Old 05-17-2010, 09:03 PM   #26
'72customdeluxe
Re: Edelbrock Carb?
Originally Posted by bigguy69 View Post
i have an edelbrock carb, and to be honest i dont know how to adjust it. it takes spells where it will flood and then if you get on it it will act like it is running out of gas. i took it apart and cleaned it, checked the float level and still have problems. it dosenet do it all the time it just takes spells. but when it is in a good mood it runs great. does anybody got any tips on how to adjust or rebuild one of these things? sorry i didnt mean to hijack.
edelbrocks are sensitive to pressure. On my blue truck even a new oem replacement fuel pump lead to overfilling (not a float height problem) which was fixed with a pressure regulator. Using a different accelerator pump position helped with hesitation
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 05-17-2010, 10:00 PM   #27
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Edelbrock Carb?
the edelbrock 1406 has been a very good carb for me i have 3 in use now and no problems, i bolted them on set idle and forgot them i love quadrajets too though, holleys are for fords
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-18-2010, 11:31 AM   #28
bigguy69
dazed and confused
bigguy69's Avatar
Re: Edelbrock Carb?
thanks for the input. i will give it a try.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-26-2010, 10:13 PM   #29
71enthusiast
71enthusiast's Avatar
Re: Edelbrock Carb?
Thanks for all the help! i just have one more question would i need a throttle lever adapter for an edelbrock?
71enthusiast is offline   Reply With Quote
Old 06-26-2010, 11:05 PM   #30
silverstreak
Re: Edelbrock Carb?
To the best of my knowledge, the 1483 is used on Ford automatics only.
Scroll to the bottom of this link. There are some for Chevy's if you need any.
http://www.edelbrock.com/automotive_...throttle.shtml
Have you tried the factory brackets you have on the truck already?
silverstreak is offline   Reply With Quote
Old 06-26-2010, 11:15 PM   #31
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Edelbrock Carb?
I take it, that you are installing this on a early Seventies truck. Does this truck have the old style metal rod accelerator or does it have a throttle cable? I would purchase the carb and from there I would look at what you have and then expand from there. If you go to Edelbrok's website, there are other items that would be good to help install your carb, but I would imagine that the majority of it will be in the box when you purchase it. You may want to order an Edelbrock catalog for a more defined source of parts available. I picked up three or four of them on the HRPT, this year so the new ones are out.
Frank
piecesparts is offline   Reply With Quote
Old 06-26-2010, 11:40 PM   #32
71enthusiast
Re: Edelbrock Carb?
My truck has a throttle cable on it its a 71 model I just wann make sure I have all I need tohave my new carb running when I get it. I know I need a adapter with it though
Old 06-27-2010, 01:06 AM   #33
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Edelbrock Carb?
if your looking for a acc. cable,kickdown bracket i have used these with no problems can get them at advance, auto zone, etc..
Proverbs 3:5,6
Old 06-27-2010, 01:22 AM   #34
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Edelbrock Carb?
I've had my 1406 on my truck since 2003. About 30,000 miles later, still running well.
It's been a long time since I installed mine, but I think edelbrock recommends running a spacer if you're using a stock manifold.
I agree about the pedal. Get it on the truck and go from there. I was able to fab mine up with stuff I had laying around.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
