Which rear end is everybody using?
Im building a 53 5 window and have pretty much everything i need except the rear end. was just wondering what other people were using.
Re: Which rear end is everybody using?
9" Ford
1958 3100 w/55 frontend and 55 Cameo Bed (in progress) ![]() |
![]() Join Date: Mar 2007
10 bolt Chevy w/posi out of a Grand National...
The guy's on trucks (tv show) put a 8.8 ford out of a explorer under there AD truck. I've put one under two 57's and my 38. You can get a low milage rearend with disc brakes and posi track that don't need to be rebuilt for 200 bucks. Do they make stonger rearends? YES, but not for that price.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
10 Bolt with disc brakes out of a S-10 Blazer.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
94-01 I believe is the years for the explorer, claim to be as strong as a 12 bolt and their cheap
Certified Car Nut
I would not worry about breaking a Chevy 8.5, 12 bolt or a Ford 8.8 with most applications. A 9 inch is over kill for most people ( I have one in my 55 210 454 and its over kill). Unless you have a serious motor and putting your foot in it all the time you don't have to have a 9 inch. Ring gears on a Chevy 10 bolt is 8.2, Chevy big 10 bolt is 8.5, 12 bolt is 8.875, Ford 8.8 is exactly that, and then you have the most teasured with bragging rights 9 inch. The rearend you chose should depend on the car's use. If your building a monster than you may want a 12 bolt or 9 inch, if you build a cruiser with a little pop to it you will be fine with a 10 bolt or Ford 8.8. I'm concerned with gear ratio and I love posi. for the kind of stuff I build.
Here is the rear thats in my truck. Its a Chevy 8.5 with posi 3.42 gears. ![]() Last edited by Kabwe; 01-28-2010 at 06:56 PM. |
I plan to use the rear from the '94 Z28 my engine and tranny came from, when I obtain 350 bucks. It is a 3:23 posi with disc brakes.
ford 9" with 3:50 gears and limited slip.
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
youngrodder, Is that rearend out of a coil car? What kind of set up are you running for your rearend, Leaf spring, 4 link, coil, etc?
_____________________________________________ Thanks, Garrett ![]() My 1950 GMC Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=351867 My 1950 GMC Photobucket Account: http://s565.photobucket.com/albums/ss95/1950GMC/ |
I believe youngrodder has his truck built on the car frame that rearend came out of.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#12 | |
I still have the other rear end. I am looking to get rid of it cheap!!!! Thanks Marc |
#13 |
I just picked up a 98 camaro rear end with 3:23 gears, posi, and disc brakes for $150.The only thing is it's kind of wide.
#14 |
Addicted to Rust
![]() Join Date: Dec 2009
67-72 Ford pick up fits nice. mine has a 68 12 bolt truck in it.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#15 |
I read on Stovebolt which rears are what width and just happened on a 69 F100 9" 3.50 gear for 50$ off craigslist.
"I feel the need for speed!"... as soon as I am done with my nap. Last edited by NONHOG; 01-30-2010 at 12:18 AM. |
#16 |
68 Camaro 10 bolt. 8.2 273 gears I want a freeway flyer.
Truck's just for the fun of it. ![]() |
#17 |
Cancer Survivor in the making.
10-bolt Chevy from under a '73 Chevelle wagon. 3.08 gears.
#18 |
Tripple Five Fanatic
Narrowed 9" from a 85 Bronco, came with 3.50 but now 4:11 Track Lock or Posi. I cut it down to 58".
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#19 |
every body's using a ford 9 inch. everybody else .......
#20 |
got a 12 bolt chevy in my 59
#21 |
im putting a '98 explorer 8.8 in my 59. 3.73 gears, lim slip, disk brakes, 59 1/2" flange to flange, $150.
#22 |
I was thinking of a 9" but have had a 8.2 in my chevelle for 10yrs with eaton and superior axles, have 150 1/4 mile passes on it started out running mid 12's now 11.30 yes it will break someday but if one can hold up this long with that kind of abuse then i know it will hold up to a street rod. I'm thinking of putting it under my 53 now that ive broken the 11.50 barrier NHRA rules no c clip. the 9" is as stated earlier in the topic over kill for the street but if thats what you want more power to you,
#23 |
does any one know which rear ends are 62"?
#24 |
Late 60's early 70's chevelles are 62"
#25 |
