#26 |
Re: vintage air
yes you can use the 5.3 compressor, it IS NOT a variable compressor....ive done this many times, also VA will tell you that IT IS covered with their warrienty, ive talked with them a few time about this subject, and they WILL stand behind their warrienty...all the kits ive ordered were directly through VA, and included the magnum 4, a direct fit condencer with dryer, either a bi-nary or tri-nary sw., vent styles of my choice, and a universal line/fiting kit...basically everything needed minus the compressor (cause i was useing the stock 5.3 one) shipped was about 1200$ IIRC
#27 | |
Re: vintage air
get a better deal thru Scotts Hotrods.We do have some great prices on all of there products. Justin |
#28 |
VA72C10
![]() Join Date: Mar 2008
Re: vintage air
and what would that deal be???
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#29 |
Still Learning
Re: vintage air
So is it settled? No problem using the stock compressor on the 5.3? I have already purchased a "complete" VA setup for our trucks. It came with the sanden compressor too, but I don't know if it will mount on an ls engine without fabbing custom mounting brackets. Would I be better off using it? sorry not trying to hijack, seems there a bunch of ls conversions going on here. very helpful info.
#30 | |
Restoration Virgin!
Re: vintage air
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#31 |
Re: vintage air
We will have all of our e-mails and p/ms done on monday for sure.
Justin |
#32 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: vintage air
1st you can use the LS compressor, I am and it blows cold just fine. Wire it externally from the PCM tho. The PCM just provides a ground.
If you have your VA set up and it has the Sanden Compressor and you dont have the ls compressor, contact Kwikperformance and get their brackets. I have an Old Air Products AC System and all is well.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#33 |
Devil's in the Details
Re: vintage air
Here's a writeup from Custom Classic Trucks where they installed a Gen IV in one of our trucks: http://www.customclassictrucks.com/t...ing/index.html
From what I've researched so far, the kit that is in the summit link is only the unit itself (unit, evaporator, brackets, wiring harness, heater control valve, drain kit and the defroster bits) You'd also need to buy a drier, condenser, hose kit, have the hoses crimped by a shop, buy the vents for the cab, a bulkhead and fittings, a compressor with brackets (unless you've got one already), a safety switch and the electronic control unit of your choice. Then 134a of course.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle Last edited by Beelzeburb; 06-14-2010 at 10:18 PM. |
