Edelbrock Carb?
What type of edelbrock carburetor should I get for my 1971 350 chevy?
Re: Edelbrock Carb?
i would stay away from Edelbrock carbs. I never had any luck with them. I would use a Holley or Demon. a 650 should be about right for you.
Re: Edelbrock Carb?
1406 600cfm
Re: Edelbrock Carb?
The newer Edelbrocks are fine. I would say a 600 to 650. They are ready to run right out of the box for a stock motor.
![]() Join Date: Apr 2000
Re: Edelbrock Carb?
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#6 | |
Re: Edelbrock Carb?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 05-16-2010 at 08:12 PM. |
Re: Edelbrock Carb?
Need more info...is it a stock 350....a 500 hp 350....etc...if its a stock one and you must have a eddy carb, use a 1406.
Parts and more parts
Re: Edelbrock Carb?
It is your choice, but I have run the Carter and the Edelbrock AFB design carbs for quite some time (Believe it or not, they are the exact same carb design) and managed to find the right combination for driving on the highway with them. I have had good luck with them.
If you are running a basically stock engine and want to get around without a lot of problems, then you might consider an Edelbrock 600 CFM or 650 CFM size. Many want to go right to the 750 or 800 CFM sizes but that size can cause problems with your performance and not gain ANY fuel milage. As I stated, I have run the AFBs for awhile and I did try the 750 cfm size on my 383 stroker engine in my 84 GMC---the carb created one heck of a tall top end ability---allowing me to run up to the 6000 RPMs without any loss of fuel, but drivning around citiy streets it caused my engine to bog and slobber badly. I then communicated with several carb manufacturers (Holley, Edelbrock, and Barry Grant) and their recommendation was: For a heavier vehicle (my truck weighs in around 4000 lbs) a smaller CFM rating will give you better air flow velocity. That is what makes the engine work more efficiently not the overall carb size. They were all in agreement and so I went to a 650 CFM Edelbrock AVS carb and even though I lost some top end RPMs (Not much) I now have a carb that runs my engine well on the street. The gaggle about whether or not to run a vacuum secondary is a worthwhile consideration, but as I also stated, I worked out the needle and jet combinations on my carb to where the issue is not a problem with the mechanical secondarys on my truck. What you buy is your choice, but be smart in carb size and don't overdo it. I have a stroker engine in my truck and my son has a stock 350 in his truck and we are running smaller carbs to get the daily driving ease, but the two trucks do run quite well.
Frank Last edited by piecesparts; 05-16-2010 at 08:21 PM. |
#9 | |
Junior Member
Re: Edelbrock Carb?
It really sounds like you have done a lot of research and are very knowledgeable of carbs and which one should be used for different engines. I figured since you are so informed I would ask what carb would be good for my '73 stock 454 with headers. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Edelbrock Carb?
I recently installed a 1406 edelbrock 600 cfm elec. choke carb on my stock 350 in my 70' suburban. I am pleased with the performance of the carb and have had no problems so far. I would recomend it for a stock engine it would work very well
Re: Edelbrock Carb?
I only run Holleys and never had a single problem. They run awesome right out of the box and are very forgiving of variables like engine size, cam, intake manifold, exhaust system, etc. unlike Edelbrock carbs that need a lot of loving and massaging to make them work right.
Gearhead and audio junkie
Re: Edelbrock Carb?
Never really had luck with my 1406, never jetted it right, always ran lean. Never could justify buying a jet kit which cost 1/4 of the cost of the carb. Buy a holley 4160 600 cfm with vacuum secondaries, you'll be much happier with it.
#13 |
Re: Edelbrock Carb?
If people have a stock or mild street engine, nothing beats a reconditioned factory quadrajet, the small primary butterflies will give you much better fuel mileage than any aftermarket carb, more so if you find one that came off a small block. they are calibrated for that engine, unlike a aftermarket carb that will have a generic fuel curve that will work "ok" on all, also the fact that the driveability will be better and there is no goofing around with trying to make things work.
#14 |
Re: Edelbrock Carb?
1406 ...you will like it!
#15 |
Re: Edelbrock Carb?
I just installed a 1406 600 cfm on my 1971 stock 350 and love it! Next step Edelbrock performer series intake! Gained 2 mpg on my daily driver.
Just my .02 |
#16 |
Re: Edelbrock Carb?
I recently installed a 1406 and still have intermittent slight power loss after the engine is warm - the engine just doesn't want to rev. I'm thinking the issue is something else though and I've been scratching my head to figure out what.
#17 | ||
"I ain't nobody, dork."
Re: Edelbrock Carb?
Holley... or go home...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#18 |
Re: Edelbrock Carb?
I took the backfiring flooding Holley off.
#19 | |
Re: Edelbrock Carb?
See Attached http://www.buicks.net/shop/reference/carb_cfm.htm
Frank |
#20 |
![]() Join Date: Jun 2006
Re: Edelbrock Carb?
I put a edelbrock 650 Thunder series AVS carb on my 68 with a 350 built similar to a 330 hp gm crate motor and ran great right out of the box.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#21 |
Re: Edelbrock Carb?
If i do get a 1406 600 cfm edelbrock carb then do i need to get a new intake manifold to fit it?
#22 |
Re: Edelbrock Carb?
'77+ quadrajet
'72 cheyenne super step, '05 long bed gmc |
#23 |
dazed and confused
Re: Edelbrock Carb?
i have an edelbrock carb, and to be honest i dont know how to adjust it. it takes spells where it will flood and then if you get on it it will act like it is running out of gas. i took it apart and cleaned it, checked the float level and still have problems. it dosenet do it all the time it just takes spells. but when it is in a good mood it runs great. does anybody got any tips on how to adjust or rebuild one of these things? sorry i didnt mean to hijack.
members met: redbaron69, billsbowtie,nc67 |
#24 |
Re: Edelbrock Carb?
Well, I think I fixed my issue. Turned out I think it was a vacuum leak. The nuts holding the carb down had backed off a little bit and needed tightened. Suddenly the fast idle doesn't jump up so much on a cold start and the truck runs well when hot.
I love it when it's easy. |
#25 |
Re: Edelbrock Carb?
I've worked with Quadrajets, Holleys and Edelbrocks and they are all fine carbs. Everyone has their favorite style of music and it's the same with carburetors. It's all just a matter of what someone is used to and what they prefer for their own personal reasons. All three brands have been used on mild street motors and high horsepower engines as well.
Your original question was "What type of edelbrock carburetor should I get for my 1971 350 chevy?" I agree that the 1406 (or Thunder series version) would probably be the best choice out of the Edelbrock line if your engine is a mild to stock build. Every engine is different, so don't be suprised if it will need a bit of tuning to get it just right. |
