230 straight 6 to 327 v8 same bell housing?
Hi all, I have a 65 C10. I'm hearing conflicting reports. It looks by eye that my bell housing on the 230 6 cylinder will match up to the 327 v8's block. ( I haven't pulled the 6 from the truck yet) Does anyone know if this is fact? I have a 3 on the tree tranny in the truck.
Thanks, Dave Last edited by mrdave03; 07-19-2010 at 09:19 PM. |
#2 | |
Re: 230 straight 6 to 327 v8 same bell housing?
If it's the inline 6, i don't think it will fit, I have a bell housing that was in my 63 parts truck, and the bolt pattern and starter slot do not line up for the bolt pattern on the V-8 block. I have not seen one for the V-6 motor, so i can't say one way or the other for it. If you want to use the stock crossmember on the frame, you will have to use something like a 1955 year model bellhousing for the V8. If you use a later model bellhousing without the angled mounts at the bottom, you will have to remove the crossmember and make a transmission mount. If I am wrong someone correct me(no offense taken)--I do not claim to know everything ![]()
My Build thread http://www.67-72chevytrucks.com/vboa...d.php?t=408574 |
![]() Join Date: Nov 2009
Not to hijack the thread but i am wondering the same thing also. I have a 64 with a inline 6, i want to put a 283 in with the original tranny and bell housing.
It is an inline 6 and I've heard people say they have done it but some say it will not.. so I'm hoping I can get the definitive answer here.
Intentionally Left Blank
Mine still has the oringinal bell housing in it. The 350 on one side, TKO on the other.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
#6 | |
The bellhousings with crossmember mounts were used through the 72 model year. These will always be made of cast iron and will also have starter mounts. 73-up are aluminum full-circle housings - no crossmember mounts or starter mount on these. The GMC V-6 bell is a totally different animal and doesn't interchange with anything else. Ray |
X2 raycow!
3x raycow
Enjoy your truck
I pulled the original 230 I6 from my '63 and put in a small block. The bellhousing definetely bolts up to both blocks.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
same here i swapped my 250 I6 and put in "87 on up small block. all the same bolt pattern.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
It's too bad certain people will post like they know what they are talking about, when they don't.
That's the only reason you get conflicting answers. Here's another thread I just posted in: http://67-72chevytrucks.com/vboard/s...t=swapping+292 I surely want to swap out my cracked 292 to a smallblock V8. Would really like one more definite answer from those who have done it - not those who haven't and think they know. Thanks in advance
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-19-2010 at 10:13 PM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
A small block will bolt up to the same bellhousing that is behind that 292. You will however have to change the passenger side motor mount bracket. The 292 version sits farther forward than the V8 version.
#13 |
It looks like to me you have confirmation.
Raycow doesn't post bad info, he has helped me many times and has always been right on with his info or comments. After he posted there was still a couple others that said they had made the swap. I would say you are good to go. |
#14 |
Thanks guys,
I wasn't questioning raycow, but more or less trying to ask people to not post what they don't know. It's frustrating when you get conflicting info. I try to always search before I post, and so many threads with some saying it won't work and some saying it will. Now I need to go find a V8 and junk the cracked 292 block. ![]() Thanks again.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-20-2010 at 01:49 AM. |
#15 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
I just changed from a V8 to a 292. The 292 passenger side mount seems to be a bit stubbier than the V8 and the angle of the motor mount is different. I've tried looking up the perch in my GM parts book, but since it was riveted to the frame, there's no part listing as replacement frames were ordered according to the VIN number.
I reserve the right to be wrong The following information as it is based solely on a personal experience and observation, not on repetitive swapping of V8's and Inline 6's, nor have any factual GM part numbers been quoted to back this claim. No person or animal has been hurt in the typing of the message. ![]()
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-20-2010 at 06:56 AM. |
#16 | |
Ray |
#17 |
there was a part nbr for the 4 x4 frame perches about 20 years ago as I had researched the availability of them then, but were obsolete already at that time. there should be a part nbr for any frame member or part
#18 |
Therefore I'm wrong again, I'll look harder! Please review the apology above!
![]() PS my support was for a 4WD.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#19 | |
![]() Join Date: Oct 2007
EDIT: And if y ou currently have a 292. you need the frame perch as discussed bove. Last edited by MikeN; 10-20-2010 at 02:37 PM. |
#20 |
![]() I'm searching for pics for my better understanding. I believe these are perches, or are they motor mounts? Top ones are 230,250 and 283 engines Bottom ones are 292 I6 As was said, the passenger side one is different.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-20-2010 at 03:48 PM. |
#21 |
Here's the link to the site I found the pics:
http://www.persh.org/pickup/perches.htm
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#22 |
bottom set in pics are for 292 I6. the top ones are for 230,250 and 283 engines
ron |
#23 |
Thanks,
I fixed the post. Are the 283 V8 the same as for 327 and 350?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-20-2010 at 03:49 PM. |
#24 |
Your pic shows perches, towers, frame brackets, or whatever else people want to call them. The mount is the bonded rubber/metal assembly that fits between the perch and the block on a V-8. Inline engines have an additional part, an engine bracket, that fits between the mount and the block.
Ray |
#25 |
