05-13-2010, 03:12 PM | #26 | |
Re: Anyone else have to fix a CPP bolt in notch?
Moving on... I welded the inside seams. Im not a professional welder and my welds are not as pretty. Simply MIG welded inside seams with teh welder set for 3/16 steel (so I dont melt through and mess up the pretty welds) Good penetration: Thickness of the weld bead that you guys say will interfere with the frame rail: The impossible: Still fits...both sides with plenty of room for a fatter weld. Last edited by 8mpg; 05-13-2010 at 03:14 PM. |
05-13-2010, 03:18 PM | #27 |
let's review: you're bolting a 1/4" thick part with no less than 8 grade 8 fasterners to a cold-formed c-frame section that is approx. half as thick and your more concerned about the 1/4" part being weak? um-kay.
05-13-2010, 03:31 PM | #28 | |
My truck isnt a race truck by its going to have a solid 400-450hp and damn near 1000tq. So yeah...I might worry a bit about the strength of the piece. Im not running a 350 with 300hp and 280tq. Please read this thread: http://67-72chevytrucks.com/vboard/s...engineer+notch Lots of different notch calculations based on materials and its strength compared to stock frame strength. Last edited by 8mpg; 05-13-2010 at 03:38 PM. |
05-13-2010, 03:47 PM | #29 |
I'm with you 8mg, right or wrong the notch you bought is no way goin on one of my build ups as it arrived from the company. It's your truck and if you think it needs better welds i say get to it.
R.I.P. Killer 71 10/26/07 |
05-13-2010, 03:53 PM | #30 |
1.) Actually, the c channel gets its strength from the single vertical section, not the two parallel sections. Grab a 2" x 4" and give it a flex. Note the direction of flex in relation to the sides.
2.) I've seen these notches very very closely. 3.) I have bought & installed more than 1 set of these notches. 4.) Even with the "bottom half ripped off" the 1/4" thickness is still stronger material than the underlying 1/8" thick cold formed c frame. Basic physics, my man. 5.) The fact remains that there has never been a reported failure due to a bad weld. But of course with 1,000 ft. lbs of torque out of 400-450 h.p your's could possible be the first. |
05-13-2010, 03:53 PM | #31 | ||
Since you are the sole authority on these trucks and notch God, please do the mechanical engineering and put out a model. Id like to see your "basic physics". I forgot, only you can possibly know if there was ever a failure with a CPP notch. Just another thought...the fasteners just hold the darn thing on the truck...it doesnt give the strength to the notch. Last edited by 8mpg; 05-13-2010 at 04:01 PM. |
05-13-2010, 04:25 PM | #32 |
You're the one telling the manufacturer how to make their parts but somehow I'm the expert? LOL! Good one.
Would like the model it in SolidEdge or ProE? Get back to me, k? |
05-13-2010, 04:37 PM | #33 | |
I dont know why you are acting like someone pissed in your cheerios. This was a simple concern that I voiced and here you come nut swinging in to make me look like a fool. Like many people in the thread I pointed out I was suprised to see a 1/4" thick 4" pipe notch would reduce the frames integrity to 25% of the original strength. Also amazed by adding a 1/4" boxing plate shown in the thread with a 1/4" thick pipe notch still only leaves 75" of the strength. So by comparison (I know it is not a direct comparison) you would think that the CPP notch would fit close to this category. 1/4" thick notch and 1/4" steel backing plate. The difference is the lower parts that bolt to the spring plate and the frame behind the notch. With it being 1/2 way welded on, there is no way it adds the remaining 25% of the strength. So I welcome you to post a model with load testing and compute the numbers to show the strength compared to a stock frame. Its its 90% or more of the strength of the original frame, great. I highly doubt it will. Then substitute some poor welding in the notch and show those numbers. Until you have some fact, please just shut the hell up. You remind me of Obama... "uhh...uhhhhhhh... my fellow people...you will just have to trust me... install it on your truck and you will see what happens. Im not exactly sure what that is...but... we will see. My opinion is uhhh... based on nothing more than my opinion. Please dont look into the facts and educate yourself...just believe me" Last edited by 8mpg; 05-13-2010 at 04:40 PM. |
05-13-2010, 04:47 PM | #34 |
LOL ... kids.
05-13-2010, 04:49 PM | #35 |
Irony
I take it that you will not be doing the model to prove your point? Im working on getting a couple people to do models to show the results. Whether or not Im right or wrong. Last edited by 8mpg; 05-13-2010 at 04:50 PM. |
05-13-2010, 05:15 PM | #36 |
Catchy title goes here..
III. No pissing matches. Its fine to disagree, but once a thread has run its course, and degenerated into little more than an insult fest, it will be locked. While this will require a judgment call by the Administrators & Moderators. The members of this site can keep our moderating to a minimum by exercising a little discretion and self- control. Excessive profanity will lead to a 24 hour suspension at the Administrations discretion.
IV. Pure trolling, either to upset someone or simply for your personal enjoyment, is strictly prohibited. If you're here to cause trouble, it will be a very short stay. Immediate BAN and you will be reported to your ISP http://67-72chevytrucks.com/vboard/a...t.php?f=34&a=9 Agree to disagree, discuss and move on. The taking it to pissing match level only results in more work for us and less fun for you. |
