#26 | |
Re: Another IFS/4 link Question
justin www.scottshotrods.com |
#27 |
Justin,
Do you use a mustang spindle? I am going to run a 8.8 ford rearend, so instead of drilling for chevy bolt pattern. I was wanting to just go with fords 5 on 4.5. Thanks Aaron |
#28 |
Justin,
More ???? to throw at you. Does your kit come with plates for the frame boxing like tci and the others do? |
#29 | |
5 on 4 3/4 chevy 5 on 4 1/2 ford your choice there on what you want to use. We also have as a upgrade 5 on 5 bolt pattern 5 on 5 1/2 6 lug justin |
#30 |
#31 |
Great. Thanks for the great customer service, and I havent even bought anything yet. lol
#32 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Hey justin. Im also looking at your 4 link kit with bags.maybe a package deal. Mii & 4 link.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#33 | |
1. 1 1/8 1/4 dom tubing on the link bars they have a right hand and a left hand thread so it is fully adjustable with out taken any bolts apart. 2.The Scotts rodends are cnc machined out of 304 s.s nobody else machines there rodends like we do.Bushing size is 5/8 and thesd size is 3/4 3.All brackets are lazer cut and bent then tig welded not mig welded. 4.1 1/2 125 wall dom shock crossmember with shock bungs tig welded in place. 5.Our rearend 4 bar brackets are fully tig welded and the rear bag mount mount is tig welded to the back side of the mount and the lower shock mounts are welded to the bracket as well. 6.The pan hard bar is made out of 1 1/8 1/4 dom tubing and has a right hand and left hand thread for adjustment.The rod ends are a 3/4 rh thread and a 3/4 left hand thread hime joints. 7.The front 4 bar frame mount brackets are tig welded as well. 8.All hardware is grade 8 bolts 9.Bags are firestone tapered spring and we have re-6 and re-7 slam bags as well we can use. After this if you are still intrested in a very high quality 4-bar please e-mail me or call me and for doing a package price NO PROBLEM AT ALL. For some fun I have never thought it would be so hard to sell our products before.lol Justin justin@scottshotrods.com (805)485-0382 |
#34 |
Yes the 4 bar kit looks killer. I will be calling this week.can you tell me any details on laying running boards.how much notch is needed.will bags and drop spindles be enough in front.does the crossmember need to be raised.
#35 | |
in detail and answer all of your questions. Justin justin@scottshotrods.com |
| Bookmarks |
