Old 03-12-2010, 08:11 AM   #1
olred68
olred68's Avatar
Long tube header question
If I run longs tubes how low can I drop the frontend without the headers draging on everything?
Brandon
olred68 is offline   Reply With Quote
Old 03-12-2010, 08:27 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Long tube header question
you can't ......I think the best solution is these then you can tuck things up pretty easy
http://www.kmjent.com/cart/product.p...8&cat=0&page=1
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-12-2010, 09:01 AM   #3
gmcdude
gmcdude's Avatar
I have long tube headers on mine and they don,t drag, I have 4 inch drop up front, but I runing 20 inch wheeels.
gmcdude is offline   Reply With Quote
Old 03-12-2010, 09:09 AM   #4
Hottrucks
Hottrucks's Avatar
good point...now much drop are we talking here
Old 03-12-2010, 09:49 AM   #5
Jim_PA
Sure, a shorty header is better than manifolds, but I wouldn't run those unless the world was coming to an end, and they were the last headers on earth.
Jim_PA is offline   Reply With Quote
Old 03-12-2010, 10:16 AM   #6
Hottrucks
Hottrucks's Avatar
Ummmm...WOW...ummm why not they clear everything and get your exhaust above your frame rails..or is it a brand issue??
Old 03-12-2010, 10:36 AM   #7
olred68
olred68's Avatar
its a money deal I have a set of long tubes and I want to drop it 3" so not sure what I should do
Brandon
Old 03-12-2010, 10:40 AM   #8
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I am running Long tubes with a 4 1/2inch front and 5inch rear drop and I have to be careful with speed bumps even going up into my garage slight incline the cement is uneven by alittle and hits the collecter,My temp fix is a 1/2inch piece of plywood that I drive up on the passenger side each time I go in and out of the garage. If I knew how to weld I would cut 1 or 1 1/2 inches off each tube of the headders to bring them up, I think thats all I would need.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 03-12-2010, 03:28 PM   #9
Jim_PA
It's a performance issue. I don't care who makes them, shorty headers are just a step above ram horns.
See below for example. I'm sure this is one of many similar articles out there proving this point.
http://www.fourwheeler.com/techartic...ers/index.html
Old 03-12-2010, 06:04 PM   #10
Jeffs70
Jeffs70's Avatar
so my new hugger headers would just be simply like running stock manifolds then ? vs long tube headers? that are causing a problem with lowering our trucks.
I had long tubes before when I had a 4" drop and they just about dragged every place. so I went to huggers and haven't tested them as of yet. but not that I would be out of money cause they was free lol.
Jeffs70 is offline   Reply With Quote
Old 03-12-2010, 06:35 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... headers are all about scavenging exhaust gasses quickly. Shorty's defeat the purpose.
I have plain ol' Heddman Street Hedders, full length... they tuck up along the frame pretty nice. They're the ones I'll be using when I drop the rear 4" and the fron about 2".
My Dad has the same headers on his 1970 C10 and that thing is lowered 5" in the back, and close to 3" in front. They don't drag...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-12-2010, 06:47 PM   #12
olred68
olred68's Avatar
Well I have a set of flowtechs and I hope when I install they dont hang to low below the frame I want 2 1/2 drop spindles and 1" coils
Brandon
Old 03-12-2010, 04:22 PM   #13
ShredSled
ShredSled's Avatar
I'm kind of curious about this issue as well...
oh, and it seems those Gibson shorty headers are a very exteme example. The ones in that other link look more like mid-length, similar to Thorley Tri-Y's....
get it!
ShredSled is offline   Reply With Quote
Old 03-12-2010, 08:27 PM   #14
Jeffs70
Jeffs70's Avatar
Strut I am not sure its the pictures or not but in those pictures it looks to be as if those Thorley's Tri Y headers still stick down just as low below that tranny pan and frame as the Hedmans headers ?
Old 03-12-2010, 08:36 PM   #15
big mike71
big mike71's Avatar
The ones Big Al has on his truck do not hang down at all.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 03-12-2010, 09:02 PM   #16
Strut
Strut's Avatar
They do hang down, but there not near as low as the Hedmans. They dont hang down past the front cross member like the Hedmans.... These Thorley headers are the same part# as BigAls....
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 03-12-2010, 09:20 PM   #17
Jeffs70
Jeffs70's Avatar
ok awesome just what I was wanting to know thank you
Old 03-12-2010, 10:06 PM   #18
ShredSled
ShredSled's Avatar
yeah, if you look at those photos relating how low they are to the A-arms, it looks like those Tri-Y's give you quite a bit more clearance compared to that lower most primary on the Hedman's.
Also something else I'm kind of wondering is, what is the primary diameter on those Hedmans? 1 3/4"? Might have been a bit too much for your motor, stealing low-end and putting it up top. Might notice some good low-end gains with those more mid-length and smaller dia. 1 5/8" primary Thorleys.
get it!
Old 03-12-2010, 10:17 PM   #19
Jim_PA
Yep, the Tri-Y's are what I run too, and they definitely don't hang as low as the hookers I had on there before.
Might sell them though for some 1 3/4" long tubes to go with the 383. Still haven't decided. Not sure if it's worth it... leaning towards keeping the Tri-Y's.
Old 03-13-2010, 07:15 AM   #20
Jeffs70
Jeffs70's Avatar
I found some headers as I was doing some searching maybe you all can do something with these for laying frame also http://www.clearimageautomotive.com/...%20Headers.htm
Old 03-13-2010, 02:42 PM   #21
ShredSled
ShredSled's Avatar
nice find! Those look very tucked!
get it!
Old 03-13-2010, 03:40 PM   #22
Jeffs70
Jeffs70's Avatar
Yeah I am thinking on getting those my self, wow they are pricey any more for headers.
Old 03-13-2010, 04:18 PM   #23
ShredSled
ShredSled's Avatar
no doubt! Esp. for mild steel, and the ceramic is another %50 of the cost added on! wow.
Gotta be a small production outfit that just doesn't push the volume needed to keep costs low.
You could probably get ARH to custom build you some stainless headers for about the same cost as those with the ceramic coating!
get it!
Old 03-13-2010, 04:11 PM   #24
Strut
Strut's Avatar
Here is those headers:
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
1972 Chevy C10 SWB
2008 Yamaha R1
