Old 06-04-2010, 11:13 PM   #26
trusty72
trusty72's Avatar
Re: Help me spend 2500 on my engine.
Those are all good ideas, but for 2500 you could peice together a pretty nice street turbo setup with either blow thru carb or mega squirt econo injection. ive seen 500 hp on an engine like yours that would last forever. Of coarse better pistons, rods and crank would be best, but keep the boost around 5 or 6 and have a blast. that way when you step up in internal engine parts later, you can up the boost for FREE horsepower!
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-05-2010, 04:39 AM   #27
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Yearone has just come out with a 350 small block that puts out 400+ horsepower for about 2900 bucks!
beebster is offline   Reply With Quote
Old 06-06-2010, 07:44 PM   #28
davebloomer
davebloomer's Avatar
im thinking about something along this line. Looks like I have everything I need there..... I think
http://www.summitracing.com/users/wi...f-3cc0a2d01172
davebloomer is offline   Reply With Quote
Old 06-06-2010, 08:09 PM   #29
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks good, I'd check to see if the pushrods you have are gonna work with that setup. I'd also get some new headbolts, and see if you need new rocker nuts. Where you gonna get a new converter?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-09-2010, 04:12 PM   #30
davebloomer
I was planning on a B&M from summit. 2400 stall. I'm actually gonna do a 700R4 swap after I finish with the motor so I'll buy it after that.
