Old 06-23-2010, 01:23 AM   #26
54Caddy
GM Addicted
54Caddy's Avatar
Re: Need brake help badly!
that is true i might do both lines next get another caliper and a new driver side one also
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-23-2010, 03:25 AM   #27
Fer79
Fer79's Avatar
make sure the caliper to rotor is 1.25 "
Fer79 is offline   Reply With Quote
Old 06-23-2010, 08:40 AM   #28
grinch4om
dang its hot
grinch4om's Avatar
to isolate it, jack it up and take the wheel off, loosen the brake line at the caliper...does the rotor now spin free? if it does, replace the hose, if it does not, remove the caliper, does the rotor spin free? if it does, replace the caliper, if it does not there are issues with rotor mounting,i.e. bearings wrong, rubbing etc....if the caliper were cocked due to mounting boss' machined wrong, new pads after burn in would show a wear pattern that left areas not scuffed up...
grinch4om is offline   Reply With Quote
Old 06-23-2010, 12:26 PM   #29
54Caddy
GM Addicted
54Caddy's Avatar
ive had it up in the air several times, with the brake hose connected and try spinning the rotor it will not spin, with the caliper off it spins freely, so i replaced the caliper and still the same thing but not as bad i will try it with the hose off or just buy a new hose and see if it works out. The pads do not look like they have uneven wear or anything odd about the wear pattern.
..Mac’s Garage..
IG:MacsGarage
Old 06-23-2010, 10:38 PM   #30
f.monroe
f.monroe's Avatar
You can try spinning the wheel or rotor and if it is hard to turn , just crack open the bleeder screw. If it frees up , the hose is collapsed . No need to remove the hose just to free up the pressure .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-23-2010, 11:13 PM   #31
54Caddy
GM Addicted
54Caddy's Avatar
Thats what ill be doing tomorrow.
..Mac’s Garage..
IG:MacsGarage
Old 06-23-2010, 11:16 PM   #32
KMK454
KMK454's Avatar
Just out of curiousity, what brake fluid are you using? I need to top off the MC...
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 06-24-2010, 02:49 AM   #33
54Caddy
GM Addicted
54Caddy's Avatar
I am using the prestone synthetic fluid. The synthetic doesnt eat the paint.
..Mac’s Garage..
IG:MacsGarage
frustration!!
