#26 | ||
Re: CPP notch problems with quality...round 2
Stopping a 6000lb trailer is no big deal...trailers have brakes. My old trailer would slow down the truck faster than the truck brakes would. People tow way more than 150% of their trucks weight. Heck, my buddy had his Dodge dually over 40,000gcvwr with a 8500lb dually. Never had a problem. Quote:
If you have a welder and you are confident in welding teh inside seams, get the CPP notch. It was $102 shipped to my door off ebay. |
#27 |
the porterbuilt unit and the cpp unit are two totally different things.
just to be fair. |
#28 |
You are correct..the Porterbuilt will be fully welded and much stronger with a top cap on the frame rail to finish out the "C" on the frame.
For PharmD...here is a link to their vendor section. http://67-72chevytrucks.com/vboard/s...d.php?t=366945 Pic of theirs: ![]() |
#29 |
Factory Strippers Rule!
![]() Join Date: Mar 2009
I dunno, I think if you're that worried and want to tow a trailer that big, maybe you should have left the thing stock. And like Longhair mentioned, the notch might be the least of your worries if you plan on towing with a shortbed... panic stops or sudden lane changes with a heavy trailer and short wheel base = bad day. Even if you have the power to pull it, there's a lot more to it than that. I don't want to be negative, especially to someone who likes truck like I do, but you need to make sure ALL your bases are covered.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
#30 |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Just because you can doesn't mean you should....
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
#31 |
As previously mentioned, 8mpg would use his 06 Dodge 2500 Megacab Cummins for the HEAVY loads. He just wants to be able to use his lowered short wheel base truck as a truck.
#32 | |
I personally wouldn't tow 1k lb tongue weight 6k lb trailer as 8mpg stated with a lowered c notched short wheel base truck. If you have a 3/4ton diesel truck I don't see why you would even want to risk towing 6k lbs with of a modified shortbed... Our YukonXL is rated to tow just shy of 8k lbs and I have towed near the GCVRW with it. It did it safely but it was compromised in its ability to stop and accelerate to the point I didn't feel comfortable towing like that. I tow a lot with my car trailer and my camper and no longer use the half tons sitting here to tow with when I have a much more capable and safer truck to do so with. Yeah it might not be as cool as a cummins powered nv4500 equipped lowered shortbed on bags but it sure is a lot safer.
#33 | |
Im not trying to argue with you but the frame can take it, the suspension can take it...why not? At most, Id be pulling an old mustang on a car hauler or making a trip to the steel yard. Im not planning on pulling everday as a work truck, but I want to have the ability to. The notched frame wouldnt be a concern as long as the company does their engineering and builds a quality piece. There are tons of step notched frame duallys out there that pull huge triple car trailers. If they can pull that, a 69 chevy can pull a single car hauler with a moderate load. Last edited by 8mpg; 05-18-2010 at 03:04 PM. |
#34 |
Java Mechanic
I don't know how to express this correctly but --- the biggest problem with towing heavy loads with a short wheel base vehicle is not neccesarily a lack of strength or power but stability. The trailer exerts yaw force on the hitch. This is why heavy haulers have long wheel bases or use a 5th wheel mount that puts the site of this force closer to the center of mass of the tow vehicle.
I do not know if a Mustang on a flatbed is too much for a shortbed truck or not (I'm not that kind of engineer!) but I thought I should bring up this point. I'm not saying you are wrong to try it ... I'm just no expert on the issue. I'm only saying that there are concerns to keep in mind that the strength of the frame and thrust of the engine won't solve. On the plus side; I don't think you'll have an issue with frame strength with the repair you did to the notch plate.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#35 | ||
There is nothing wrong with complaining when you believe you have recieved an inferior product but lets look at some things...
