#26 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: 230 straight 6 to 327 v8 same bell housing?
I'm surely going to hunt down a 350 then.
It's the cheapest to rebuild.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#27 |
Just to settle up on my original question on this thread. I pulled the 230 straight 6. The bellhousing bolted right up to the 327 small block. The clutch fit except I tossed the bracket mounted on the 6 and put a stud ball right in the 327 block.. hooked up the linkage and perfect fit.. motor mounts from the 6 fit perfectly as well. Only upgrade was the 2 row 1" thick radiator had to be bumped up to a 3 row 2" thick to keep it cool.
#28 |
Yeah as noted before the only issues with bell housing is with the older inline 6, ther 235. That is different, but the 230-250-292 is the same.
1982 K10 SWB 1987 V20 - Sold - Doh! |
#29 |
Does anyone know if the chevy small block 400 is the same block as a 327 and 350? I have a chance to pick up a running 400 to put into the 64 that Im picking up today. The truck has a stroked 250 with low gear 4speed.
#30 | |
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
#31 |
Thanks Ray. I think those were the 2 parts the guy took off the motor. I will see if he used them after all.
#32 |
GMC's n H.D.'s too!
Not trying to Hijack, but I cannot get to Persh's website, both my computer at work, and my home one are blocking it through the anti virus program, it pops up anytime I go to even this post. Is anyone else having that problem? I searched his name on the forum, and each one of the posts that had his website in it it popped up. I noticed this on another board as well.
Sorry for the hijack, just thinking someone may have an idea about what is happening, and maybe others are having the same problem. |
#33 | |
ron |
#34 |
GMC's n H.D.'s too!
Still a no go, thanks though!!! Is he on here where I could contact him directly? I looked in the members directory, and did not see Persh or Van Pershing.
#35 |
#36 |
GMC's n H.D.'s too!
Thank you!! Sorry again for the Hijack!
