Old 05-03-2010, 04:09 PM   #1
Sublvr72
Sublvr72's Avatar
what's necessary to do a big block swap?
My buddy is sending a 89 chevy 2500 to the scrapper and it's got a 454 and turbo 400 trans that he's gonna give me for cheap. What's needed to get this swapped into my truck?
are the motor mounts the same or will they need to be changed? Any other problems I might run into?
I'm trying to get everything together before the swap so it goes as seamlessly as possible.
I'm already pricing out intake manifolds to swap out the TBI back to carb, and I'm looking for some headers as well.
Sublvr72 is offline   Reply With Quote
Old 05-03-2010, 04:25 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: what's necessary to do a big block swap?
I've got some BB headers and BB motor mounts if you decide to go that route...others will chime in with exactly what is needed, if anything else.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-03-2010, 04:30 PM   #3
Sublvr72
Sublvr72's Avatar
what do you want for them?
Old 05-03-2010, 04:33 PM   #4
70stroker
70stroker's Avatar
when i was doing this swap in my 70gmc 2wd i was searching around also. everyone told me they were differnet motor perches. I measured 5 times and they seemed the same to me. So i put it in just to see. I have had no problems runnin my perches off my small block. for what its worth.
70stroker is offline   Reply With Quote
Old 05-03-2010, 04:44 PM   #5
Fitz
Aside from motor mounts and frame stands,
be sure to take the entire serpentine belt drive,idler and all of the bracketry power steering pump, A/C compressor, idler and pulleys. You didn’t say which motor you’re running now so I’ll assume a small block, which means you’ll need a larger Radiator. I doubt a fan & fan clutch from 67-72 is going to be compatible with the belt drive on that motor so you may want to think about an electric fan.
The stock power brake booster is 10 in in diameter and is probably going to interfere with the valve cover on that side so you might need a smaller diameter booster if you’re running power brakes. I don’t know which starter you have on that motor but the large housing starters almost fill the exhaust path on the passenger side so you might need a mini starter.
Fitz is offline   Reply With Quote
Old 05-03-2010, 05:08 PM   #6
Nova70
Nova70's Avatar
You can pretty much drop it right in if you wanted to. I would suggest putting BB mounts in as they're a little beefier.
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 05-03-2010, 05:12 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
money
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-03-2010, 05:43 PM   #8
cdowns
cdowns's Avatar
4core radiator is nice for a BB
Old 05-03-2010, 06:23 PM   #9
Sublvr72
Sublvr72's Avatar
I should probably clarify that... I've got a 307 and 3 speed. The goal is to pull out the motor and trans in my truck, and bolt in the motor and trans from the 89. The 454 is being pulled from a running truck so everything is there. Serpentine system, accessories, mechanical fan, etc.
My truck is currently drum brakes so the booster shouldn't be a problem yet.
So as for the motor mounts, the big block will fit right into the small block mounts?
Old 05-03-2010, 06:49 PM   #10
cdowns
cdowns's Avatar
you'll need to remove the manual tranny crossmember and get an autotranny crossmember// you'll probally need to have a driveshaft built// when removing from the donor vehicle take the driveshaft so you can at least salvage the yoke that goes to the tranny
Old 05-04-2010, 03:48 PM   #11
Fitz
You will still need the big block frame stands and mounts....the small block mounts will bolt onto your 454 but the frame stands are too close together to accept them.
Old 05-04-2010, 04:04 PM   #12
67/72junkie
you can use 73 up frame stands and clam shell engine mounts.only requires drilling a couple holes .save your self some cash.
67/72junkie is offline   Reply With Quote
Old 05-04-2010, 04:06 PM   #13
Sublvr72
Sublvr72's Avatar
ok, I found some big block frame mounts and some headers from a member here. Aside from that and the trans cross member, the rest is all bolt on?
Old 05-04-2010, 04:26 PM   #14
67/72junkie
bb auto trans linkage,I have for $75 complete.If you have pwr steering you will need to have the metric ends on the sector end of the lines changed to standard.
