vintage air
What do i need to know about the vintage air magnum IV and adapting that to a ls motor? Is it better to order there compressor or to use a factory air compressor. Also Has anyone purchased there vintage air from summit?
Truck and auto performance nut
Re: vintage air
I think Summit just began carrying Vintage Air in the last few months or so?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: vintage air
no clue i got on there lastnight and found the whole setuphttp://www.summitracing.com/parts/VTA-671400-VUZ/
Re: vintage air
im not actually sure if its all there or what i need to make it work with the 5.3 im hoping 68 short step chimes in or someone that has messed with this
JRods Garage
Re: vintage air
thats pretty cheap isnt it???
That's right, it's Copper!!
Re: vintage air
That system is too big for our trucks. I used the Gen-II compact system in my truck. I fits behind the dash nicely without too much fab work.
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
Re: vintage air
well 68 short step used this magnum IV setup on killers truck just fine it can be done
Re: vintage air
VA72C10
![]() Join Date: Mar 2008
Re: vintage air
that's just for the core itself....still need the compressor, lines, bulkhead, vents, controller, condenser, drier, etc.etc.etc.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Re: vintage air
well will the stock compressor on a 5.3 ls motor work? or does it need replaced with there system
Re: vintage air
does anyone know any websites to order the complete kit off of?
Re: vintage air
http://vintageair.com/cat2007/51.pdf
They do offer a compleate kit for our trucks. BOOYA Ya do have to look around for the price list on their site a bit. but it is the summthin like $1200. and you have to go through one of their certified dealers. |
#13 | |
Re: vintage air
http://www.classicautoair.com/67_72_..._Chevy_AC.html |
#14 |
Re: vintage air
ya i was looking for the magnum IV because its all drive by wire no cables involved. i knew vintage airs website had prices and u had to go through there dealers i just didnt know if there was a place to order it on the net.
#15 |
Re: vintage air
also i dont know whats involved when using that kit and tryin to use a factory 5.3 compressor
#16 |
Re: vintage air
Most likely you will be able to use the factory compressor on the 5.3.
Most late model compressors can handle either clutch cycling or constant run systems. Use the proper type and amount of oil for the compressor. The oil may be listed on the comp label, other wise check with a dealer. As for the amount, Vintage Air should have an idea about that. FYI, I used to test automotive AC compressors. My guess is educated.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#17 |
Re: vintage air
Call Scotts Hotrods we are a Vintage Air Dealer and we have sold several kits to
Board members here over the last two months.We have some great deals on them.E-mail us at justin@scottshotrods.com and we will give you prices you cannot pass up.Support the Board Vendors! Justin |
#18 |
Re: vintage air
Do VA kits come with or w/o the compressor/bracket/pulley?
#19 |
Re: vintage air
When you purchase the Va sure fit kit for your year truck they come 100%complete
and the best thing is it is 100%bolt on.Yes the comp bracket does come with the kit and the comp has the pulley on it.Like I said earlier shoot us a e-mail we will take care of you. Justin justin@scottshotrods.com |
#20 |
Re: vintage air
you can't use the LSx compressor with VA system. They are a variable ratio compressor and when doing retrofits, there is no way to control the output and have to be run full out. If so, they will die an ugly death in short order. AND WILLl VOID any Vintage Air warranty.
There is only one company I know of with adapter brackets to run Sanden 508 compressor on LSx and it is Kwik Performance. All other bracket systems use SD7 compressors, which is ok to use since the front runner system uses them. VA may have recently released a conversion bracket as there was some talk of it on another board the other day
Mike Redpath Last edited by Musclerodz; 06-11-2010 at 01:26 AM. |
#21 |
Re: vintage air
good to know
#22 |
Re: vintage air
Unless your in a hurry, check with me in about a month or two. I plan on using the magnum IV in my burb' and I should have it up and running again soon. I'm going to try and get down to Summit this weekend to pick up ( if in stock ) the unit so I can begin the mock-up of everything.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 06-12-2010 at 01:56 AM. |
#23 | |
Re: vintage air
justin@scottshotrods.com (805)485-0382 |
#24 |
Re: vintage air
PM sent.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
#25 |
Re: vintage air
I do not believe that all LS compressors are variable. As of 2007, only Denso had a really good variable. The Visteon VS16 was just coming on line and was being built in Hungary. A variable compressor is easy to recognize. There will be a connector point on the body to supply the PWM signal to the control solenoid. There may or may not be an actual clutch. Some just have a drive pulley.
