Old 06-03-2010, 09:49 PM   #1
davebloomer
davebloomer's Avatar
Help me spend 2500 on my engine.
I've got 2500 I get to spend building my 350. It is a 94 model block bored .030 stock heads stock cam etc. Currently running just fine and I'd kinda like to leave the bottom end alone. (only about 6K miles on the motor) It is not a daily driver just a grocery getter and weekend cruiser but I'd just really like to be able to take it to the track and have fun with it. The 94 350 stock came with like 195 horse and I guarantee mine doesn't have any more than that. So if you had a stock running engine and 2500 to spend on it what would YOU do? It can be as wild as 2500 can make it. It has a 350 trans and 3.73 gears.
^ That truck wants to go fast.
davebloomer is offline   Reply With Quote
Old 06-03-2010, 10:06 PM   #2
Big-Blue
Big-Blue's Avatar
Re: Help me spend 2500 on my engine.
Aluminum heads and headers...
Or...pull the motor and sell it, take the cash and add it to the $2500 and buy the 400 horse YearOne crate 350 for $3000.
Big-Blue is offline   Reply With Quote
Old 06-03-2010, 10:13 PM   #3
crapy67
White wall terror
crapy67's Avatar
Heads, cam, intake, exhaust and the most over looked piece of the puzzle... the touq converter.
crapy67 is offline   Reply With Quote
Old 06-03-2010, 10:19 PM   #4
67/72junkie
Vortec heads and aluminum intake to match.Performance cam with hi rev lifters and true roller chain. depending on what you have now performance carb ,distributor, and headers.easy 350 hp and with 700 r and 373 will have hole shot and top end. for good street driving I would use performer rpm and 650 cfm carb
67/72junkie is offline   Reply With Quote
Old 06-03-2010, 10:23 PM   #5
frednoah
86 Scottsdale
TFS-K315-465-450 <--- Search it at Summit. It says Trick Flow claims 465 hp with this setup. You'd still have some change left for some headers.
frednoah is offline   Reply With Quote
Old 06-03-2010, 10:26 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
cam heads (alum. or vortecs) headers biger carb stall if you have it intake
John
1999 Toyota Tacoma 4x4
Old 06-03-2010, 10:28 PM   #7
davebloomer
oh yeah I have headers already. Keep the ideas coming guys... any sizes/brands on cams? what about heads?
I looked at the trick flow package and I must say I like it. What size stall will i need to get with something like that? Also how will my vacuum be for my brakes etc? I also use an air conditioner and I'm wondering if it will still idle with it on? I guess I didn't think you could build it that big with that amount of money so maybe I should say the limit is as big as possible that i can still enjoy driving it with the wife riding with me.
Old 06-03-2010, 11:20 PM   #8
srea76
srea76's Avatar
I agree with other post about selling the one you got and buy a new crate.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 06-04-2010, 07:01 AM   #9
silverstreak
http://www.holley.com/data/types/pic...2_SBC_ZOOM.jpg
http://www.summitracing.com/parts/WND-6500-1/
silverstreak is offline   Reply With Quote
Old 06-04-2010, 10:04 AM   #10
Put your money into aluminum heads and the valve train,including cam and timing chain.I`d go inside and run flat top pistons to bring the compression up to suit the heads,though.If not,I`m not sure the aluminum heads will give much benefit.I have $1,300 into a total rebuild with factory 64cc heads.I figure if I had gotten aluminum heads I`d be at about $2,500 and might have gone with more compression.
Old 06-04-2010, 10:11 AM   #11
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Assuming your 1994 block would be roller lifter ready, I would start there with a nice roller camshaft. Then there are a set of 64cc aluminum heads on ebay that sells for $650 all day long with free shipping. then get a good two-plane intake that's rated from 1500-6500 RPM and slap a good 600-650cfm Holley on it and your good to go!
Good luck.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-04-2010, 11:53 AM   #12
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Originally Posted by crapy67 View Post
heads, cam, intake, exhaust and the most over looked piece of the puzzle... The touq converter.
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-04-2010, 12:11 PM   #13
cdowns
cdowns's Avatar
i'd go for the matched edelbrock topend kit
Old 06-04-2010, 12:45 PM   #14
Tynee
I miss this truck.
Tynee's Avatar
Personally, if I had the $2500 to drop into my '93 block, I'd get it machined for a mechanical fuel pump, but then my electric is dieing again, so my advice may not be the best on here...
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 06-04-2010, 01:41 PM   #15
Doug Garland
Good luck.
See above? ... I agree. Since it is not a daily driver, I'd get the ZZZ 1st design roller from GM, it thumps more than the newer designs. Get the whole roller setup, spider tray, and make yourself a roller engine. The bosses should already be there in the lifter valley. Add those Patriot heads on Ebay. Intake, carb, and get a good set of headers, and a 2200-2400 stall and you are set.
Doug Garland is offline   Reply With Quote
Old 06-04-2010, 02:14 PM   #16
davebloomer
thanks for all the input guys
Old 06-04-2010, 02:42 PM   #17
C20-67_N_MO
Talking Re: Help me spend 2500 on my engine.
Your Welcome!
Heck we like to spend other peoples money!!
Good luck at whatever you decide and keep us updated!
Old 06-04-2010, 02:46 PM   #18
8mpg
8mpg's Avatar
Crate motor all the way... warranty...its built and done, just drop it in.
8mpg is offline   Reply With Quote
Old 06-04-2010, 02:58 PM   #19
davebloomer
I'm wanting to do this because I enjoy the work. I don't really wanna do a crate motor.
Old 06-04-2010, 05:45 PM   #20
davebloomer
http://www.summitracing.com/parts/TFS-K314-420-395/
http://www.summitracing.com/parts/BMM-20404/
I think this is what I'm going with.
Old 06-04-2010, 06:04 PM   #21
Sinister
Between Trucks...
Sinister's Avatar
Those Trickflow heads are angle plug which might not play nice with your headers.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-04-2010, 06:39 PM   #22
cdowns
cdowns's Avatar
and besides the angle plugs that kit is not ment for your motor // check the applications
http://www.summitracing.com/parts/TF...n/?prefilter=1
Old 06-04-2010, 09:44 PM   #23
davebloomer
oh yeah I looked closer earlier just didn't pay attention which one I linked to...
Thanks for the advice on the angle plugs I can only imagine the pain there.
edit: maybe i didn't pay close enough attention ever... that's why I'm glad you guys are here. I guess I need to do some more research on the differences in the blocks... I thought they were the same just the heads being different.... anyone care to prove me wrong please? I need to be clear that my truck is not throttle body injected. It has what I believe to be the factory centerbolt heads with a carb'd performer RPM intake. So I am unsure what would be the difference in the kit going in my block or an older one.
Old 06-04-2010, 10:21 PM   #24
cdowns
cdowns's Avatar
all these companys have tech lines// if you wish to get the most out of your money it pays you to get on the phone with the complete specs of the truck and what your hoping to achieve for a final product and talk to the real experts
Old 06-04-2010, 10:43 PM   #25
davebloomer
will do it. Thanks guys.