Old 05-06-2010, 11:53 PM   #15
Sublvr72
Sublvr72's Avatar
got the motor and trans pulled from the donor truck!
Now to pull my 307 and 3 speed
the TH400 was rebuilt 4 years ago and hasn't been driven since.
Old 05-07-2010, 06:34 AM   #16
LONGHAIR
You are going to need to swap in a radiator that has the auto trans cooler too....and what about the induction system? Are you planning on running that TBI or converting to a carburetor?
These "for cheap" swaps have a tendancy to get spendy...
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-07-2010, 07:34 AM   #17
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
your going to need to wire up the trans shift switch...( it maybe on the peddle of the parts truck)..do your self a BIG favor..take a week and clean and paint everything...put you new carb on get rid of all the polution stuff and if your going to run the stock exhaust maniford put new studs in..it should look like this...it will make the install go much easyier
waiting for the pics to upload I remebered the feed for the HEI needs to be 12V and check the oil sending unit so you can hook it up to your gauge..save the line that gos to the power barke booster you'll kick yourself later if you don't..its the little things that will slow you down and make for 10 trips to the parts store
notice the new mounts and stands sitting there
Hottrucks is offline   Reply With Quote
Old 05-07-2010, 08:35 AM   #18
junkyardjohn
junkyardjohn's Avatar
SORRY DONALD.. I HAVE TO DISAGREE. 73 UP STANDS ARE TALLER & REQUIRE ABOUT A 1" SPACER ON THE TOP OF THE FRAME RAIL ON OEM CROSSMEMBER ASSY.s (BEEN THERE.. DONE THAT). NOW IF THE CROSSMEMBER ASSY. HAS BEEN REPLACED WITH A 73 UP TO GET THE DISC. BRAKES... SURE.. THEY'LL BOLT RIGHT IN. OTHERWISE PEOPLE WOULD BE USING THESE $20 STANDS INSTEAD OF PAYING $200 FOR THE 72 ONLY BB STANDS. JOHN (WHEN ARE YOU COMMING THIS WAY TO BUY ME THAT STEAK DINNER & A BEER?) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-07-2010, 08:54 AM   #19
Sublvr72
Sublvr72's Avatar
I'm aware of the radiator, I've got a single core radiator at the moment so that's gonna be first to go when the motor gets swapped. I'm going to convert to carburetor, so intake and carb are on the list as well.
I already realize this isn't going to be a cheap swap, but I guess the end result should be worth it.
Old 05-07-2010, 09:29 AM   #20
Hottrucks
Hottrucks's Avatar
wish you where closer I have a bunch of parts to get you rolling they arn't great but usable things like a straight auto column ( your going to need the linkage parts or you could go with a locar floor shifter and leave yours)a 3 core rad and auto X memeber...dam...but most of that can be found in the bone yards or from local memebers...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 05-07-2010, 09:39 PM   #21
Shyguy
Junior Member
Shyguy's Avatar
When we put a '73 454 in my '71 with a old style 4 speed we used BB motor mounts and stands from a '74 C-20.
We did have to drill new holes, but the engine and transmission works great together without having to change the drive shaft.
One mistake we made is we used the stock starter instead of a mini starter so the engine has heat soak problems.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-09-2010, 04:42 PM   #22
Sublvr72
Sublvr72's Avatar
big block motor mounts.... check
big block headers.... check
big block.... check
trans.... check
still need...
intake manifold
carburetor
fan
auto x member
fuel pump
AT radiator
Old 05-09-2010, 04:58 PM   #23
sameyrasmea72
sameyrasmea72's Avatar
A BB/th400 truck also had a high hump cab floor. I don't know if you will have clearence problems or not, but there has to be some reason the factory BB trucks have a high hump.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-09-2010, 05:27 PM   #24
Sublvr72
Sublvr72's Avatar
hmmm... I guess we shall see when it goes in... Worse case I'll cut the floor and raise it up
Old 05-09-2010, 08:39 PM   #25
fishingjred73
fishingjred73's Avatar
No need look here 454/400 with low hump cab page 5 post #122
http://67-72chevytrucks.com/vboard/s...=271489&page=5
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