You said you aren't a professional at either of these but you have determined that both professional welders and engineers have failed to do their job properly. Quote:
I don't intend to stir the pot but it sounds like you are bashing a vendor based on what you perceive to be a bad part and not on what you know to be a bad part. It is not necessary to always have 100% penetration on a weld. A 50% penetration weld does not mean it is a bad weld. It all depends on the particular application. |
#36 | ||
Did I determine they dont know how to do their job? I guess I did. Considering the POOR penetration in a weld, and professional welder will tell you that it is a poor weld and would never pass a welding certification test. Again, is their engineer correct? Who knows, the only answer they came up with was Quote:
How can you tell if these frames can take towing a car... LOOK AROUND. There are plenty of people that have posted pictures of their trucks pulling loads. Think about this...if you have 2 pieces of steel you weld together that are 1/4" thick and you get 50% penetration. The steel connecting them is 1/8". Do you really think that 1/8" is enough? If it were, why do they boast their 1/4" thick steel brackets and dump on the other competitors 3/16"? How can you look at the bracket and possibly think that it is a quality part? My buddy builds custom trailers for a living and just laughed out loud at the part. As a business owner that builds trailers from a single car hauler to 53' industrial 18 wheeler trailers, he knows his fair share about proper welding. He said it was a joke and to get my money back. He himself is a certified welder and employs over a dozen certified welders. Last edited by 8mpg; 05-18-2010 at 04:32 PM. |
#37 |
oh...and hopefully in the next week or so we will have an idea on the strength of these brackets from and outside engineering perspective. Third party unbiased opinion.
#38 |
Why didn't you just have your trailer buddy build you some notches?
#39 | |
I could have built a notch but its much much easier just buying one. I have been trying to say, the fit of the notch is good. I like the product but find the weld just lacking. I dont think anyone seems to understand this simple point. Good product, just needs to be welded better. My first thread was asking if anyone had to fix one before. I wasnt here to bash the company and ridicule them. CPPJeff tried to reply to my comments and other board members concerns and he was wrong. Then he asked his engineer who was wrong. They further said other companies have inferior products compared to theirs. My whole point was just the darn welding and that it needs better quality control and the inside seam should be welded. This has turned into people tellin me im dumb and worry to much...just "trust" the people that say their welds are fine. I cannot except that the welds are fine, that the engineer is correct or that Jeff was correct on why the inside of the brackets are not welded. |
#40 |
6>8 Plugless........
![]() Join Date: Sep 2007
Wow, people actually think these newer 1/2 ton vehicles compare to an old 1/2 ton when it comes to hauling? Seriously? Does anyone actually work on these newer ones or actually try to use them? 8mpg, sorry about your bad part. Nice fix. Good luck on the rest.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#41 | |
Any thoughts on using a fuel cell with diesel? Im worried since it doesnt have baffles that its goign to foam up. |
#42 |
#43 | |
#44 | |
The brackets will be load tested on the computer by a couple engineers to compare original frame strength and a frame with a CPP notch in the same scenario. This will be a computer model tested to compare original vs one with the CPP notch. Not a full load test with a full suspension.
#45 |
I am interested i seeing the results of the tests they do, as this is what i do for a living but with aircraft.
I am assuming they are going to build finite element models and apply similar loading that the truck would see if it was loaded with a trailer. I would also like to know what loading they are using to test the models with. It will be hard to model the CPP notches with the welds they have. They will need to apply some type of knock-down factor or factor in the stress riser that the welds are creating since they do not have good penetration. the welds are definitely the weakest link in this product, which is an extremely poor design for a structural part. I didnt know about PB's notchs when i bought mine. i would have bought those. CPP welds should look like PB's. I bet CPP's parts are roboticly welded, there aren't many certified welders that would let a weld like that go out the door. I quit buying from CPP awhile ago after i learned why they tripled the price of their pinion shims. |
#46 |
why did they triple the price of their pinion shims?
#47 |
I was told by a sale's rep (before Jeff came along) that they changed vendors, changed materials, and where now stamping the the CPP logo on them. The rep went on to say their cost was twenty-something dollars and so they were selling them for $69. They still had not updated their catalogs or website to reflect the price/product change.
I threw my CPP catalog away after that phone conversation. I had already purchased my c-notch's, drop blocks, and front shock brackets from them. Last edited by dznucks; 05-19-2010 at 09:15 AM. |
#48 | |
Talked with Nate at Porterbuilt and he said there will be a new notch design coming from them. After talking to him, it sounds VERY stout and will be much better than the CPP unit. Sounds like it is worth the extra money. I might sell my frame and start with the other one I have just so I can use his notch. LOL.. I thought you were talking about the notch..not the pinion shims. Last edited by 8mpg; 05-19-2010 at 09:23 AM. |
#49 |
Don't forget to have your engineering buddies run some numbers on Nate's notch too to make sure it meets your needs....
#50 | |
Happy to be here
![]() Join Date: Mar 2000
This still sounds like a CPP witch hunt to me.
