looking at me wondering " Why is he taking the cover off all those rearends and punching on his calculator.lol
#32 |
Or an even easier way to check gear ratio is to hold one axle shaft solid, spin the other axle shaft and count how many times the pinion rotates. 3.5 is 3.43's, 3.75 is 3.73's. This trick usually works well, especially if you don't want to open the axle up. If the axle has a locker then you don't have to hold one axle shaft solid.
#33 | |
LOL I got a visual I can see you in a junk yard like a kid in a candy store!!!LOL.. Thank for the info good to no!!!! I get your mail reply too thanks....
#34 | |
Certified Car Nut
#35 |
Does anyone know what rear end gear came in a 1983 S15? It had 2.8L V6 I believe.
_____________________________________________ Thanks, Garrett ![]() My 1950 GMC Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=351867 My 1950 GMC Photobucket Account: http://s565.photobucket.com/albums/ss95/1950GMC/ |
#36 |
I have an S-10 Blazer rear in my truck. The S-10's came with 3 or 4 gear ratios and the optional factory locker. Only way besides counting teeth like Kabwe said, was to look at the build options on the glovebox of the truck. Mine was the GU6 (3:42's followed by G80 which is Posi) thats what I needed. As far as rearends that can take abuse the 9" design is king if you're making 900+ horsepower, anything less and I'd stick with the Chevy stuff. 10 and 12 bolts take 30 LESS horsepower to turn than the 9" (pinion angle on the ring and an extra pinion bearing) so if you have a mild motor, use the Chevy stuff and enjoy the extra HP and mileage! 12 bolts can be set up to be really tough and I know of a guy who ran 9's with a 10 bolt!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 Last edited by kustombrad; 02-23-2010 at 08:41 PM. |
#37 |
I have a 11 bolt of a mid 60's gm
big car. It has a posi, richmond 4.10s, and moser axles. Soon to be narrowed but I think it's 66 inches |
#38 | |
Thanks, |
#39 |
stock c- clip axle 8.5 10 bolt. auburn gear center, with richmond 4.10's. just ordered comp. engineering 4 link kit, QA1's rear pro coilover "kit". seeing if i can snap an axle with the power at hand.
next winter order, 9" housing ends, mosier 30 splines, eaton diff., lpw rear end girdle, and some 3.08's
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
#40 | |
Cancer Survivor in the making.
I believe 3.90 was the standard ratio in the stock half-ton rear in '55. You must have a calibrated eye to see 1.95 revolutions. I'd have trouble unless I measured things getting that accurate.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
#41 |
