Old 05-10-2010, 04:17 PM   #26
Sublvr72
Sublvr72's Avatar
Re: what's necessary to do a big block swap?
Originally Posted by fishingjred73 View Post
No need look here 454/400 with low hump cab page 5 post #122
http://67-72chevytrucks.com/vboard/s...=271489&page=5
awesome! Thanks!
Sublvr72 is offline   Reply With Quote
Old 05-10-2010, 04:52 PM   #27
jgreene0717
Jason
jgreene0717's Avatar
Just got finished swapping out from a small block to big block on my 1971.
I used the tubular motor mounts from performance online, tubular transcrossmember from classic performance, and a set of Hedman part #HED-69136 headers and it bolted right in place. Only issues I had was with clearance to radiator gets a little close when using a long water pump when bolting engine in front holes on frame rail. I moved my motor back and redrilled holes in frame rails to give me more radiator to water pump clearance. Not sure about yours though with the serpentine setup you will just have to bolt it all in and see.
jgreene0717 is offline   Reply With Quote
Old 05-10-2010, 05:08 PM   #28
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done the big block, turbo 400 swap into low hump cab trucks before and both trucks needed fresh cab mounts to get decent clearance between the floor and trans. Old saggy mounts allowed it to rub, new mounts gave enough clearance to pass your hand between the floor and trans.
Old 05-18-2010, 10:36 PM   #29
Sublvr72
Sublvr72's Avatar
progress-
getting the motor ready to drop in...
Old 05-20-2010, 02:18 PM   #30
Fitz
My truck is also a low hump cab with a turbo 400 and a big block installed...everything fit without any problems.
Fitz is offline   Reply With Quote
Old 05-23-2010, 03:35 PM   #31
Marc33
Marc33's Avatar
I am starting this same project this week. I have a 71 gmc 2500 2wd 350/350 and I am going 454/350. Looks like I will be having some fun.
Thanks for the good info.
Marc33 is offline   Reply With Quote
Old 05-23-2010, 05:23 PM   #32
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Originally Posted by Sublvr72 View Post
big block motor mounts.... check
big block headers.... check
big block.... check
trans.... check
still need...
intake manifold
carburetor
fan
auto x member
fuel pump
AT radiator
Hey feller, I've got a factory four barrel intake and good quadrajet carb, fuel pump and clutch fan that came off my '83 454 in my '69 truck if you're interested. I may have some other stock big block stuff.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 05-30-2010, 09:44 PM   #33
Sublvr72
Sublvr72's Avatar
progress-
big block almost ready to drop in, just waiting for a few more pieces.
self powered 69 Panel!
Old 07-13-2010, 02:44 AM   #34
19stepSide72
wanna be 67
19stepSide72's Avatar
that last picture looks like uncle kracker poking up through the engine bay.
19stepSide72 is offline   Reply With Quote
Old 07-13-2010, 02:50 AM   #35
Sublvr72
Sublvr72's Avatar
motor's been in for awhile now, still need to work on getting the trans in.
Old 07-13-2010, 02:09 PM   #36
WIDESIDE72
WIDESIDE72's Avatar
You will want to swap that TBI specific distributor for an older HEI with vacuum advance. Or your old SB point dist will work, if you have clearance issues with the large cap HEI.
I would use a Pertronix or similar.
WIDESIDE72 is offline   Reply With Quote
Old 07-13-2010, 02:27 PM   #37
BarryB
BarryB's Avatar
Yeah thats what I was going to mention also, If you use a MSD igniton box such as a 6A or 6al, you can use just about any distributor, since only the pick ups are needed with one of those. If not your gunna need an older non computer Dizzie. Have you gotten an auto Xmemebr yet? I have one that I'm not using. I'll give somebody a good deal. PM me if you need one.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-13-2010, 05:28 PM   #38
Sublvr72
Sublvr72's Avatar
yeah, I'm getting a new distributor and yes I found an auto x member from my old 74 that fits so I got that covered!
Old 07-26-2010, 10:44 AM   #39
clos69
Its Topless Season!!!!
clos69's Avatar
Any updates? How much clearance do you have with the serpentine setup to your rad? R u going to run electric fans or can you run a clutch fan? Subscribed as I am going to run a similar setup on my 77BBC.
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 04-08-2012, 12:23 AM   #40
WIDESIDE72
WIDESIDE72's Avatar
I know this is an old thread, but my pops and I are contemplating swapping the 6 cyl/ 3 ott in his 71 GMC for a 73 454 and a mid 80's 700r4. I still have the 73 donor and was thinking I would use the clamshells from it. Does anyone know if the 73 radiator wil fit?
Old 04-08-2012, 12:27 AM   #41
sameyrasmea72
sameyrasmea72's Avatar
I am almost positive it won't, but someone else will chime in.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
