Old 08-01-2010, 04:42 PM   #26
shrunken66stroker
shrunken66stroker's Avatar
Re: May I rant a moment?
Why doesn't someone do a test so there's a definitive answer? Take a length of wire and make a few soldered connections. Then take a length and make crimped and another with wire nuts. Connect them to power, measure the output and you'll see how much resistance you have.
shrunken66stroker is offline   Reply With Quote
Old 08-01-2010, 08:24 PM   #27
bubba327
HOW long until spring??
bubba327's Avatar
Originally Posted by raycow View Post
The problem with wirenuts is that they just don't work very well with stranded wire.
Ray
Speaking as a licensed master journeyman electrician , I have found that wirenuts work extremely well on stranded wire if properly installed.(in commercial and residential applications)
For automotive use --solder and heat shrink rules the options
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
